Question about Camping, Backpacking & Hiking
Hi, lost our charger for the Workforce Rechargeable Spotlight Model#WKF124HD
  • 67 Answers
SOURCE: i have a coleman rechargeable spotlight and i lost
try Radio Shack
Posted on Apr 06, 2009
al_kupchella
  • 843 Answers
SOURCE: I have a Kingavon 1 million cp spotlight (model
I will assume that your light has rechargable NiCad batteries. Use the following advice ONLY if you are sure this is true. If the light is more than a couple of years old, this is probably true. Of the plug has to fit, but it must also have the correct Polarity, Voltage, and Amperage. The spotlight should be labeled where you plug the charger into it with these three critical parameters. They will also be indicated on the chargers. POLARITY --- If it takes a round plug, the polarity is indicated by a symbol that looks like a C, usually with a plus sign inside of it (this indicates that the center contact is positive). VOLTAGE --- this will be expressed as VDC input on the light, and VDC output on the charger. The voltages only need to match within about 10%. AMPERAGE ---- this will be expressed as mA (milliamps, which is thousandths of amps) or as A (which is Amps). 1000 mA = 1 A. This doesn't need to match precisely either. But if it's too low, the charge will take a while and you might burn up the charger (possibly literally burning it). If the amperage on the charger is high, that's OK, so long as the voltage is not high as well.
I hope this helps, Thanks for using FixYa. Al Kupchella
Posted on Apr 29, 2010
  • 973 Answers
SOURCE: Power On Board 3 Million Rechargeable Spotlight
Vector is now owned by Black and Decker since 2006, you can order one at their website, you will need to enter the model #, here is the link http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jun 17, 2010
Testimonial: "Thank you so much!! I do appreciate it!"
  • 973 Answers
SOURCE: I have a 139c spotlight and i lost my charger
You can purchase one from Black and Decker, they purchased Vector in 2006, here is the link;
SOURCE: need manual for vector model vec1138 rechargeable
http://www.baccusglobal.com/bd/manuals/NEW%20MANUALS%20FOR%20WEB/VEC1138%20MANUAL.pdf
Posted on Nov 30, 2011
Need to buy charger for Model# WKF124HD workforce rechargeable sportspot
Look on eBay or Amazon - Fixya does not supply any equipment, manuals or software.
Aug 09, 2017 | Cameras
Could really use your help repairing a WorkForce SportSpot WKF124HD. The WorkForce SportSpot 1,000,000 candle model WKF124HD Locking Trigger MOMENTARY SWITCH for on / off light control has failed.
You can try to find the O.E.M. part, take one from an old junked light, or find a generic switch from the hardware store and make it work. You diagnosed the problem already. You could replace it with a regular (DC) switch if you normally "lock" it on most of the time.
Miniature Pushbutton Switches
You might just consider replacing it, as it seems there is risk for fire with this model.
1 000 000 Candlelight Spotlight fire
Feb 02, 2016 | Vector Cars & Trucks
Lost my charger for my vector sport spot 1,000,000 power series
My spot light just crapped out, dead battery.
I have a wall chargerand car charger available along with the on/off switch and bulb. contact me dspiper@comcast.net
Jul 25, 2012 | Vector 1 Million Rechargeable Spotlight
Lost charger for my vector sport spot 1,000,000 power series , where can I get another one?
To recharge the battery, you will need a 12VDC 300mA adapter. It will take 12 to 15 Hours to charge.
Take your light to Radio Shack, and make sure the barrel fits.
WHAT IS THE VOLTAGE OF MY VECTOR MODEL VEC117FS
6 volts rechargeable battery. Check with the manufacture for a recharger for the 110v and or a car charger for your light.
Mar 27, 2012 | Vector 1 Million Rechargeable Spotlight
I have a victorlite 1.5 million candle power spotlight lost charger but I have a 12 volt 1000ma- will that work??
If the voltage and tip polarity of your replacement charger matches the charging port on your spotlight, there's no reason why it shouldn't work as a substitute for your original charger. Note, however, that if your original charger was more powerful (say, 1.5 amps instead of the 1-amp charger you have here), it will take noticeably longer to fully charge your spotlight than the original charger took. it's not a problem if the original charger had a lower mA rating than the replacement in your hand--the spotlight will sip an appropriate amount of juice from the charger.
Jul 13, 2011 | Vector 1 Million Rechargeable Spotlight
New wall Charger needed
Depends upon the model, but most use 12v 500Ma batteries w/ a barrel-pin connector.
You can buy one here, or search this site for your model:
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=69262&tid=16032
Sep 22, 2009 | Vector 1 Million Rechargeable Spotlight
Camping, Backpacking & Hiking Logo
883 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
