Question about Honda Boating
2007 Honda 225 4 stroke outboard randomly misses between 2500 & 2900 rpm.
  • Honda Master
  • 18,201 Answers
The first and easiest thing to do is replace the spark plugs and gap them. After that is it a guessing game for electrics or fuel delivery. My advice for marine engines is always professional service as the consequences of breaking down on the water are always a problem. The engine is only 10 years old so it probably has onboard diagnostics. The engineer connects it to a computer and it tells him what is wrong.
Posted on Aug 09, 2017
  • 14 Answers
SOURCE: tune up specs for honda outboard
You have probably already found an answer, but all the specs are in the owners manual. If you do not have one, you can download one for free from under the owners section. You will only need the serial number for your engine.
Posted on Aug 10, 2009
  • 14 Answers
SOURCE: won't run much raster than idle speed
Since there is no background to this, I assume at some point in time, the motor ran ok for you...
The first thing to do is to drain one of your carburators into a glass jar to check for water. If there is water, you will see it separate from the fuel in a couple of minutes. The water is on the bottom. If there is water, you will need to flush the motor with good fuel, one carburator at a time and probably will have to pump your tank.
If there is no water, the easiest thing to try is the following...when the motor starts to bog down, activate the choke. (If you have a side mount box that activates the choke when the fast idle lever is all the way up), you will have to have someone go back to the engine and manually pull the choke lever out. If the motor picks up, the motor is most likely in need of a carb job.
You can then do a cylinder drop test while motor is idleing, momentarily pulling the spark plug wires off of the spark plugs one at a time. If you pull one off and the engine speed does not change, listen for spark at the spark plug connector to the engine. If you hear the clicking of spark spark is probably ok. The issue with that cylinder is probably fuel related...probably a clogged carburator. If one carb is not functioning correctly, they all probably need some work. If you are not into mechanical stuff, you should have a dealer do the work. After the carbs are cleaned, they need to be adjusted for proper idle and idle/air mixture as well as vacuum balanced . If you are going to attempt it yourself be sure to by a manual either from Honda or one after market.
Before the carb job, a good dealer will always do at least a compression and spark check to be sure there is not an internal issue. The spark plugs should be checked at this time and changed out if they look questionable. Only use NGK DR7EA spark plugs not a substitute.
Also, check your oil and be sure it is clean and at the proper level.
There are several other things that it can be, but this is the most common.
  • 53 Answers
SOURCE: yamaha outboard 150 4 stroke bad vibration at 700
is you propeller bent? a dent the size of a quarter will cause a shake. If not that means your engine is misfiring. here are the troubleshooting test and tool list you need to find out. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local outboard dealer. I know all these are expensive but if your going to be a outboard tech you will always need them. Troubleshooting (1) check compression. without the year model I'm giving you a average numbers. Look at your Clymer manual. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine coul clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing its fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Posted on Nov 03, 2009
  • 53 Answers
SOURCE: I have a 2009 40hp 4 stroke outboard. It sounds
not enough info. what Manufacturers and model? is it out of warranty? here are some troubleshooting tools and procedures since labor rates at your local dealer could be up to $100.00 per hour. before you start I have two Goals for you. (1) If you learn everything you can about your engine you will become more confortable and enjoy it more. (2)confirm that your engine is ok now. is the noise your hearing piston related, or is it ignition missfire. the compression check and the ignition output test will help answer that. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. Troubleshooting (1) check compression. without the Manufacturer I'm giving you a average numbers. Look at your Clymer manual for specifics. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark output. use a spark gap tester. all cylinders should jump a half inch gap. If all these test prove that the basic operation of the engine are within specification, then we can turn to fuel delivery. unfortunately you didn't give the Manufacturer so I can't give you the troubleshoot procedures for the fuel delivery system. you will need to refer to the manuel. please get Clymer manuel you will apreciate it
Posted on Nov 04, 2009
  • 54 Answers
SOURCE: what is the maximum RPM's that I should be safely
I am not an expert for Johnson but with most 2 strokes about 5100.
Posted on Nov 28, 2009
Yamaha outboard 15lh backfire or missing low rpm
Hello Bill, have you replaces the spark plugs? Do this first.
If it still backfires/misses.. have the carb cleaned and set by a competent professional.. if it still does this, remove the flywheel and see if one of the magnets has broken or come loose...(my own experience!)
Jun 13, 2017 | Seloc Yamaha Mercury Mariner Outboards...
Have a 2 stroke 225 Yamaha outboard. Alarm for what I can tell for heat, an oil went off today. Runs fine at lower rpm, but goes off when it goes up beyond 21 rpm.
How long has it been since you changed your water pump? The pressure relief valve can also cause over heat issues if it is stuck.
May 12, 2017 | Yamaha Boating
How do I stop the engine from back fireing
Sounds like the timing is off. Plugs are firing either a little to early or a little to late.
Feb 11, 2015 | Clymer Yamaha 2-225 HP Two-Stroke...
How do I set the timing on my Honda 7.5 hp 4 stroke outboard
if you havent moved the ignition plate etc then remove cam belt and put top piston to tdc and the cam pully to tdc ( mark on head ) refit belt and rotate engine by hand to check nothing catching then try !
Mar 07, 2014 | Boating
Yamaha 250vx cards outboard lost rpm wont go above 4200 rpm
clean and balance carbs , compressions all above 100psi ? sparks on all cyls ?
Sep 29, 2013 | Clymer Marine Maintenance and Repair...
Boating Logo
46 people viewed this question
Top Honda Boating Experts
Fabrice Wolters
Are you a Honda Boating Expert? Answer questions, earn points and help others
