Question about Whirlpool Washing Machines
My Whirlpool washer top load has rusted out around area where you put bleach in . I don't know why and now little pieces of rust are in wash tub,when washer is done washing clothes.
If it's less than 5 years old, the warranty covers replacement of the top and lid due to rust. Check here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Warranty%20Page%20-%203955869-W.pdf
Posted on Aug 24, 2009
The lid to my whirlpool cabrio top loading washing machine will not open completely???
Hello. How old is your washer? Is there rust around the bleach dispenser near the left side hinge? What probably has happened is the hinge assembly underneath the top cover has rusted from the contact with chlorine and or fumes. These washers are notorious for rusting at the hinges, especially near the bleach dispenser. The parts involved are:
left hinge arm--w10389421
right hinge arm--w10389240
left hinge spring assembly--w10358931
right hinge spring assembly--w10358932
top cover--w10391067--if this needs to be replaced, call for service--it's a solid hour to 90 minute job for an experienced tech! You have to transfer ALL THE PARTS to the new cover and it's INVOLVED--trust me! If there is rust around the bleach dispenser and underneath the top cover, you might check your serial number with Whirlpool to see if you can get a new top cover for free covered by a service bulletin dealing with rusting. To raise the top cover, remove the top screws from the hinges on the rear of the washer holding down the top cover. Then, remove the screw and metal plate protecting the wire harness and pressure hose and set it aside. Next, from the front, slide the top cover forward 1/2 inch and lift up. Have a friend assist you in holding up the top cover. You can now access the hinges mounted underneath, check for rust, and also see how the suspension rods are mounted(they are very easy to remove since there is a slot in each rod holder located at each corner at the side of the tub near the bottom. You would pull up on the tub, release the top of the rods first, then reach down and unsnap the plastic clips(2) in the center of each holder. Use a headlamp or flashlight to see. The rod will drop down and can be removed through the slot. Reverse the procedure to install.
Also, in case your suspension rods get worn out(the tub has a hobby horse "bouncy" movement), the part number for the set of 4 is w10368625. The proper way to check the rods is to place your hands on the right and left side of the tub ring(the plastic cover over the basket) and shove smartly down and release--the tub should grip going down and pull coming up--no springy movement--just like shock absorbers on a car. It should come up and settle. If it has any bounce at all, the rods are worn--symptoms will be increased out of balance errors or the washer might start banging during spin. I hope this helps you. If you are hesitant about performing any of the repairs above, please call for service!
Oct 03, 2015 | Whirlpool WTW8600YW 4.6 cu. ft. Cabrio...
Tip
Simple Tips to Make Your Washing Machine Last Longer
  1. DON’T OVERLOAD: Overloading not only is damaging to your clothes but also puts unnecessary stress on vital components. Compare overloading your washer to pulling a loaded trailer behind your family car all the time. Extra strain on the motor, transmission and suspension will most certainly shorten the life of your car. Oh, did I say your washer also has a motor, transmission and suspension?...How does overloading damage my clothes? Rubbing together of cottons causes linting. The more rubbing together the more linting and the shorter the life of the garment.
  2. DRAIN HOSE HEIGHT: Be sure to follow manufactures directions regarding proper installation. Washers have small pumps, either self powered or driven by belt off main motor. Ideally, the drain hose should hook into a drain pipe directly behind the console of your washer. If your hose is too high the pump takes longer to evacuate the water from the tub putting stress on your washer and possibly reducing cleaning effectiveness. Too low a drain hose and your water could siphon out of the unit during the wash cycle. I have been on calls where the customer said there washer would wash, stop, fill, wash, stop, fill etc. Water was siphoning from the tub.
  3. RUSTING: Clean surfaces frequently to avoid rusting, especially clean around the bleach dispenser as bleach is corrosive and will cause severe rusting if not kept clean and dry. If rusting has already appeared go to your hardware store and pick up a bottle of rust converter (not rust remover). Follow directions on bottle. This works very well on rust. It can also be painted over after 24 to 48 hours.
  4. SOAP SCUM : To reduce the build up of scum fill your washer with warm water, add a pint of vinegar and let it run through a full cycle.Follow this procedure once a month.
  5. BUY OEM PARTS: When replacing parts on your washer, be sure to buy genuine Whirlpool parts, Frigidaire parts, Kenmore parts, Maytag parts, or parts for whichever brand washer you have. This will guarantee you are using the most reliable replacement parts available.
on Dec 22, 2009 | Washing Machines
What do I do to stop the rusting?
Stop using bleach in the dispenser. Just put it in the tub after your wash machine has filled with water. The problem is, bleach eats away at the enamel and metal and if you don't have it sufficiently diluted with water, then it eats away at everything---really fast!
Oct 24, 2014 | Whirlpool Washing Machines
I have deep rust appearing around the bleach port. machine is only one year old. WHY is it rusting ?????
Samsung does not recommend the use of chlorine bleach in this machine. The bleach port is intended for color-safe bleach only. Chlorine bleach is an oxidizer that will accelerate the corrosion process of the drum, which is what you are probably seeing. The users guide for your machine states specifically that you SHOULD NOT put liquid chlorine bleach into the bleach port.
Aug 13, 2014 | Samsung WA5471AB 4.7 Cu. Ft. Top Load...
Rust around my bleach despenser and under the side of top where the despenser is help
Bleach tends to eat thru the paint and cause the rust. What I do on a call for this is to take the bleach cup out, sand the area and paint the area with appliance paint. Here is a link to the paint I use in case you want to do it. The only way to keep this from occurring again is try not to let the bleach get on the painted areas. I know this is hard to do on a washer but you can try to poor some water around the area of the bleach cup. If you should get the paint else where, be sure it is enamel appliance paint.
Nov 01, 2012 | Maytag PAV2300 Top Load Washer
Every once in a while a plume of rust get injected into the washer or rinse cycle. Are their components on this washer that can develop rust for this to happen? The model # of this Whirlpool machine is...
No depending on your citys growth rate and repair rate of the lines underground this happens to homes everyday. Another real possibility is your water heater you have not replaced. put an inline water filter on and you will be happy 2 ways no rust and better feeling longer lasting clothes
Jul 23, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
RUST SPOTS
My 10 year old Kenmore (Whirlpool) top load washer is rusting under the top cover. The entire cover from the bleach dispenser all around is rusted under the lid. Periodically, rust dislodges into the tub and stains whites. You would have to treat the rust under the lid. I decided to try, using "Rust-mort" rust treatment on a rag. The rust would all have to be wetted with the rustmort after some scrubbing with a scuff pad. I have not attempted this yet.
I went to OSH and checked lids on new top load washers. The lip on the cheaper models was not properly coated with paint, and I could feel the rough partially exposed metal, which would rust. The more expensive models had a smooth well coated lip on the underside of the cover. Hope this helps.
Oct 22, 2008 | Washing Machines
Whirlpool "ultimate Care II" KSQ8511kQ0
Having bleach spilled on the unit will hasten the process of rusting - it will eventually rust especially if in a wet humid setting
Regards
Sep 20, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Rust inside my washer
Use Oxylic Acid Crystals dissolved in hot water and test for color fast if applicable, carpets, clothes, washer, toilet, surfaces, etc. Oxcylic acid is a white crystaline acid which reacts specifically with Ferric Oxide, (rust) and oxidises the stain quite selectively. Few teasthingys in a small bowl of hot water and a toothbrush. Purchase cheap at local hardwares Hope this Helps Let me Know Ttech
Jul 24, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
717 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
