Question about Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor
Is there such a thing as an external digital maximiser for electric outboards?
Any PWM (pulse wave modulation) DC control rated for the voltage and draw of the motor would work. A little customizing and waterproofing would be needed.
Posted on Aug 16, 2009
50hp Mercury outboard electrical schematic
Hey David,
Yo should find all the info you need here..this will be very very helpful...' Mercury Outboard Manuals by Seloc 1965 2014
Jun 07, 2017 | Mercury Boating
I have a mercury 75hp outboard ser#OD020354 would like to know what year the motor is
QUESTION:
How can I determine when my outboard was built?
ANSWER:
Every Mercury outboard has a serial number label located on the transom bracket area of the engine. The latest serial number labels display a 2-digit number in a box at the lower right portion of the label. These digits coincide with the last two digits of the year in which the outboard was manufactured. For example, if an outboard was manufactured in 2010, the number "10" would appear in the box at the lower right portion of the label.
May 01, 2017 | Mercury Boating
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
Where is rhw spark plug on my wee boat motor.Where can I get manual for it with diagram of parts on motor. The only thing I can identify is the pull cord and lever for choke- I think.Any help much app
see this video
http://www.youtube.com/watch?v=Md-6H0rfEeI
see the orange thick wire your outboard may be similar notice the spark plug at the back of the motor near the bottom of the engine at the end of the thick orange cable. I recommend looking for a similar thick electrical cable and follow it to where it ends up.
Nov 02, 2014 | Boating
Medion How To
Basically it is drag and drop. Plug your USB external drive in. Navigate to the drive and folder you wish to store them and minimise the page. Go to Picasa and right mouse click on the photos you want then when what you require are highlighted press Ctl and C together. Maximise your external drive, select where you wish them to go and press Ctl and V.
Ctl and C = Copy
Ctl and V = Verify or Paste.
Hope that helps.
Oct 28, 2013 | Computers & Internet
Yamaha 200hp 2001 manual
  1. Fuel
    • A common problem with an easy solution, Yamaha boat engine trouble could arise due to inadequate levels of fuel or engine oil. All Yamaha outboards take unleaded gasoline as a main fuel source with a pump octane rating of 86 or higher. The type of engine oil varies according to motor size and can be found in the "Specifications" section of a particular outboard's owner's manual (See Resources).
    Electrical
    • Problems with the electrical system can also prevent a Yamaha outboard's engine from working correctly. Troubleshoot the electrical system, first removing the main fuse that's located underneath the electrical panel on any electric-starting outboard. If the connection at the center of the fuse is broken, it must be replaced by a fuse of the same amperage. The battery should also be removed, cleaned and fully charged when troubleshooting the electrical system.
    Spark Plugs
    • Owners should also remove and inspect the spark plugs during the troubleshooting process. If the insulator tip of any plug is burned, that spark plug should be replaced. The number and type of spark plug depends on the specific outboard. Additionally, owners should ensure that each spark plug gap is set to the width stipulated in the owner's manual (see Resources).
Jan 20, 2013 | Motorcycles
Accessories help for tablet
do a web search on the Brand name and see if the company still exists. The parts department of the manufacturer, may have some parts for the unit.Also check Ebay for items related to your machine.
May 02, 2009 | Computers & Internet
How to play dts/dolby digital on HK AVR5
I believe he avr-5 has 6 channel inputs, what you will need is a dolby digital 5.1 and DTS outboard surround sound processor, say an item as the Technics SH-AC500 decoder, a Harman Kardon Signature 2.1 DTS version outboard processor/preamp, and many others on the market by different manufactors, Run the discrete audio outputs from the Processor into the AVR 5`s 6 channel inputs, select 6 channel input or DVD inputs on the receivers selector and your good to go. Be sure you are playing Dolby Digital 5.1 or DTS encoded material.
Feb 08, 2009 | Harman Kardon AVR 100
Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor Logo
123 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
