Question about Kitchen Appliances - Others
Truning it on it goes to high and it stay there . what is wroung. it gas
Inperal deepo fryer gas.
    Top Expert:
  • 12,170 Answers
Check thermostat
Posted on Aug 09, 2017
4 Suggested Answers
SOURCE: ultrex deepo fryer
need a basket handle
Posted on Jan 02, 2008
  • 68 Answers
SOURCE: fryer will not fire
The coil in the valve is barely being held closed. Most of the time, 90%+, the thermocoupler (or thermopile) is bad.
You can clean and check the connections, and test it again. Otherwise, spend $20, and replace the thermocoupler. (thermopiles $50) Reason is, a gas valve will likely cost $250 or more. Good luck - Mike
Posted on Jul 01, 2008
tborn6
  • 700 Answers
SOURCE: Imperial propane fryer won't stay lit.
check the high limit it tripping out
Posted on May 22, 2009
When I light my Pilot on my Fryer it will not stay lit long enough to light the fryer. What can i do?
There are several possible causes of this problem, aside from a loose or damaged wire, which is uncommon. The cause in about 95% of the cases is a thermopile that has gone bad. The thermopile is the small cylinder that is attached to the pilot assembly where part of the pilot flame can contact it. It has a cable or wire going to the gas valve, high limit switch, or both. When hot enough, it produces and electrical current that keep the pilot on and allows the main gas valve to open. This is not hard to replace in most gas fryers and not too expensive. This often starts as an intermittent problem. The second possible cause is a defective high limit. The high limit is a small rectangular device with wires going to the gas valve and a tiny stainless tube that goes through the bottom of the kettle to a sensor bulb, like the thermostat has. These are usually self resetting, but may have a small red reset button. If present check the reset. If no reset, jump the two wires and see if the fryer will now light. If so, the high limit is defective, assuming the fryer is not over temperature. If defective, replace. Do not operate the fryer in this condition as there is no over temperature protection. The next cause is if the oil is too hot, in which case the high limit will shut off both the main burner and the pilot. The pilot cannot be relit until the fryer cools down and the high limit resets. If the oil is too hot, usually over 425F, replace the thermostat. If the high limit trips when the oil is in the normal operating range, replace the high limit. The final cause is a bad gas valve. This is not too common, but the gas valve is expensive and a bit difficult to replace. Check all of the other causes first.
Sep 22, 2014 | Kitchen Appliances - Others
Pilot wont stay lit falcon dominator fryer
Sep 19, 2014 | Kitchen Appliances - Others
Nearest engineer to Stamford
Sep 16, 2014 | Pitco Frialator Kitchen Appliances -...
Frymaster troubleshooting
Aug 24, 2014 | Kitchen Appliances - Others
How can you tell if the pitco fryer safety switch is bad
The safety switch is operated by extremely high temperatures. If the safety switch is bad, it will not shut off at extremely high temperatures.
Jun 02, 2014 | Imperial IFS40 Deep Fryer
Hi actually i have a cifs40 deep gas fryer and recently i change the control thermostat,now when turn the pilot on ,after 15 second the pilot stay on,but when turn the control valve knob to on position...
Hi, from the above question, the problem is not with ht thermostat but with the control board. The control board fails to hold onto power when the device is heated up, that why it goes off automatically..
Take care
Apr 26, 2010 | Imperial IFS40 Deep Fryer
Imperial cif 40 single tank bouble basket deep gas fryer
When the whole unit shuts down including the pilot light the thermocouple is not working properly. The thermocouple is what tells the gas safety valve that the pilot light is lighted. When the thermocouple fails and does not send the milli-volt (mv) signal to the gas safety valve due a failure the gas safety valve turns off the gas supply. (i.e total shut down)
If you have a handyman around you can have him disconnect the thermocouple from the gas valve control and clean the mating area in the gas valve and on the bitter end of the thermocouple. After cleaning then reconnect the thermocouple. This sometimes corrects the problem. FYI you can get a thermocouple at most any large appliance parts supply. (You will need to the know total length) It would be even better to have the old one in hand during the trip to the parts store.
Thanks for using FixYa,
Kelly
Apr 24, 2010 | Imperial IFS40 Deep Fryer
May 22, 2009 | Imperial IFS40 Deep Fryer
Pitco frialator does not stay alight
You may have gotten water in the gas inlets. You can dry it out quicker by placing a hair dryer in the pilot area and gas valves. Disconnect the gas line first of course. Do this for about 30-45 minutes and it should be O.K. Let me know how that does.
Mar 03, 2009 | Pitco Frialator 35CD Deep Fryer
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
