Question about Refrigerators
Got a 2015 actros underbed fridge will not open is there a way of opening it from the side or top not sure were the catch is. Thanks
  • 161 Answers
SOURCE: GE Side by Side Fridge Door Adjustment
Most refrigerators do not have anything to prevent the door from opening all the way. To minimize this , adjust the front leveling legs up enough so the door won't stay open by itself. The refrigerator doesn't have to be level, it just should not rock. Most are adjusted this way to let the door shut itself. This should help. If this doesn't work. make a strap with small chain or seat belt type material. Attach from the bottom of the door. Make it just long enough to not let the door open past 90 degrees.
Posted on Jul 03, 2008
landsend
  • 1066 Answers
SOURCE: fridge side wont cool unless the freezer door is open
the little fan motor in the freezer is defective.  It may only be stuck.
Posted on Apr 01, 2009
  • 323 Answers
SOURCE: Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Posted on Oct 24, 2009
gordanddar
  • 477 Answers
SOURCE: The pass. side bonnet catch will not release and open the bonnet.
Have someone lift on the bonnet while you pull the release handle.
Posted on Nov 06, 2009
SOURCE: 2006 LR3 Trunk won't open.
i have a LR3 land rover i hear the tailgate release but it does ot open. i have tried every thing. unlock and lock. need help
Posted on Sep 12, 2010
Why are my fresh vegetables freezing in my vegetable bend and my sour cream freezing on my top shelf in refrigerator. Got to be something simple. Thanks
send the model number off of the machine,if freezer is on bottom or side by side open the fridge door,look up on the right hand wall up near the ceiling and you should see a tag with the model and serial numbers,if freezer is on top open the fridge door and look at the left side wall up near the ceiling
Jan 01, 2018 | Refrigerators
Leaking water. found large oval opening under evap coil and a catch pan in fresh food conpartment. Where does it go from there?? Do I have to pull fridge or what?
There is a drain tube the runs from the bottom of the refrigerator to a catch pan that is on the compressor which in turn will evaporate the water from there. Check to make sure the drain tube is not clogged.
Oct 18, 2012 | Frigidaire FRT17B3J Top Freezer...
Fridge door squeaks, freezer door bumps
Slacken the three screws, align the door and tighten the screws up again. Try not to lean on the door when it's open.
Apr 21, 2012 | Refrigerators
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
GE side by side. Top shelf in fridge warm. bottom drawers frozen. Freezer working fine. Seems to be blowing a lot of cold air out the vents by the floor. Top shelf in fridge is 55 degrees. Diffuser...
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Mark
Dec 29, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Side by side refridgerator part too warm
Make sure the small door between the freezer and fridge is open. It should be at the top towards the rear on the wall between the fridge and freezer. Thermostat controls its open/closing. And make sure freezer is in fact freezing and you don't just have residual cold in it. Freezer should be about 0 dertees.
Feb 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
All food on top shelf of refrigeratr is freezing
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 17, 2009 | Refrigerators
Frigidaire PLHS267ZA Side by Side
Did you leave the door open? check the light socket for shorts ..check the door switch the light will go off when to door is closed..
May 04, 2008 | Frigidaire PLHS267ZA Side by Side...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
