Question about John Deere Garden
I have a John Deere LA115. Is there a trick to loosening the bolt on the small pulley or placing the belt back around the small pulley?
I have cleaned the deck. The belt is not broken, appears in good shape. I can place the belt around all the other pulleys except the small one. I used WD40 without help. I can't get the belt between the bracket and the pulley
  • 958 Answers
SOURCE: 2003 lancer replace serpentine belt
this pulley is still being hold by another bolt. it is a long one that is horizontal and can be access by a deep long socket wrench from the radiator side.
i hope you can find it.
tnx 4 using fixya,
drcool
Posted on Sep 17, 2008
blueextc3221
  • 15935 Answers
SOURCE: Can't get A/C belt around pulleys on my 01 Chevy Tracker 2.5 V6
Removal & Installation
1.6L Engine
A/C Compressor Belt
  1. Disconnect the negative battery cable.
  2. Loosen the A/C compressor mounting bolts.
  3. Pivot the A/C compressor towards the engine in order to relieve the tension on the belt.
  4. Remove the A/C compressor drive belt from the pulleys.
To install:
  1. Properly route and install the A/C compressor drive belt on the A/C compressor, the power steering (if equipped), and the crankshaft pulleys.
  2. Adjust the A/C compressor drive belt to obtain 6-9 mm (0.24-0.35 in) deflection.
  3. Tighten the A/C compressor mounting bolts to 13-20 f t. lbs. (18-28 Nm).
  4. Connect the negative battery cable.
Alternator Belt
  2. Remove the power steering pump and the A/C compressor drive belt.
  3. Loosen the generator mounting bolts.
  4. Pivot the generator towards the engine and remove the accessory drive belt.
To install:
  1. Properly route and install the generator drive belt on the pulleys.
  2. Adjust the alternator drive belt to obtain 6-8 mm (0.24-0.32 in) deflection for a used belt or 5-6 mm (0.20-0.24 in) deflection for a new belt.
  3. Tighten the generator mounting bolts to 17 ft. lbs. (23 Nm).
  4. Install the power steering and the A/C compressor drive belt.
  5. Connect the negative battery cable.
Power Steering Pump Belt
  2. Loosen the power steering pump mounting bolts.
  3. Pivot the power steering pump towards the engine in order to relieve the tension on the belt.
  4. Remove the power steering pump drive belt from the pulleys.
To install:
  1. Properly route and install the power steering pump drive belt on the power steering pump and the crankshaft pulleys.
  2. Adjust the power steering pump drive belt to obtain 6-9 mm (0.24-0.35 in) deflection.
  3. Tighten the power steering pump mounting bolts to 22 ft. lbs. (30 Nm).
Posted on Apr 26, 2009
  • 32 Answers
SOURCE: John Deere F620 zero turn mower
you probably have the belt on wrong, check your manual to see if you have it on right.
Posted on Jun 21, 2009
  • 302 Answers
SOURCE: john deere mower deck belt
try this. unhook the tensioning spring so you can get the belt on and the get some vise-grips on the spring and re-connect it. hope this helps
Posted on Oct 08, 2009
  • 26 Answers
SOURCE: Harmonic balancer Pulley problem. My belt
I don't know about the pulley but I CAN suggest a surpentime belt that has worked GREAT for me. It's available at most auto after markets, (Auto Zone, Oreilly's, Napa etc...) and is called a "Gator Belt". Stock belts are ribbed on the inside but the Gator Belt looks like an alligator's back on the inside. As a result, I've had one on for over four years without a problem.
Posted on Mar 06, 2010
Have a 2009 John Deere LA115 and need a belt diagram.
For a belt (replacement) diagram, contact John Deere directly.
Apr 18, 2017 | John Deere Garden
I have a John Deere 216 the belt keeps coming off. I've replaced all the pullies, it stays on longer but still comes off. It's the primary belt
The tension Pulley Need to Be very tight, Loosen the Adjuster Bolt and slide Pulley as far over as possible, then tighten bolt, If you still have a Problem then You either have a stretched out Belt or the wrong one
Jun 06, 2015 | John Deere Garden
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
Replace a fanbelt on john deere 4020 diesel tractor
Most older models had the adjustment on the alternator. loosen it and push it toward the engine. remove & replace the belt. Pull the alternator away from the engine until the pulley cannot be turned by hand due to the tension. Tighten the adjustment bolt to secure it. Don't overtighten the belt.
Sep 22, 2014 | John Deere 4020 Gas & Diesel Tractor...
Belt slipped off Transmission Pulley of John Deere D110. How to get the belt keeper aside and put the belt back on the pulley?
There are usually two bolts securing the keeper to the bottom of the tractor. remove one and loosen the other and you should be able to swing it out of your way. worst case is to take them both out and replace the belt and reinstall the keeper
Aug 25, 2014 | John Deere Riding Lawn Mower. D110 42 in....
I need the deck belt routing diagram for my John Deere 185 42" deck.
I fiound some beautiful pictures in a manual for the 48" mower deck by John Deere. I haven't
found the 42" diagrams yet, but I can TELL you how it goes on (or is supposed to). Loosen the sheaves (pulleys) and belt guides. The inside of beltl go on back side of each of th 2 blade pulleys. On the discharge side it will come around to the back side of smaller pulley. On left side it will come to back side of the foward pulley. Then it will go around the jacksheave on the engine shaft. Just remember, th notched side or inside of belt will always go to the v side of pulley and the back side or flat side of belt will go to the flat pulleys. Good luck
Jun 18, 2011 | Garden
I am looking for a belt diagram for a John Deere LH108 riding lawnmower. the belt has come off and I am having trouble getting it back on. It looks like the little black bar is next to the pulley and I...
If this is the guide your talking about: http://jdpc.deere.com/pimages/MP30/MP30295________UN14NOV02.gif
You will have to losen all of the 6 bolts to get the belt on. The belt guide is there to prevent the belt from jumping off of the pulley and it fits very close to the running belt. Without losening the bolts you will not be able to get the belt on.
Thanks for using FixYa.
Kelly
Jul 05, 2010 | Garden
How do i replace a fan belt in a John Deere 1140 .
Loosen the alternator bolts and slide it sideways until the belt can be taken off it.Once you get the belt off the pulleys you need to remove the stub shaft that goes from the motor to the pump,loosen the bolts and slide it forward with a pry bar.
Nov 17, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I need the belt routing diagram for a John Deere 160 lawn tractor.
Loosen the sheaves (pulleys) and belt guides. The inside of belt will go on back side of each of th 2 blade pulleys. On the discharge side it will come around to the back side of smaller pulley. On left side it will come to back side of the foward pulley. Then it will go around the jacksheave on the engine shaft. Just remember, th notched side or inside of belt will always go to the v side of pulley and the back side or flat side of belt will go to the flat pulleys.
Jul 07, 2009 | Garden
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
