F-20. Does not spin - Washing Machines
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
Tip
5 Best Spinning Reels Under $50
When it comes to buying a spinning reel, you'll face a variety of choices with different trade-offs. You'll come across spinning reels as cheap as 20 USD and also as expensive as 2000USD. Why such a big difference? Which one should you buy?
Best Spinning Reels Under 50 for 2016 2017
on Nov 24, 2016 | Fishing
Speed Queen Model RWM274W-3062 top loader.Stops spin cycle after about 20 sec.When i open and close door it spins again for about 20 sec then stops. What could be the problem, thanks
Washing machines kick off when they're out of balance, like if something is too heavy and waterlogged on one side. Redistribute the laundry and it will be fine.
Mar 09, 2016 | Speed Queen Washing Machines
Goodman A42-20 inside unit fan not spinning...?
if you can turn blade by hand freely try capacitor.
Jun 28, 2013 | Goodman CLQ36AR49 Air Conditioner
Fan only spins when we spin does not start up on own should it always spin
Hi!
Fan should come on about two minute after freezer door is left open. If you have to spin it to start it up, replace it.($20 average.
Don't forget to rate this post!!!
Jul 07, 2010 | Frigidaire FRS26H5AS Side by Side...
E 20 comes up on screen.not spinning
e 20 on screen not spinning. please help model atf6000fs0
Mar 12, 2010 | Frigidaire Washing Machines
My washer does not spin out and reads error 20
don't know maybe moisture in the eletronics or outlet hose could be blocked, or it is out of balance
Dec 13, 2009 | Frigidaire Affinity ATF7000E Front Load...
Flashing E 20 will not spin
blocked pump, clear blockages from pump and hoses
Oct 25, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer fills with water and thats it
Possible a bad motor control board. Depending on the age of the washer, you may need to replace the motor control board and the motor as a kit. Also be sure to test that the motor control board is getting power, I've seen cases of the motor/ motor control failing and taking out the main control also. The tech sheet is in the console and should walk you through the steps.
Jul 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Error 20 AEG washer dryer
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Jan 09, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
