Question about Sewing Machines
Why does the embroidery come out white (bobbin color) and not green (thread color)?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
You are either sewing upside down (!) - with the right side facing down not up or, more likely, you have the tension too tight so the topthread is pulling the bobbin thread through to the right side.
Posted on Aug 09, 2017
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
akylas
  • 26 Answers
SOURCE: Brother PE-150V bobbin thread
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Posted on Jun 10, 2008
SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Posted on Nov 17, 2008
SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
Posted on Jan 15, 2009
kent581
  • 87 Answers
SOURCE: Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Posted on Mar 18, 2009
I have a brother 770pe and the bobbin color is white and the thread color is green, but the embroidery comes out white. What do I do?
The surface of the embroidery is often a combination of the two threads. The bobbin thread is intertwined with the top spool thread to make the design. Easy fix: make sure the bobbin thread is the same color as the top spool thread.
Aug 09, 2017 | Brother Sewing Machines
Bobbin thread shows on embroidery pattern
The bobbin thread is being pulled too hard by the top thread. The idea is to get an even pull similar to a tug of war. When it is even the thread will form a knot in the middle of the fabric.
To fix this so the top thread isn't pulling too hard lower the tension of the top thread. This should fix it.
May 08, 2015 | Janome Memory Craft 10000
My brother pe770 is allowing bobbin thread to show on top sporadically which makes the stitching look like it is speckled with white. I have adjusted tension..cleaned and changed everything.
Shelia,
when sewing these parts of the design, (small stitches? ) load your bobbin with the same top thread. Just match the top thread color, and done! No more white bobbin thread in the topside of your designs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Brother PE770 Computerized Sewing Machine
Why does the bobbin keep showing up on top of the embroidery? I have changed the bobbin, I have rethreaded the top thread, I have changed the needle, I have cleaned the bobbin area. How else can the...
Loosen the top tension a little or tighten the bobbin tension ever so slightly. If that fails you can always color the bobbin threads with a magic marker the same color as the embroidery thread. You might go to Superior Thread's web site and try some prewound bobbins. They are worth their weight in gold. Dr. Bob knows all about all kinds of thread and is very good about answering questions. I think some of his Thread University videos are available too.
Jul 15, 2014 | Brother PE-770 Embroidery Machine
The machine is pulling through more bobbin thread than embroidery thread
Sounds like a tension issue. Try rethreading the upper thread first and then lower the upper thread tension.
Jan 27, 2013 | Brother PE770 Computerized Sewing Machine
I have a ce 100 and the bobbin thread comes up and gets into my embroidery pattern. how do i loosen the top tension to stop this from happening. my purple flower has white in it from the bobbin :(
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
Bobbin thread is coming to top when embroidering. I have changed needle and re-threaded several times
Feb 16, 2010 | Singer CE-100 Futura Computerized Sewing...
Apr 30, 2008 | Brother PE-150V Computerized Sewing...
Embroidery Problem with my disney
Check your bobbin case. Thread the bobbin through your bobbin case while holding it in your left hand. Pull the thread with your right hand and feel if there is any resistance. If not, you need to adjust the tension on the bobbincase. Also check if a piece of thread or fluff did not get stuck between the tension blades on the bobbin case. If you are not sure how to adjust the tension on the bobbin case, ask your dealer to do it.
Dec 18, 2007 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
42 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
