Question about Nokia Cell Phones
How do i put new code in a nokia phone.and how do i get the letter
I want to unlock nokia 100 with imei number 355520057928028
Hello. You can unlock your Nokia 100 safer and easier using unique unlock code. You can get the unique unlock code for a Nokia 100 from TheUnlockSpot.com at affordable cost. Good luck.
.................UNLOCKING INSTRUCTIONS.................
1 - Switch on your Nokia 100(New) without any sim card.
2 - Don't bother as to what is displayed on your Nokia 100(New).
3 - Compose #pw+CODE+1#.
4 - The Nokia 100(New) would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 100(New) mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 100(New)
Nov 24, 2014 | Cell Phones
How to open line nokia x2
How To Unlock Nokia X2
1.Get Your Unlock Code From Cell Phone Unlocker
2. Turn your phone on without a SIM Card
3. Compose #PW+CODE+1# ("CODE" is the unlock code we sent you)
(if locked from Fido/Roger Canada, please compose#PW+CODE+7#)
The letter P appear after press 3 times quickly the button star ( * )
The letter W appear after press 4 times quickly the button star ( * )
The letter + appear after press 2 times quickly the button star ( * )
4. The phone will show "SIM Restriction Off" This means you've unlocked your phone!
Read more: http://cellphoneforums.net/nokia/t342488-unlock-nokia-x2-easy-method-cellphoneunlocker-com.html#ixzz2UjsaZ3ps
May 30, 2013 | Cell Phones
What is my restriction code. nokia 3110. IMEI no. is 356789020560619. kindly provide the same at the earliest pse.
May i know it restricted by Which Network In which Country?
If you could provide those Details means i will check and tell is there unlock service for Model or not,!!!You can check and get Restriction code for Your Phone at
Superunlockcodes.com at Low cost and Follow the instructions to remove the Network Lock step by step:
Nokia 3110 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Nokia 3110 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 3110 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 3110 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3110.
4 - The Nokia 3110 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 3110 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia 3110
Each Nokia 3110 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 3110 mobile phone using the form above.
May 25, 2011 | Nokia 3110 Cellular Phone
I need to unlock my phone so it can be used for every network
First and foremost, you will need to purchase an unlock code.
Warning : Do not enter any wrong unlock codes on your Nokia 1280 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 1280 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 1280 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 1280.
4 - The Nokia 1280 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 1280 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia 1280
Mar 05, 2011 | Nokia 1280 Cell Phone
Security code to lock phone Nokia 6300
You can use the security mastercode instead.
1. Get the IMEI number. Type *#06# on your mobile or remove the battery. It is located on a white label under the battery. It is usually 15-17 digits long with no letter or slashes.
2. Then go to this website to get the master code.
Hope this helps. Please don't forget to vote or rate the answer. All the best!
May 07, 2010 | Nokia 6300 Cellular Phone
My nokia ask for a code 6500s imei no.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 0760677541(Unlock code)
Follow this instructions carefully
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1 - Switch on your Nokia 6500 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6500.
4 - The Nokia 6500 would then display the message "SIM Restriction Off" and will be unlocked!
Note: For Nokia 6500 mobile phones locked to the network Fido in Canada follow these instructions:
The letter p appears if you press the button star (*) three times quickly
The letter w appears if you press the button star (*) four times quickly
The symbol + appears if you press the button star (*) two times quickly
The CODE (0760677541) you need to enter is the unique unlock code for your Nokia 6500
GOODLUCK
Nov 13, 2009 | Nokia 6300 Cellular Phone
Unlocking nokia e75
For unlocking Nokia E75 follow the instructions given below & get the unlock code in this site http://www.theunlockarena.com/unlock-your-phone/rs13wp2/ & unlock your mobile in easier way ..
Warning : Do not enter any wrong unlock codes on your Nokia E75 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia E75 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia E75 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E75.
4 - The Nokia E75 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E75 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia E75
Jul 27, 2009 | Cell Phones
Need a restriction code for Nokia 3500 (Fido service provider)
Code Entry Instructions
How to Enter Unlock Codes on Nokia phones
*** please read instructions carefully before starting! ***
1. Switch ON your phone without SIM Card
2. Compose #pw+yourcode+1# ("yourcode" is meant to be the actual unlock code we gave you)
ie. if your code is 000000000000000 then enter exactly:
#pw+000000000000000+1#
*** IF THE CODE IS REJECTED, DO NOT TRY AGAIN. ***
Substitute the 1 at the end with 7.
So 2nd time try: #PW+YOURCODE+7#
ie. #pw+000000000000000+7#
The letter P appears after you quickly press 3 times the button star ( * )
The letter W appears after you quickly press 4 times the button star ( * )
The letter + appears after you quickly press 2 times the button star ( * )
The phone shows "SIM Restriction Off" and is unlocked!
IF YOU HAVE TRIED TO PUT IN AN INCORRECT CODE 3 OR MORE TIMES PREVIOUSLY & YOU GET PHONE RESTRICTED SIGN, THEN YOUR DEVICE IS HARD LOCKED AND MUST BE UNLOCKED WITH WITH A CABLE AND HARDWARE BOX.
Apr 20, 2009 | Nokia BNIB NOKIA 3500 Classic Unlocked/Sim...
Response on unlocking nokia 2360
Follow the instructions given below & unlock your mobile by getting Unlock code in this site http://www.theunlockarena.com/unlock-your-phone/rs13wp2/ & gain solution ..
Warning : Do not enter any wrong unlock codes on your Nokia 2630 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 2630 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 2630 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2630.
4 - The Nokia 2630 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2630 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia 2630
May 02, 2008 | Nokia 2366i Cellular Phone
Unlocking nokia 6300
How to Enter Unlock Codes on Nokia phones:
ie. #pw+000000000000000+1#
Jan 17, 2008 | Nokia 6300 Cellular Phone
Cell Phones Logo
29 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
