Question about Refrigerators
I recently purchased a propane fridge for my cabin. Model unq ugp 10 dpb-cm. I can't see in the owners Manuel anything about outside venting. Does this model require it?
  • 10,075 Answers
Even if it doesnt say to vent to outside id say please do it. co can kill you in your sleep. you cant smell it. also get a good co detector and keep the batteries fresh in it.
Posted on Aug 09, 2017
  • 556 Answers
SOURCE: need owners/users manual
owners/users manual comes along with can contact your dealar for that. if he does not provide you you can contact philips sercice centre located through out world regards
Posted on Sep 12, 2007
  • 315 Answers
Click on Download the complete user guide (9002 Ko)
from right side of the window
Posted on Mar 30, 2009
  • 742 Answers
SOURCE: I need an owners manuel for a Bread Magic model 572 - style TS-238B
get that at
Just send them a request.
Posted on Jan 25, 2010
  • 2220 Answers
SOURCE: need new chain for remington pole saw, model
It should, I have been on this earth to long for a definate answer. Both saws have 40 drive links, are 3/8s, and a gauge of 0.050. Please verify my findings here:
Oregon Bar & Chain Selector
Have you contacted a local saw shop? With your chain as a pattern they can make a replacement in couple of minutes. Inquire by phone about a price you may be pleasantly surprised. Give them Oregon number 91VG040G (low kickback, most likely what your saw is fitted with). If you feel adept you might try a slightly more agressive chain but the odds of kick back increase. HTH
Posted on Feb 06, 2010
Testimonial: "thanks, chain went on easy, worked great"
SOURCE: danby propane frig model DPR2260-2 owner's manual
I have the same refrigerator and am looking for the manual as well. Did you ever find one? If so, where?
Renata BC
Posted on Oct 30, 2011
Question about ignighter
igniter failed, out of adjustment , or dirty carbon build up
Jul 14, 2017 | Danby Refrigerators
Low air flow from a/c vents
In the summertime when its hot out, a/c air flow from the vents can start to slow down. When this happens there is a simple thing that all owners can do. Most vehicles today have a cabin air filter inside the vehicle. Most of these filters are easy to get to and change. Then there are some that take a bit more work. A cabin air filter is like a engine filter and works the same way. The cabin air filter catches outside air and debris that gets into the vehicle before it can get to the a/c evaporator. When these filters get dirty they restrict the airflow from the vents. When your airflow is not as good as it used to be, remove the cabin air filter and test the flow again with the filter out. If it changes and blows better, that means the cabin air filter needs to be changed
on Sep 05, 2010 | Heating & Cooling
2003 wildwood Le trailer how do we light the gas on the refridgerator??? Did not come with manual.
Your fridge should have a switch for propane/electric/automatic. This is usually located above the fridge door & just below the freezer door. When on propane the gas will feed directly to the fridge there us no need to light it! However the propane needs to feed from the large propane tank usually mounted on the tongue of the trailer to the fridge....this takes some time . We usually light our drove first then wait a few minutes & then turn on the fridge. Please know that it takes a few hours 10-12 fir the fridge to cool down to acceptable temps.
Now if u do all the above u may have a blockage (mud dauber) in the propane line - which u can usually access thru the fridge access panel on the outside of your trailer. Bees seem to be drawn to the Oder if propane. Make sure prolate tank is shut off! Take a small brush & clean the inside of the propane line & then start from the beginning.
When the switch is set to electric, you should notice the fridge getting colder in a few hours. Again 10-12 hrs before it us acceptable to place food in it.
When the switch is in the auto mode it will automatically switch from electric to propane when you lose electricity for any reason & back to electric is you run out of propane - or shut it off.
Oh one last thing you must have your battery on in order for the fridge to work!
Oct 25, 2014 | Camping, Backpacking & Hiking
Puma trailer, Why is 2yr old Fridge not covered under warranty?
How could someone at Fixya be of assistance? Warranties typically do not convey. You should have purchased an extended warranty at time of purchase.
Try contacting the accessory manufacturer rather than the RV manufacturer.
Palomino Contact Us
May 06, 2014 | Palomino RVs
Danby propane fridge model # dpr2262w-6. the freezer still works great but fridge portion does not . the fridge has a bad smell. the fridge is at a cabin and no service
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Aug 24, 2010 | Danby DPR2262 Top Freezer Refrigerator
3 way dometic RV fridge RM2612 won't work on propane or 12 V
Check any fuses/circuit breakers in harness from battery. That battery should supply 12 volts dc to fridge lugs/terminals at bottom of fridge on outside behind vent.
If battery is good and hooked up properly but no 12 volts to fridge, then you will have to trace back to battery for broken /bad wire. If you want to test quickly, just run 2 jumper wires from battery to those 2 lugs marked + and - Battery + to + (pos)at fridge, and - battery to -Neg at fridge. That should allow you to run it on propane or 12 volt. Remember, running it on 12 volts will kill that battery pretty quick, unless it's being charged. When you are plugged in, the converter supplies the 12 volts to your fridge, as well as should be charging your battery.
Jun 18, 2010 | Dometic RM2652 Refrigerator
I bought at Dometic propane/ electric fridge for my cabin last year. It has not run properly since. The fridge will light and run for a while with a blue flame but sometimes in the idle mode it goes out....
I have to ask, what is idle mode? I've never seen one that runs on idle mode, in a RV in 15 years. Has anyone used a manometer and tested Inches of water column in propane supply to fridge, as well as other appliances?
Any I've seen run on propane, are either on, (flame present, or off, no flame present.) Flame goes out completely when not calling for cool.
Jun 13, 2010 | Dometic RM2620 Refrigerator
Danby propane frig model DPR2260-2 owner's manual
Renata BC
Oct 06, 2008 | Refrigerators
No installation Instructions or Owners Manuel
Although you gave an incomplete model number, Owners Manuals, Installation Guides, Warranty Guides and Part Lists can be found for the entire MH3184 series on this page: Whirlpool Product Literature/MH3184 Series
Hope this helps!
Aug 05, 2008 | Whirlpool MH3184XP Microwave Oven
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
