Question about Tablets & eReaders
LG39C: "Authentication problem" when I try to connect to my home wi-fi. Wrong password? (gmail or wi-fi?) How can I start all over?
rcw1962
  • 2571 Answers
SOURCE: my wi fi is not connected. How do I do that/
I picked 1 up for the first time and connected in 2 minutes.
In settings page where you add a wireless connection, you will need to know..
Security type, mine was wpa2 ( may be wpa/wpa2/wep)
SSID, your network name that is transmitted, mine was default
password, whatever the wireless password you chose with wpa, if you have wep, it gives you a pass key, you will need to log onto your router to get this
Posted on Jul 17, 2010
chuckster57
  • 1102 Answers
SOURCE: i can't get my kindle
You need a wireless ROUTER for your house to be WIFI. Depending on who your internet service provider is, the MODEM might have a built in router. If it doesn't then you will need to purchase and install one.
Posted on Dec 31, 2010
jakaripage_j
SOURCE: how can I connect my tablet to wi-fi
on your settings go to wi fi settings turn it on
Posted on Apr 06, 2012
bumdrew
  • 397 Answers
SOURCE: Tablet not connecting to Wi-Fi; router is NETGEAR WNR 1000
Try changing your wireless encryption settings, the type of security it uses can sometimes be an issue.
Here is a detailed guide on how to access your routers settings: Netgear WNR1000 wireless settings guide
Posted on Mar 26, 2014
  • 884 Answers
SOURCE: How do I get wi-fi connection. I have inputted information for the wi-fi it says saved, then when you go to connect it says authentication problem and cannot complete registration.
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code. Also bear n mind that the code may or may not be case sensitive, and that the authentication type for both router and tablet needs to be the same. It is possible that you will only be able to change the authentication type on the Aceess Point / router and not on the tablet.
Cheers
Posted on Dec 26, 2014
My fire kindle will not connect to my internet services even until yesterday everything was working fine, I keep getting an ' authentication problem?
Try re-checking your wi-fi password. Log off your connection, Then try again to log-on. Make sure you have the right service, put in info and see if it takes. You may have to try a different service to see if the problem may be their's. If you logged into a different wi-fi recently you may still be logged into that one even though out of their range.
Nov 02, 2016 | Amazon Kindle
Why will my wifi not turn on?
Hi Michelle, try turning your tablet off then on.... If still no Wi-Fi and you're trying to connect to your home Wi-Fi The password is on the back of the modem in the house, Write it down then go into your phone/tablet settings and tap "CONNECTIONS", Then tap on Wi-Fi and make sure it's switched on(should be a button there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on it and a small window opens for the password, Type in the pass word tap ok and you're connected... Bellow is a link to a short youtube video explaining pretty much the same thing I said..... I hope this helps..., CHEERS..
How to Connect My Phone to My Internet Using Wi Fi Wireless Keeping Up...
Apr 18, 2016 | Lenovo IdeaTab A2109
How do I find Wi fi passwords?
Hi Andrew, If you're trying to connect to your home Wi-Fi The password in on the back of the modem, Write it down then go into your phone/tablet settings and click "CONNECTIONS", Then click on Wi-Fi and make sure it's switched on(should be a button there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on it and a small window opens asking for the password, You're connected... Bellow is a link to a short youtube video explaining pretty much the same thing..... I hope this helps...
https://www.youtube.com/watch?v=8XurHgNoZhs
Mar 30, 2016 | Tablets & eReaders
How do I change the password on the kindle for the wireless network?
To add a new Wi-Fi Network:
If you don't see the network you want to connect to in the list of detected networks, you can add it by choosing "Enter other Wi-Fi network" at the bottom of the list of detected networks.
  1. Make sure you are within range of the network you want to add, and that you know the network name and password (if required).
  2. Press the Home button, then press the Menu button.
  3. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  4. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks.
  5. Use the 5-way controller to navigate down to "Enter other Wi-Fi network" and press to select.
  6. Enter the name of the Wi-Fi network that you want to add.
  7. Enter the password (if required). Press the Symbol key to enter numbers or characters not present on the Kindle keyboard. You can continue to use the keyboard while the Symbol menu is displayed.
