Question about Oreck Vacuums
SOURCE: Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Posted on Apr 09, 2008
SOURCE: replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
SOURCE: Oreck XL Leaks Dirt At Bag Entrance
do you use a docking station to put your bag on or is it just a push on bag? also when you turn on the vac with an empty bag in it, does the outter bag blow up?
Posted on Dec 22, 2008
SOURCE: Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Posted on Oct 16, 2009
Testimonial: "Quick answer and the same thing I found out after I posted from an Oreck repair site. Thanks."
SOURCE: My Oreck XL is spitting dust out of the housing
i have a model XL2450RH and it has been blowing dust out of the joint in the back is this the same issue???
Posted on Jan 05, 2013
Jun 25, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Feb 18, 2013 | Oreck Great XL21 XL 21 8 Pound Upright...
Apr 01, 2011 | Oreck XL2200 Bagged Upright Vacuum
Mar 06, 2011 | Oreck BB2000 XL Little Hero Canister...
Jul 22, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Jul 08, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Dec 18, 2008 | Oreck XL2200 Bagged Upright Vacuum
Mar 22, 2008 | Oreck XL21 Bagged Upright Vacuum
Dec 24, 2017 | Oreck Vacuums
