Question about Garden
Predator auger #60622, I need a recoil starter #75 on engine assembly diagram.
    Top Expert:
  • Garden Master
  • 12,744 Answers
Notify predator or do online search
Posted on Aug 09, 2017
  • 11 Answers
SOURCE: Drawing or Schematic on Suzuki Lt50 Recoil Starter Assembly
This may help you a bit.
Posted on Feb 04, 2009
  • 5 Answers
I just finished replacing the ice auger in my GE HSS25GFPA side-by-side and offer some suggestions/hints.
The auger (WR17X11705) was available locally (Appliance Parts Co., $28.97). This fits many other refrigerators. The replacement took a little under 2 hours. I estimate these hints may cut the time by one-half.
There are only 4 screws in the entire ice drawer assembly. It possibly was not necessary to remove the control rod. The other 3 screws hold the front cover. There are also 2 tabs holding the top of the cover.
The most difficult part of the repair was removal of the plastic assembly housing the crusher blades and the front bearing of the auger. This is held in place by only 2 large square tabs on the sides. There is enough space to get ONE side to release BUT to get both released required careful prying with thin-bladed screwdrivers (and prayer). These "tabs" don't push in, rather the drawer flexes out. Once released, the unit slides up and angles to allow removal of the auger/crusher. Re-assembly could not be easier. Stainless sheet metal screws would probably work if you do break something.
Remove the clear inside cover of the crusher assembly and the "C" clip on the threaded end of the auger shaft to separate the auger from the crusher.
And now for my PRIMARY reason for sharing my experience - the %#$@ plastic nut/bearing is a LEFT-HAND THREAD. I only realized this when trying to bend my make-shift split screwdrive back and the SOB loosened right up!
Carefully note the locations and orientations of the blades and spacers as you move them from the old to the new auger.
Posted on May 01, 2009
  • 70 Answers
SOURCE: How to change the pull starter cord.
drill out rivets then re-rivet or use self tapping screws
Posted on Oct 04, 2009
  • 394 Answers
SOURCE: I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Posted on Feb 26, 2010
SOURCE: replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Posted on May 26, 2010
Parts for a predator gasoline auger powerhead I need a recoil starter
notify predator or do an online search for part
Aug 09, 2017 | Garden
JIFFY MODEL 75 ICE AUGER recoil isnt retracting my pull cord. A small engine repairman said i need a whole new top housing and that it is all one piece. Second opinions??
He is correct but if you are handy you can take off the starter assembly and locate/repair the problem yourself. There is a spring assembly in there and if it pops off, the string will not be retracted for starting purposes.
Nov 18, 2015 | Garden
How do I replace recoil spring on generator
Depending the manufacture of the engine the actual replacement varies. You basically need to first remove recoil starter cover assembly. In the center in most recoil rope pulleys will be screw(bolt) that need to be removed. Pay close attention the assembly order or the parts; take picture if necessary. Once you things a part and old spring is removed. Be careful even broken springs can go flying and cause injuries. Carefully put the new spring in the correct direction. Re-assemble the rope pulley unit. To put tension on the spring you wind the pulley in the same direction as it would if you was pulling the rope out. Wind until it stops then unwind up to one turn depending where the rope enters the pulley and install the starter rope. After the starter rope is installed slow let the pulley take up rope slack. Then you re-install the starter cover assembly on the engine.
Note on some engine other components needs removing just to the starter cover off. I know of some Briggs engine that this is true as the carburetors has to come off first.
Jan 12, 2015 | Electrical Supplies
I have an Ariens ST724 7hp snowblower (model:924075 serial 005629) that needs to have the starter cup, recoil, and the 4 bolts that secure the recoil replaced. The problem is all of these parts are NO
In order to order engine you must look-up the engine itself. If this blower still has the original engine then it is a
Tecumseh HSK50-65496
Recoil Part Number TEC590604 Image
t_590604_000.jpg This item has been discontinued by Tecumseh, part number STE150-003 will work but does not have the handle cup.
Original Tecumseh Part
Replaces Tecumseh 590604 and 590605
Fits Models: H, HS, HSK
For use on Snow King Models
Nov 10, 2014 | Garden
Fixing a cord recoil on a mtd mower with a 4 hp briggs and stratton engine
The upper covers and the fuel tank needs to come off, the starter on most engines is part of the engine cover so this will have to be un bolted and removed with the starter connected
May 30, 2013 | Mtd Garden
Engine doesn't turn over pull cord stuck
remove the starter assembly and see if it is the recoil or engine. if by removing the recoil it recoils the cord then it is most likely a seized engine but pull the rope a few times with the assembly in your hand to check it then try turning the flywheel by hand and see what happens
Feb 09, 2013 | Garden
I have a 8900 with techusm motor and i need a recoil starter rebuild kit it is the eskimo ice auger
You cant get the rebuild kit for this anymore. You can get a bolt on recoil starter, they are about $30.00.
Go to your Tecumseh dealer, and they should have the part.
Hope this helped.
Jan 01, 2011 | Sport & Outdoor - Others
Spring on recoil starter broke after using generator third time. now mcculloch says recoil starter is not available.have to purchase entire starter housing assembly for $105.00
Generic version of your starter is most likely available from small engine shop. Look for model and type of engine itself. Briggs stratton, honda, etc. model number if engine is usually on starter cover or stamped on block or tag attached. If the recoil part is riveted to housing you may need to either re-rivet or use screws to attach new rewind. Used parts are also available at small engine shops. Just take in the starter housing only for match-up. Good luck
Sep 13, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
We have a featherlite gas blower model # F1 1500 LE - need part # for pull cord and assembly
Recoil starter pulley - Part # 530071792 (Rope & Handle NOT included)
Recoil starter spring - Part # 545008011
Hope this helps,
Oct 15, 2009 | Poulan Featherlite Gas Blower, with Low...
Pull start recoil assembly
I bought a replacement recoil starter for my 1850 at Pats small engine parts. The part number for a 3.5 B & S is 499706. If you look on the heat shield on the side of the motor there is the engine model and s/n. Hope this helps.
May 31, 2009 | Coleman Powermate Powermate 5000W...
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
