Question about Air Tools & Compressors
During heavy rain, a ROOF company installed an emergency TARP using ~200 NAILS. I now see FLASHING out of place (likely culprit & a fairly easy fix) but I have ~200 NAIL HOLES in my roof! What to do?
I truly think the flashing is the sole problem & that they knew that, but wanted to ensure I would have to buy a new roof. It is very high & steep. I can get someone up there (does it have to be a roofer?) to replace the flashing, but what can I do about those 200 nail holes?! Thank you sooooo much! :)
  • 1388 Answers
SOURCE: max roofing nailer
Max nailers are very good quality and parts are not expensive. Parts and parts list at Check the following to repair not feeding problem.
Check paw in the door should have a light spring action. Feed paw should have a medium spring action. You may have to pull the feed piston back and hold to check feed paw spring action. Feed piston should have heavy spring action. If springs seem ok then remove feed piston and replace two orings. If the feed piston spring is broken replace with correct part. Make sure that the ports that direct air to feed piston are not blocked with bits of rubber or dirt. Sometimes parts of the bumper will break off and spread thru-out the gun. Good Luck and enjoy. (parts not expensive)
Posted on Dec 11, 2008
  • 154 Answers
SOURCE: will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Posted on Jun 11, 2009
  • 82 Answers
SOURCE: Repairing screw holes in corrugated iron
You dont mention how many holes there are to be sealed, I would assume less than 10? .. a couple of options spring to mind but there may be more!
1. Try using Eternibond sealing tape over the holes .. apparently good for 25-35 years! .. will need to clean the surrounding area carefully before application. Link to site
2. You could always use the roofing screws and associated rubber grommets to ensure a watertight seal of the old holes. You may need to place some wood on the underside for the screws to bite into. This may be the cheapest option.
Hope this helps - if so, please leave feedback, if not let me know and I'll try and help some more!
Posted on Feb 02, 2010
Testimonial: "As usual from the professionals, two easy options that will be more than cost effective. Thanks for lending us your expertise!"
  • 1388 Answers
SOURCE: my makita an451 roof nailer
Nailers that use strips of nails (one nail directly behind the other) will sometimes drive two nails at once and is caused by damage to the driver. The nails are so close together that the driver will hit the first and part of the second nail head. Coil nailers, as your an451, use nails seperated by welded wire making it very difficult the the driver to hit the second nail. Usually when a coil nailer shoots two nails, it is acutally the trigger valve that acutates twice (two very rapid fires). Two very rapid fires is caused by faulty trigger valve. I have seen a roofing coil nailer fire one nail and a second nail drops out of the gun. Caused by weak / malfunction of nail feeder or wire used to weld nails together is too thick.
Posted on Sep 27, 2011
  • 885 Answers
SOURCE: my ridgid r213bna nail gun won't fire a nail, but has good pressure & no jam...
If a gun is firing and nails are not being driven into the work it's because of one of two problems. The nails aren't feeding fully under the driver or the driver isn't fully retracting each time the gun is activated. Is looks like you've eliminated a feed problem so you are going to have to take the gun apart to find out why air is not being held in the bottom of the head long enough to push the driver back up the cylinder. Go to and bring up your model so you can follow along. Remove the four screws holding the head cap on. The things that can cause your problem are: the piston seal & o-rnig are damaged, the cylinder is badly scored, the o-ring & cylinder ring on the bottom half ot the cylinder are damaged or out of place, or the driver guide under the bumper is broke or missing. If it turns out internal parts are damaged or missing, I highly recommend the overhaul kit to replace all the 'soft' parts inside the gun as long as you have it apart.
Posted on Aug 06, 2012
The rain last winter caused damage to the house and Progessive insurance won't cover any of it.
Most insurance companies do not cover mold.
I'm sorry this happened to you. I will pray for you and for someone to help you fix your roof.
May 11, 2017 | Cars & Trucks
How do i fix a leak in the trunk of my hyundai coming from the moon roof
there is hose going from each corner of the sunroof the rear 2 drain towards the trunk and should drain out the bottom of the rear quarter panels make sure the hoses are going where they should go
Sep 23, 2012 | Cars & Trucks
When it rains, water wets carpet in back of van by jack compartment and if carpet is covered by a tarp, water pools in center of tarp.
Check the gaskets on the back doors for cracks or missing pieces [ replacements are availble ], also check the gasket at the tail light on that side for the same issue. A less likely cause is sealant failure at the body seam on the roof to side panel above that area, this is rare unless there has been major body damage due to an accident.
Jun 24, 2011 | 1999 GMC Safari
My car leaks through the screw holes in the handle on the upper side of driver and passenger window when it rains. During heavy rains it will pour onto the dash and floor board. What is causing the leak...
Most of the time it's a windshield leak as the roof sould'nt have any holes in it except where the windshield is connected to the car body. Most do it yourselfers aren't experienced enough to remove and reinstall windshields so is best to call around to see who in your area does windshield work and if your in the USA and have Comperhensive insureance the company can remove and install the windsheild and charge your insurance for the work.
Mar 08, 2011 | 2007 Jeep Commander Rocky Mountain
I am a disabled woman who lives in a double wide in morgan county, my roof needs fixing i have 3 hugh cracks in my kitchen, and every time it rains it rains through. i dont have much money but maybe i...
Hello young lady, if I lived close to Morgan county, I would come and see what I could do to help you at no charge.Do you know anyone that may be able to come over and at least put a tarp of some kind over this leak until you can make an arrangement to have it repaired? You can't live right under these kind of conditions! If you know any men folk that you can call, please do it.A tarp would help a lot. Make some calls to some roofing repair Companies and explain your situation and hopefully someone will come to you're rescue. Good luck and God bless you.
Sincerely, Shastalaker7
Oct 27, 2009 | Dometic Rooftop RV Air Conditioner
2004 hummer h2 leaks water from roof over front
Seal all the lights on top. Mine flooded from the water running down the light harness wires. Used clear rtv sealant and fixed it. You will have to remove the seal the two larger lights on the corners.
Jun 23, 2009 | 2004 Hummer H2
My driver side foot well gets wet
If this only occurs during heavy rain you have a problem with the drains around the bulkhead. Alternatively the heater matrix could be leaking. Check to make sure you are not loosing coolant from the engine. If you find you are constantly topping up the coolant then heater matrix is suspect.
Jun 21, 2009 | 2001 Volkswagen Passat
Removing a stove pipe through the roof
I would begin by going up on the roof to see what the situation is because you are going to have to remove the stove pipe and repair the roof to assure no leaks. Usually the only thing holding the pipe is roof cement through a rubber boot. Use a razor blade knife to cut through the tar, then remove the boot by pulling the roofing nails that hold it in place. After that, patch the roof and reshingle. If this is more than you care to do yourself you will have to hire it done. good luck
Jan 22, 2009 | Plumbing
Trane HVAC Unit
If your condenser blow air up through the top of the condenser and you are concern about rain water affecting the unit.
You can install a roof or rain hood about 4ft above the unit to keep the rain off, The unit must be able to blow air off without causing Hi head pressure to affect the unit, The condenser must breathe or desipate heat freely.
Tell me if your question answered or if it works for you.
Mar 31, 2008 | Heating & Cooling
Air Tools & Compressors Logo
29 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
