How do I fix the picture size?
PICTURE IS TOO LARGE
  • 93 Answers
SOURCE: JVC AV2649S Picture Too Large
you can see the diagnostic menu in jvc as you press both at the same the display and the picture mode buttons
Posted on Oct 18, 2007
  • 319 Answers
SOURCE: PICTURE TO LARGE FOR THE SCREEN AND ZOOM ISNT FIXING IT
Your TV set may have settings for picture size ratios but also if you have cable or sattelite service, they too may have these settings. Try both TV and cable remocons for proper adjustment
Posted on Aug 04, 2008
skotkolr
  • 558 Answers
SOURCE: picture size
http://media.onecall.com/Image_Products/Sharp/LC_GD6UManual.pdf
Please read page 39 or in your manual page 38
Posted on Nov 28, 2008
Tech4lfe
  • 38 Answers
SOURCE: Picture too large for screen size
It's usually called format if it is an RCA
Posted on Mar 06, 2009
  • 814 Answers
SOURCE: picture is slightly too large for our sanyo DP42848
This is a problem with the aspect ratio setting. Usually found in the setup section. You can use your owners manual to locate the setup section and find the procedure for changing the aspect ratio settings.You should be able to do with the remote control or the buttons on the television. You can call the Sanyo customer support at this telephone number. 1-800-877-5032. Give them the model number of your television and they will be able to help you . I hope this information has helped you with your problem.
Posted on May 22, 2009
The picture from my fire stick is too large for the screen. The picture from my regular tv, cable and dvd are perfect. I need to know how to adjust the size of the picture.
adjust the size of your tvs picture with your tv remote. Hit mode and select desired size.
Bitcoin donation address: (anything helps!)
1BxGnavhUFra5zsuq2bdQJSz1HcFyGn8Za
Feb 28, 2017 | Televison & Video
Tv picture size
reset the code download from www.remotecodelist.com
open the remote and clean the KEYpads from corrosion, dirty, dust, or oxide, this happen since the Syscon control all information.
if does not work, go to the repair shop TV for fix it.
God bless you
Sep 09, 2012 | Logitech Harmony 650 Remote Control
No matter which picture size I select, I cannot ever seem to get the picture from the DVD to fit the screen. For instance, I am watching a DVD right now that is in wide screen, and when in...
U tries used the DVD player remote to fix this problems,could be the DVD movie?Have the same problems,with the regular tv incomming broadcasting signal?Yes,than the tv Tuner signal board is the problems and the causes it dying and shorted.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 27, 2011 | Sansui SLED2280 22 in. LCD TV
The picture at the bottom of my Panasonic Viera is cut off at the bottom. How can I fix it.
The picture is zooming in to much,u getting a close up large picture.Look in ur tv remote look for a button said like LCD MODE,VIEWMODE or P.SIZE,push one of those buttons on the remote to pick a picture differece view modes.That can fit ur tv screen.
Oct 14, 2010 | Panasonic Viera TC-L32C12 32 in. LCD TV
It appears that on this television you can only adjust the picture size when you are using the twin picture feature. You must adjust the picture size with your other remote control. Since I do not know whether you are connected to a cable box or a satellite tv box or a blu ray player or a DVD player I cannot be very specific. On your other remote control you should had an hd zoom button, aspect, format, ratio, #, or etc. Those buttons change the picture size. The other factor determining picture size is the resolution the equipment connected to your tv is set to. This tv supports 1080i but you should also try setting the connected equipment to 720p or 480p or 480i. Also the connected equipment may be connected to your tv in two places so make sure you are on the correct selection using the tv video button on the Sony remote.
May 06, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
MMS picture messages i receive on my Ka08 are too small
Depends on how large pics were sent to you. MMS pics and videos are always small in size as the max size is fixed.
Aug 09, 2009 | Cell Phones
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ilo lcd tv..picture too large??
I had the same problem and tried everything with the tv to get it back to normal. I would look for what was suggested by tvtek, but also look on your cable remote or box for an "aspect" button. That fixed my problem. If your problem occurs with DVDs as well then you may have another issue, but if it is with cable only, try this. When I called our cable company the tech said alot of people this button without even knowing it.
Feb 26, 2008 | Televison & Video
Oct 17, 2007 | JVC AV27F476 27" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
