Question about Sailrite Sewing Machines
I have a sailrite ultra feed Model # LS-1 I love it ! It will not stitch even though everything else works
Today I went to use it when the needle goes down it does not catch the bobbin thread and does not stitch ? Everything is working properly otherwise --what should I do ? thank-you Kathy
  • 192 Answers
SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Posted on Nov 14, 2007
  • 6 Answers
SOURCE: Need help catching the bobbin...not able to stitch
go back and check to see if the needle is inserted properly. I have had this problem on other machines and have found that this is a cure for some. i just got in a hurry and put it in wrong(most times the flat side of the needle goes towards the back).
Posted on May 06, 2008
  • 749 Answers
SOURCE: won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Posted on Nov 01, 2008
  • 4 Answers
SOURCE: Stitch is uneven, not straight, and tension off on top and bottom
on my industrial machine this was caused by the wrong size needle. the length was off just a fraction. just an idea, in case you bought generic needles or something.
Posted on Nov 30, 2008
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
The fabic will not move under the foot feed tried everything !!! Hve the mauels but cant figure this out !!! help and the thread in the bobbin keeps knotting up Thanks
Are the feed dogs moving when you try to stitch? If so, are they below the needle plate so they do not make contact with the fabric? If this is the case, the feed dogs have been dropped to allow darning. Check your manual and raise the feed dogs.
Is the stitch length set to at least 1 1/2 or 2? If the stitch length is set too close to zero, the needle is practically stitching in place. Lengthen the stitch so the fabric will move as the stitch is taken.
Are you sewing very fine material? If the fabric is a very light weight, there may not be enough pressure between the presser foot and the feed dogs. Most machines have an adjustment to increase the presser foot pressure. On newer machines it is usually a dial at the top left of the machine or low on the left side of the needle. Older machines sometimes have a a round cylinder the projects on the top above the needle bar that is spring loaded. Pressing the cylinder down will usually tighten the pressure. Other machines actually have a screw at the top of the needle bar that when screwed down will tighten the pressure.
Nov 22, 2015 | Sewing Machines
Stitch selector knob turns but doesnt change stitch from a straight stitch on kenmore ultra stitch eight, model 13453
when a part on the sewing machine does not respond like it's suppose to ,,then it would be a good idea to have the sewing machine checked
Nov 15, 2012 | Kenmore Sewing Machines
When i sew on my LS-1 the stiches are not catching sometimes they do for afew stiches but then get tangeled up at then end of the needle and starts to break
I would change the needle, in case there a burr or it's bent
clean under the needle plate & in the bobbin area for lint or loose threads
Aug 09, 2011 | Sailrite Ultrafeed LS-1 Deluxe Mechanical...
Where can I buy an electrical supply and foot control for a Thompson Mini Walking foot Model PW 201
Almost any dealer will sell a replacement part for the sailrite. Its a standard type controller, the cost is 40-80 depending on the quality of the controller and cord. Take the machine in the shop and try to be sure its a correct fit. Sailrite has a mail service as well.
Derek
Jan 18, 2011 | Sailrite Ultrafeed LS-1 Deluxe Mechanical...
Can I do free motion sewing on a Kenmore Ultra Stitch 12? Model 158 1595281 serial #31011208
If you can lower or disengage the feed dogs you can stitch free motion.
If the the feed dogs cannot be adjusted as described, you can set the stitch length to zero.
You can also tape an index card over the feed dogs and punch a hole where the needle needs to enter the needle/face plate.
A darning or free motion foot is needed.
Take a presser foot with you when shopping for the foot as it is important to match the shank length.
Newer sewing machines are low shank and the older ones long shank.
You can also order online at Clotilde (see "which foot to use" for a guide).
Feb 18, 2010 | Sewing Machines
Looking for user manual for Sailrite LS-1 and a source for a basic case for the same.
Go to the Sailrite site, open the "sewing machine" menu and choose "accesories". The is a case on the list which might be suitable.
Although I couldn't see any instructions option, the manufacturer should be able to supply one if you ask them, since they pubished it in the first place.
Dec 18, 2009 | Sailrite Ultrafeed LS-1 Deluxe Mechanical...
Sewing manual for a Reliable or Sailrite
The problem is that you purchased a clone of the Sailrite Ultrafeed. Most people do not know how much work Sailrite puts into each Ultrafeed Sewing Machine before it is shipped to customers. They hold 17 patents on the Zigzag Ultrafeed and know this machine inside and out. So when each machine goes through the assembly line in Indiana they are then tested by Sailrite in 2 layers of canvas then 8 layers of canvas then 4 layers of vinyl fabric if it does not sew it flawlessly they fix it, Ultrafeeds work right out of the box! So, it is highly unlikely that you will be able to get the clone machine to work. It must be totally rebuilt (a 4 hours process for an experienced technician). Sailrite will not work on any clone machines. So get your money back and buy a Sailrite Ultrafeed! If you are desperate and can not return the machine you can buy a DVD that Sailrite made for the Ultrafeed (each Ultrafeed purchased gets it free) it can be purchase here: http://www.sailrite.com/Ultrafeed-Advanced-Maintenance-DVD . It will help with timing issues, but will not show you how and what to do to rebuild the machine.
May 21, 2008 | Sailrite Ultrafeed LS-1 Mechanical Sewing...
How do I adjust the bottom thread tension?
some machines have a nob on the front loose is low numbers like 0 1 -2 most machines work well on number 3. If the nob is not on the front check and see if it is on the side.
Feb 12, 2008 | Sailrite Ultrafeed LS-1 Mechanical Sewing...
Needles for Thompson Waling foot machine
135 X 17 is the correct sizing. Needles you should use are from #18 to #22. You can order from sailrite.com or from "thompson" the manufacturer is now datco or something, located in Lubbock Texas (do a google search on Thompson mini walking foot sewing machine)
Oct 13, 2007 | Sailrite Ultrafeed LS-1 Deluxe Mechanical...
Sewing Machines Logo
29 people viewed this question
Top Sailrite Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sailrite Sewing Machine Expert? Answer questions, earn points and help others
