Overnight plus a bed
SOURCE: HP 5600 all in one
For this, you need to configure your HP All in One in "answer fax calls automatically" mode.
Follow the instructions as below :
Press Setup on the panel
Press 4 then press 2 ( This selects basic fax setup and then selects auto answer )
Press > to select ON
Press OK to accept the setting.
You may like to change number of rings before auto answering the fax. You can do this by :
Press Setup
Press 4 then press 3 ( This selects Basic Fax Setup and then selects rings to answer )
Enter appropriate nuber of rings by keypad or by < OR >
Best of Luck,
rajesh_im
Can you determine if it is actually getting hot or is it just a sensor problem? If it is overheating, don't drive it till you can rectify the problem.
Overheat problems could be low coolant, water pump, radiator, thermostat, etc.
Testimonial: "it hasn't overheated as yet, but my heat gauge does rise to the top. i have checked the coolant & it is half full/empty"
SOURCE: postal code for Cape Town, South Africa
http://www.sapostalcodes.info/queryPostal/Cape+Town Looks like there are several- based on suburb
