Question about Cub Cadet Garden
I have a cc 500 bat push mower the battery charger was leftout on rain the light dont come on for charger is it fried also does it have a plug that i can plug extenstion cord in or do I n
  • Cub Cadet Master
  • 20,559 Answers
The charger lead should have been connected to a Residual Current Device, or Earth Leakage Breaker that should have flipped the power off. There should be a reset button on the plug.
Charge the mower for 14 hours before initial use. Charge mower indoors in a dry area out of the weather. DO NOT charge in rain or wet locations. IMPORTANT: Use only the battery charger provided with this mower. Plug the battery charger into the battery first, and then into any standard 110/120 volt household electrical outlet. See Fig. 3-9 for B battery charging location. A C NOTE: If an extension cord is required, use one that is at least wire size 16 AWG. Connect the extension cord to charger before plugging extension cord into electrical outlet. NOTE: You may charge the battery with the battery removed from the mower. IMPORTANT: Always recharge battery fully. It takes 14 hours to recharge a completely discharged battery. A flashing light on the battery charger indicates the battery is less than 80 percent charged; a solid green light indicates the battery is 80 to 100 percent charged. A full charge will be achieved in less than 14 hours if the batteries were only partially discharged. NOTE: It is recommended that the mower be charged once every two months during storage. IMPORTANT: Always disconnect battery charger (or extension cord, if used) from the electrical outlet first, then disconnect battery charger from battery. NOTE: It is recommended that the mower be charged immediately after it has been discharged. Storing batteries in a discharged state could reduce future performance. WARNING: The battery contains corrosive fluid and toxic material - HANDLE WITH CARE. Keep away from children. Do not puncture, disassemble, mutilate, or incinerate. Explosive gases could be vented during charging or discharging. Use in a well ventilated area, away from sources of ignition.
Cub Cadet CC500 BAT Operator Manual Charging The Battery
Cub Cadet CC 500 BAT Review Pros Cons and Verdict
It is a 48 volt battery, so the charger for this is special. contact Cub Cadet direct for a replacement.
Service Parts
Posted on Aug 09, 2017
dromtonpa
  • 40 Answers
SOURCE: jet3 ultra power chair wont charge
If you have access to a voltmeter,put it on your battery then plug in the charger; if the voltage rises that will tell you that your charger is working.
Posted on Apr 10, 2009
  • 32 Answers
SOURCE: batteries are charged disconnected and used seperate charger thet had 3/4 charge to start with push start button nothing wheels locked but when charger is plugged in controller lights light up showing
it sounds like dead cel in one of the batteries, try having batteries loaded tested.
Posted on Jul 13, 2009
  • 396 Answers
SOURCE: I need a manual for
www.manualsonline.com
Posted on Oct 29, 2009
  • 26 Answers
SOURCE: I have a Invacare Battery charger and the green
charger broken can be repaired call
0208 676 0944
Posted on Apr 15, 2010
philwalker78
  • 608 Answers
SOURCE: can not find a drain plug in the 500 series push
They are made to be drained out of the dipstick hole. Warm the engine up and stop it,remove the spark plug cap, remove the dipstick and tip the mower to that side while placing a container under the dipstick filler. After draining, right the mower,refill with correct oil and quantity and remit the sparkplug cap. Regards Phil
Posted on Apr 17, 2011
No spark
I would first look to make sure the spark plug is not wet. Dry the end of the plug and the cap; a q-tip should work just fine. At this time look to make sure neither end is rusty. In the future my dad keeps a large pail inverted over the motor of his mower and leaves it out all winter (in the snow and rain). He has done this for many years.
Jun 03, 2014 | Mtd 22" Yard Machine Push Mower
Put bat on chager red light is flashing
Leave it on the charger over night,the light should turn green,but it may take a while.If it stays red tomorrow,check the water levels in the battery.If it is a maintenance free battery you will need a new one.If the light does not turn green.
May 20, 2011 | Garden
Mower was running then shut off. And now when I turn key it just clicks.
sounds like your battery went bad...try a battery charger and see if it works that way ..if so then bad battery or not charging the bat. when running
May 19, 2011 | Toro 52" 27hp Z Master Zero Turn Lawn...
Keypad lights not working e65
take the battery out. and plug it to the charger with no battery and turn it on if the keybad lights still dont work they likely got fried. if it got wet put the phone without the batter in non cooked rice for some hours it will absorb all the moisture. if its under warrenty take it to your service provider
Mar 26, 2011 | Nokia e65 Cellular Phone
Will not charge...
probably the bat is dead
Apr 09, 2010 | Jazz DV-179 Digital Camera
Midland GXT 550 two way radio has a constant RX read out on display as though it is constantly receiving.
my 550 got wet wos leftout in the rain now after three mounths it shows a low battery
Dec 12, 2009 | Midland Two Way Radio
14 DC volts at all time comming from bat termanels. fried one bat already. gen is off and no bat in. still 14 volts
What you are reading is the voltage coming from the trickle charger located in the generators control panel. Because these batterys are on a constant trickle charge they tend to evaporate the water out of them quicker.
We make it a habit to check the battery water level every 6 months and top off with distilled water when necessary. Because you are topping these batteries off more frequently the battery acid become diluted causing the battery not to last as long. So at least every 6 months I would also check the specific gravity of each cell in the battery as well as load testing it.
Nov 18, 2009 | Generac Electrical Supplies
Power light works when plugged in but will not power up
Your Charger Sounds like its dead,but dont worry it's a common fault with laptops etc..
they overheat,check the fuse in the plug before you buy a new one just in case.
GOOD LUCK...
Aug 09, 2009 | Acer Aspire One PC Notebook
Battery won't charge, 24v charger doesn't light up
Original battery is 130$+, or you can buy replacement for cheapest price (work the same). So, depends from the wallet, choose one... I found them on amazon, take a look:
1. cheapest one (about 30-40$): Amazon com 12N9 4B1 battery
2. Original one (130$+): Finally charging for our multi device world
I hope this was helpful. cheers
Apr 25, 2009 | Garden
Garden Logo
66 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
