Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
see the causes and fix it. God bless you If your washer won't drain, check these:It spins, but doesn't pump It doesn't spin or pumpIt pumps, but the water returnsIt spins, but doesn't pumpIf
your washer spins but doesn't pump the water out, the drain line is
probably clogged. In many washers, a small sock or other piece of
clothing can get between the clothes tub and the outer tub that holds
the water. If the clothing gets between the tubs, it may then get into
the drain hose that's attached to the pump--or even into the pump
itself. If it's in the pump, you need to remove the hoses from the pump
and pull the item out.To
remove the sock from the outer tub port, open the washer's main access
panel and remove the large-diameter rubber hose that connects the pump
to the bottom of the outer tub. Then, using needle-nose pliers, try to
grab and remove the clothing through the port. Sometimes
you can't remove the stuck clothing from below. Then you have to remove
the agitator, top of the outer drum shield, and inner clothes tub. This
isn't easy to do--and you may need special tools--so you might be
happier getting a qualified appliance repair technician to do the job.If
the drain line isn't plugged, the problem may be with your pump. Even
if the pump appears to be turning, the internal impeller may be broken.
If so, you need to replace the pump.It doesn't spin or pumpIf
your washer doesn't spin or pump water out but the motor is running,
your washer probably has a frozen pump pulley. If so, you need to
replace the pump. To check the pulley, remove the pump from the washer
and try to rotate the pulley manually. If it doesn't turn freely--if
it's frozen or stiff--replace it. It pumps, but the water returnsIf
the water that pumps out of the machine goes back into the machine
after the spin cycle, your washer may be siphoning the water from a
laundry tub that has a slow drain, back into the washer. The usual
remedy for this is to improve the draining of the laundry tub. (Is
something stuck in the drain?) Also, check for these problems:If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
see this causes: t spins, but doesn't pump the drain line is clogged+ some sock remain, remove with pliers,+pump defective. It doesn't spin or pump frozen pulley pump defective, replace It pumps, but the water returns improve the drain line. If drain hose reach more 4 inche cut of of excess. If lower add air/gap siphon break assembly. see diagram God bless you
if it doesn't spin or agitate but you can hear the motor running check the motor coupling,common problem with whirlpool washers http://www.youtube.com/watch?v=9K1KHEogf3c hope this helps and good luck with your washer,or you could have a bad transmission but check the coupling first,part 285753A and it's around 20 dollars
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
