Question about Samsung Televison & Video
Does a Samsung series 5 32inch 5100 have a scart socket
How do I connect my sharp camcorder model VL-E650U to my Samsung tv series 6 630 lcd tv to view the 8mm videos on my TV screen?
You will have to use AV cables and an adapter. The adapter looks like a scart cable connector, it is that shape , and it has 3 inputs
one red one white and one yellow. It should fit in a spare scart socket on the tv and the cables should attach to the camcorder.
Just program the video to a particular channel, you may have to consult your owners documentation to discover how this is done. Go to the channel, insert the tape and press play.
Jun 25, 2015 | Samsung Video Cameras
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
I need to know how to hook my DVD player to ,y Samsung TV. I have it hooked up and have a picture but its in black and white.
look on the back of the television and the DVD player, there should be a SCART socket and/or red, white and yellow AV sockets, either use a SCART lead and connect it to the SCART on the DVD player and the TV.Or use an AV lead with 3 auxiliary shape connectors and match the colour of each connector with the female sockets on both the TV and the DVD player instead of using the other component connections.
Nov 29, 2011 | Hitachi Televison & Video
Ampbell@xtra.co.nzDirections for connecting Sky to a Samsung series 5 Tv & Blu-ray disc player please
Try Connecting a scart lead from both scart outs to scart in on TV.
Hope this helps
Apr 14, 2011 | Samsung Televison & Video
Got given a Samsung SP42Q2HL and only one scaret input works properly the other 2 are dark in colour when using them all so can you connect up a hd sky box upto it using the component inputs?
The protocol for scart sockets is, Black in colour = all pins connected and both in and out are supported. Blue in colour = only video in and audio in connected.
If you wish to use RGD, if the tv supports it, use the black socket. Some support S Video input.
Component inputs are not supported with scart as a general rule.
Jan 01, 2011 | Samsung Televison & Video
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
Manual for samsung es65 camera I would like to view my pictures on my samsung TV I was told I could do this direct from the camera to the TV just by using the a/v cable Is this correct and if so what ports...
You can download a user manual from here:-
http://downloadcenter.samsung.com/content/UM/201002/20100202195655453/ES65_ES67_English.pdf
You should have a AV cable with the camera, that has 1 round plug at one end and 3 round plugs at the other.
The single end plugs into your camera, there is a socket on the side marked AV. The three plugs at the other end go intot the TV.
They are colour coded (White - audio left, Yellow - Video and Red - Audio right) you need to find three sockets on your TV which match. Once connected and a slide show running on your camera, select one of the AV tv channels on your tv remote control.
If there isn't the 3 colour coded sockets on your TV, there probably is a couple of SCART connectors on the back (Big black socket with about 20 holes) You can buy adaptors, from electrical stores, which convert your AV cable out to a scart. Its just a box with the 3 coloured inputs and a scart output.
Jul 03, 2010 | Samsung Cameras
I have a Toshiba DVR19DTKB DVD & VHS Recorder with Freeview , A SKY + Box, A Panasonic NV-SD240BL Video cassette recorder, A Samsung PS42B450B1W 42'' Plasma TV, and would like see a diagram of how all...
connect the aerial to the dvd/vcr/freeview combo, connect a scart from that to the tv, from the scart out socket.
you can then connect the sky from the scart marked tv to either the tv direct or to the combo if it has a second scart.
Note. a scart socket with an arrow going into a box is an input, coming out of the boe is an output and a double arrow is a two way scart.
if you use scart 2 on the tv to connect the combo, the combo will recieve a signal from the tv for recording.
Jan 21, 2010 | Televison & Video
I just bought a second hand sumsung tv with a vrc attached. it has A/V connections but for some reason i cant hook it up to my dvd player...not sure WHY!?
connect up your scart lead, from the scart socket on dvd player to the scart socket on tvyer. There are usually to sockets to connect to on the tv, it will be AV1 or AV2. To view dvd, press source button on tv remote to select AV channel you have connected the dvd played to.
Aug 15, 2009 | Samsung Televison & Video
Can't dub from Samsung VR8606 to another device
If you have a scart socket on the back of the vcr poss marked av1.Connect a scart lead to this and if the dvd recorder has scart sockets connect to the one marked av2.Then put the vcr on play and the dvd on av2 and you should be able to record,hope this works.Jamie
Jul 07, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Televison & Video Logo
29 people viewed this question
Jerry Greenberg
Jerry Greenberg