  8. Choose "submit." Kindle connects to the new Wi-Fi network.
If your Kindle fails to connect to the new Wi-Fi network, it will display an "unable to connect" message. You can try manually entering all the network information for the Wi-Fi network by choosing "set up network" when you see the "unable to connect" message. If you don't know the network information, try connecting to a different network, or contact the network's administrator.
To forget a Wi-Fi network:
You can tell Kindle to forget the Wi-Fi network you're connected to so that your Kindle doesn't connect to it automatically in the future.
  1. While connected to the network that you want to forget, press the Home button, then press the Menu button.
  2. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. The Wi-Fi network you are currently connected to displays the word "forget" next to it in the list of available networks.
  4. Choose "forget" to disconnect from the network.
To connect to a Wi-Fi network:
  1. Press the Home button, then press the Menu button.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. Kindle automatically scans for available Wi-Fi networks at periodic intervals. To rescan for available networks at any time, select "rescan."
  4. Select "connect" to connect to a network. If you see a lock symbol next to "connect," the network requires a password to connect.
  5. If necessary, enter the Wi-Fi network password, and choose "submit." Press the Symbol key to enter numbers or characters not present on the Kindle keyboard.
Once you are connected to a Wi-Fi network, Kindle automatically connects to it again whenever that network is in range. If more than one previously used network is in range, your Kindle automatically connects to the network that was most recently used.
Tip: Once your Kindle connects to a Wi-Fi network, that network displays "forget" next to it in the list of available networks. Selecting "forget" disconnects your Kindle from that Wi-Fi network and also prevents Kindle from automatically connecting to it in the future.
Mar 07, 2016 | Tablets & eReaders
When I try to connect it says authentication problem
It appears that the wi-fi you are attempting top connect with requires an authentication code. If you are connecting at home, it is the passcode for your router. if a business or pay for service system, you will need an account to connect.
Nov 08, 2014 | Tablets & eReaders
My new Nexus 7 wont go past the "Select Wi-Fi" screen although I have set the Wi-Fi up
I assume you're using a secure Wifi connection with a password and it seems like that authentication is not working. You could try using an open wifi access point to eliminate the possibility of this authentication issue.
Oct 04, 2014 | Google Nexus 7
How to tune in kindle to wi fi?
From the Home screen, press the Menu button.
Select Settings, and then select view next to Wi-Fi Settings.
In the list of detected networks, choose a network to connect to it.
If your Wi-Fi network and router support WPS (Wi-Fi Protected Setup), your Kindle will detect it.
If you don't see your network in the list, you need to add the network manually.
If the network is protected by a password or WPS (Wi-Fi Protected Setup), enter the password and then select Submit.If you don't know the Wi-Fi network password, contact the person who set up the Wi-Fi network.After you connect to a Wi-Fi network, your Kindle automatically connects to it again whenever that network is in range. If more than one network is in range, your Kindle automatically connects to the last network used.
Aug 16, 2014 | Amazon Kindle Fire HD
How to connect my tablet to wi-fi
Authentication often means "password protection" for the specific wifi connection. Usually your software will present a "dialogue" box telling you a password is necessary and give you an opportunity to enter one.
Jul 31, 2014 | RCA CA 7" Tablet with 4GB eory 28458515
Cant connect to internet
Well, I may be an 18 yr. old and I may be no wiz but I'm big into computers and there are several solutions to this. 1) If there is a password put in the wi-fi, you need to: have a device in which will be able to put in the type of security and/or put in the EXACT password. 2) Make sure it is YOUR wi-fi you're trying to connect to. And 3) If 1 and 2 don't work, contact the company of which your wi-fi was bought from. I hope this explaination was helpful for your problem.
Mar 26, 2014 | Ematic 7" Tablet Computer
Cannot connect my arnova 7d g3 to the internet keeps saying authentication problem. can anyone help
You don't know the password to your wi-fi protected setup. They changed the password when they changed your equipment. Ensure you have the correct password and that you are not too far from the access point.
Jan 20, 2013 | Tablets & eReaders
Tablets & eReaders Logo
42 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
