Question about Nokia Cell Phones
How can i put lettr in a nokia mobile with out slim card
My nokia 6120c cannot take picture, if you remove your memory card it works. and then i bought new memory card it works, and then my files in my memory card corrupted after putting it in a computer and...
The problem with your unit is the memory card. The memory card is either not formatted or continues to carry viruses from your PC. Try scanning your PC with an antivirus and formatting your memory card properly and also scan it for viruses. After doin this you can then put the memory card back and install a mobile antivirus on your device. Most likely Netqin antivirus. This should solve ur problems.
Hope this solution has been helpful?
Jun 20, 2011 | Nokia 6120 classic Cellular Phone
Memory card not formated
Hi
If you are using SD card then check any security issues, otherwise switch off your Mobile and remove the your card, and switch on, wait to complete restart....... Then switch off again and Put the Memory card and switch on your mobile Now u able to format your card.
May 28, 2011 | Nokia 2690 Cell Phone
My nokia 3500c moble memory card is locked with password automatically. the same memory card is not found any password, when i install it another nokia mobile.
YOUR MEMORY CARD IS ATTACKED BY VIRUS NOW YOU CAN FORMAT YOUR MEMORY CARD WITH COMPUTER.......THEN PUT IT IN YOUR MOBILE . YOU MUST HAVE THE MEMORY CARD READER AND COMPUTER.... 1.PUT THE CARD IN THE MEMORY CARD THEN CONNECT IT TO THE PC. 2.THEN SIMPLY FORMAT IT. AND YOU ARE DONE.
Dec 12, 2010 | Nokia BNIB NOKIA 3500 Classic Unlocked/Sim...
Micro sd memory card lock password forgotten
Having 2 ways: 1. Insert the Card into any Nokia s60 OS mobiles having Microsd card, Nokia n95 Like then check this to unlock
http://www.mobiletipstricks.com/how-to-unlock-the-password-protected-memory-card-of-your-mobile-phone/
or Simply Put in Motorola Razar Mobile handset and format to have a fresh memory card
May 06, 2010 | Nokia 3110 Cellular Phone
Nokia 5800. sim card registration failed
try to insert your sim to other mobile then try balance inquiry after you have recieved the message turn off your mobile, remove the sim card and insert it again to your nokia 5800.
Aug 03, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 5300 mobile not reading memory card, though it works fine on other mobile and PC
Try to format your memory card on a pc. after formatting, try putting some songs or any other data on the card from PC and then insert it on to ur mobile phone.
If is still does not work on mobile then you need to contact Nokia as the card is working fine.
May 25, 2009 | SanDisk 2GB Secure Digital Memory Card
Why when i format my memory card itsay eror ocur operation cancel
it should be possible that some type of virus occour in your phone memory so firstly plz format your mobile with putting this code. but plz. remove your mmc card and sim card before doing this and keep a phone book number back up in your sim card because during formatting your entire contact details and images and messages were deletd. code is *#7370# and password is (nokia by default) 12345. only type this code in your mobile fone. after that plz. format your mmc card with a help of virus free computer after that put mmc card in tha mobile. thanks
rgrds: Rajiv kumar 9811461147
Mar 27, 2009 | Nokia 6600
Write protection in N70 nokia mobile MMC card
there are many things you can do to remove write protection but you have to give rating to me. Here is the first one 1.)go to MY COMPUTER 2.)right click on MMC drive 3.)click on eject. 4.)remove MMC form card reader 5.)again put it back (if at once it didn't worked try again step{2,3,4}
second method is: sometimes your USB port locks it try some other USB port & then put the MMC in memory card. pls rate me thank you
Feb 14, 2009 | Nokia N72 Cellular Phone
Unlockig code
and follow the steps
Howto use:
You need two mobile phones.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card (MMC) from the locked phone and put it into a
second mobile. Install FExplorer on the second mobile phone. Create
the directory E:SystemRecogs and copy thc-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THC-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to "12345
Aug 03, 2008 | Nokia N95 Cellular Phone
Cell Phones Logo
24 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
