Make lower case letters upper case - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 12,744 Answers
Either shift or for more upper case caps lock
Posted on Aug 09, 2017
    New Friend:
  • 30 Answers
Shift for one letter, Caps lock for all caps. Lower right and left of keyboard on most computers.
On I phone, there is an arrow on the lower left - tap once, it will turn dark, and will cap one letter. Double tap, and it will use all caps, until you release by tapping again.
Bappa170873
  • 505 Answers
SOURCE: My MS Excel vlookup function
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Posted on Oct 31, 2008
label_chick
  • 407 Answers
SOURCE: keyboard types upper case digits instead of lower
It sounds like you may have turned on the calculator function - Does one of your F keys have a light on - F10 or F11, if so Press Fn and the key that is lit up.
Posted on May 21, 2009
baker3video
  • 32 Answers
SOURCE: how to change upper case W150i
when your texting? you hit shift
Posted on Jun 27, 2009
  • 566 Answers
SOURCE: using Microsoft works 8 word processor. when I
Go to Tools/AutoCorrect.../Options and under "Correct as you type" section, uncheck "Capitalize first letter of sentences.
Posted on Nov 04, 2009
  • 1768 Answers
SOURCE: when keying in the pin or key # do you have to use
.if you are referring to the security key it depends on how you set it up in the security wizard at the initial setup
Security key can be setup with upper and lower case unless the manufacturer has specific rules for typing in the security key.
Posted on Aug 19, 2010
I am entering the correct email address and password but it says ....incorrect email or password....
It may be that your Caps Lock is set to on.
Passwords are case sensitive.
For example, if your password is: november684,
then the system will not accept November684, or NOVEMBER684, or noVember684 etc...
The password has to be exact.
If a letter in your password is Upper Case, then that letter has to be typed in as Upper Case, and if a letter is Lower Case, then it has to be typed in as Lower Case.
I'm not trying to be childish when I say:
Upper Case means: A, B, C, D etc...
Lower Case means: a, b, c, d etc...
Jan 13, 2018 | The Computers & Internet
What is the lower case letter
Upper case letters, sometimes called "Capital " letters are : QWERTYUIOP (for example).
Lower case letters are: qwertyuiop ( for example).
Jun 20, 2016 | Computers & Internet
Arrow not releasing upper case letters to lower case letters
Have you tried a power cycle? Power off, wait 20 sec or so, power on.
Jan 09, 2016 | Apple iPhone 5
What is an upper case and lower case in a password
Upper case (letter) like A and lower case (letter) like a or you can say big letters (ABCDEF) and small letters (abcde)
Mar 07, 2015 | Computers & Internet
What is a upper case letter
Its CAP as written for example: a = is lower case and A= is upper case.
Apr 24, 2014 | Computers & Internet
My smith corona sl 570 is not printing the letters c,v, b and n in both lower case and upper case. how can i fix this?
You have a key board problem. It may just need disassembly and cleaning but more likely it needs a new contact velum.
DickyO
Jan 03, 2014 | Smith Corona Wordsmith 100 Typewriter
Uppercase letter & lowercase letter what are that
Upper-case letters are the letters A-Z (also called capital or big letters). Lowercase letters are the letters a-z (also called small letters).
Dec 24, 2013 | Cell Phones
Meaningof upper and lower case letters
Upper case letters are capital letters, for example, CAPITAL, the C is upper case, the A is upper case, the P is upper case, the I is upper case, the T is upper case, the A is upper case, the A is upper case, lower case letters are what you are reading right now, for example: this sentence is in lower case. Hope that helps.
May 11, 2013 | Apple iPod touch
What is an upper and lower case letter
Upper case letters are in capital letters and lower case letters
Eg. Upper case letters are A B C D etc.
Lower case letters are a b c d etc.
What is upper case @ lower case
Not sure if this is the answer you are wating for. Anyway, 'UPPER CASE', 'lower case'. In spanish, upper case is 'letra mayúscula', and lower case is 'minúscula'. The first letter of a paraph is usually an upper case one. Same for people's names.
Just my 2 cents...
Regards, Carlos
Sep 12, 2011 | Cell Phones
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
