Question about The Office Equipment & Supplies
The documents are printing in GREY scale even though I have installed new ink cartridges. Is there a setting problem or mechanical one? Is there anything that could be cleaned? Thank You.
  • 6 Answers
SOURCE: Use of black ink
My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
Posted on Jan 31, 2007
  • 2985 Answers
SOURCE: Printing Problems
Re install the software.
In so doing follow this routine
1. go to start/Faxes and printers remove the existing default printer.
Come off line and disable your anti virus software
Click on add printer and reinstall the software.
If you have no disk for example- use the install from list feature and install from the driver library
Posted on Dec 31, 2007
  • 417 Answers
SOURCE: writing in grey scale
Make sure that in the printer driver that print the text as gray scale isn't checked and that the toner saving mode isn't on. failing this you may have a faulty machine return it to the store and get an exchange.
Hope this helps
Thanks J
Posted on Jan 20, 2008
  • 108 Answers
SOURCE: I replaced both ink cartridges for the printer, won' print.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models.  I have previously spoken to epson about this exact problem.  Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
Posted on Jan 27, 2009
  • 728 Answers
SOURCE: black ink won't print even though the cartridge is
It could be you just have a bad cartridge, If it's new, take it back and get a new one to make sure it's not the cartridge. If you get the new one and it still doesn't print black, then you have a bad print head. Meaning it would need to go to a service dealer to replace or repair the print head.
Thanks Mark
Posted on May 14, 2010
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
Grayscale not printing
This happens with Refilled or Generic ink Cartridges. They ar not compatable with grey scale prints.
Try a new cartridge, Hope this works for you.
Sep 12, 2012 | Canon Pixma MG5220 InkJet Printer
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
I can't print in grayscale with my colour cartridges
The black ink cartridge is used to print in grey scale mode.
It is therefore not possible to print in grey scale using only colour ink cartridge.
Apr 11, 2011 | Dell 810 All-In-One InkJet Printer
Printing grayscale
in MS office you change pictures 's colour and print them in garyscale go to picture tool bar and change its colour and in printing prefrence from printer properties change dpi setting to save ink
Aug 09, 2009 | Dell 810 All-In-One InkJet Printer
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Want to print with black ink cartridge only
It is a little known fact that ink cartridges do have an expiry date, and it is sometimes possible that even if a printer reads full, that it has dried out and will not print. When you recieve a warning that your ink is too low you will simply be unable to print black ink after a certain point. Generaly if you want to print in only black you will have to do that when you print a document. For instance in IE when you go to file and then print you can select prefrences and select print in greyscale or black. hope this helps!
Jan 24, 2009 | Dell 922 All-In-One InkJet Printer
I have an iP-1600 Pixma printer. I have replaced both ink cartridges and the printer does print; however, the box still comes up saying "printer ink is low; replace cartridge." How do I get rid of this...
I think you are using 40/41 or 830/831 cartridge sets. Ink cartridge 41 are now a days found defective, even if it has original company mark. Tell your vendor to replace it with genuine one. Neglect the message "ink volume low". Try to print in gray scale mode avoid colour printing.At least you will be able to get your documents printed.
Sep 03, 2008 | Canon PIXMA iP1600 Printer
My MFC-210C cannot not print black
Hi ssly96
It is possible that your colour cartridge (that also has black ink in it) is low on same. Have you tried to print with the printer setting to grey scale or black only. This should fix the problem. If it does not, then please get back to me here and I will look into it further.
May 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
Use of black ink
Jan 16, 2007 | Canon Pixma iP6600D InkJet Photo Printer
29 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
