Question about NetGear Computers & Internet
Doe netgear model b90-755044-15 router save info about web sites visited
  • 221 Answers
SOURCE: Cant find my routers Gateway Site..?
First you must make sure that the Ip address 192.168.2.1 is your routers ip address.
Click on Start, Run, type cmd, then click OK. Type ipconfig /all and hit the enter key. You are looking for the Default Gateway address. Use that address in your web browser. When you set up your static Ip address on your computer, use the first three numbers of your default gateway's address, then for the fourth number, add one. For example. If your default gateway address is 192.168.2.1, then your static ip address should be 192.168.2.2.
Try this and let me know what happens.
Posted on May 31, 2008
  • 223 Answers
SOURCE: i cant find my router model
try logging into your router from Internet Explorer....go to DOS and type ipconfig and you should see the ip address of your router....type that address into I.E
Posted on Jan 23, 2009
Geekman
  • 32281 Answers
SOURCE: I have a NETGEAR wire/wireless router MBR624GU. My
This Netgear has :-
  • LAN ports: Four (4) 10/100 Mbps auto-sensing, Auto Uplink™ RJ-45 ports (one Cat 5 UTP cable included)
  • WAN port: USB 2.0
  • Wireless: 802.11g Access Point auto rate capable up to 54 Mbps†
The modem needs to be connected to the WAN port, not to a LAN port.
Posted on Dec 10, 2009
SOURCE: open block sites
orkut is bloacked. we cannot access it. we want to open it.our server is windows 2003
Posted on Jan 21, 2010
SOURCE: netgear wgt624 v3 problem,cannot go to any sites
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 27, 2010
Web Site Blocked by NETGEAR Firewall
The most common problem for your case is that the settings at the Netgear router block the web site you are trying to visit. Go at the router's settings page, locate the firewall settings and temporary disable the firewall. Check the results. In case this solve your problem, either disable the firewall or modify the existing rule that block the url that you visit. Alternative you can check the block site list at the router settings page (sometimes called parental control) and remove the url from this list.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer. Also clarify me the model of your Netgear router and the site that you have the problem.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 04, 2011 | Computers & Internet
Got a netgear wireless modem from a friend and she
The Netgear site should have to software to download, but with the Router connected to the computer you really should be able to connect to the router's onboard software by, using Web Address http://192.168.1.1 and logging in to the router. Use User Name admin and leave the password blank. Go ahead and set up all the goodies you need, like Security and Pass Codes. I have4 bee4n using a Netgear Router in my home network for many years and have no complaints! This software is the exact same software they have on the setup disk.
Apr 21, 2010 | NetGear WGR614 Wireless Router
Lost password for netgear router wnb834b
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
Apr 20, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Netgear router WGR614 - dleteing blocked site with just letter
STEP 1: Logging on to router page
1. Open up the Internet Browser says Internet Explorer, Mozilla Firefox, Netscape Navigator, Safari, etc.
2. Put http://www.routerlogin.com in address box.
3. Put the default login info while prompt i.e. ‘Username: admin’, ‘Password: password (unless you changed it)’
Steps 2 : On the left hand site u will see block sites..
-- Just delete the intial Y there
-- apply and save the changes
And ur issue will be resolved
Dec 29, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
I have a refurbished netgear wndr 3300 router with no installatiopn cd how do i get the software download
Hi Friend
Yes you will be able to download the software. please visit the site kbserver.netgear.com/downloads_support.asP
Select the model number of your router and download the software.
Enjoy
Regards
Chiranjeet
Dec 24, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Need to update firmware on netgear wgt 624 v4 router
Hi ckane47,
You can download and read about problems and solutions for this model HERE.
Goo Luck,
And don't forget to leave a rating.
Thanks
Mark
Oct 07, 2009 | NetGear WGT624 Wireless Router
Netgear WGR814v2 does not see my ASUS 1005HA-P netbook, but the netbook sees the the Netgear wireless network but cannot connect .
To connect into your own Netgear router, you need to configure the wireless card with your router's wireless configuration settings, eg.the SSID and encryption settings. Check your router manual on how to configure the router or go to the Netgear WEB site to download this info.
To configure the Netgear router for wireless you need to connect a LAN cable from the laptop to the router and run your browser with the configuration IP address. for Netgear type the URL address ;-
http://192.168.0.1
the login = admin PW = password
Then configure the SSID and encryption, record this info so you can configure the wireless card with the same settings.
You can also connect to the Internet by using a LAN cable and plug it into the Netgear router without a wireless connection.
Sep 04, 2009 | NetGear WGR614 Wireless Router
Logging sites in wndr3300
No. they do not logged history of visited websites. They only log access time/date, NAT
Jul 01, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Netgear
Netgear provides a saved file for this during installation it contains your password and info on the router most netgear products save this written file on the desktop or in a saved Documents folder.
Mar 28, 2009 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
24 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
