Question about Cub Cadet Garden
Red & blue wire on pto switch on a cub cadet rzt22 melting pto switch
  • 661 Answers
Winding in electric clutch grounded, hopefully just wire going to clutch as these get torn by sticks etc. and ground against frame. Also could be bearing gone out in clutch causing bad clutch coil windings to go bad.
Posted on Aug 09, 2017
  • 15935 Answers
SOURCE: A short in the pto wiring perhaps?
Form what you are desribing you have a direct short, probaly in the wiring going to pto. I t has rubbed somewhere and is causing your short. Unplug the wires at connector close to your pto clutch and try it again and see if fuse stuill blows after you unhook it.
If the fuse still blows it is in the wiring going back up to thje switch. If the fuse does not blow after unhooking wiring connector the problem is in the clutch.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 20, 2009
  • 109 Answers
SOURCE: cub cadet 2160 PTO problem
Yes, there is a switch on the motion lever on the transmission, but there is also a relay switch that is taped to the fuse under the hood of the mower...if this goes bad, the deck will not come on
Posted on Jun 03, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
  • 110 Answers
SOURCE: Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Posted on Nov 01, 2009
  • 146 Answers
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 07, 2010
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
Cub Cadet,model 2135. Is there a relay betwee switch and electric pto?
a short on the hydro wire have to find chase the wires from pto back if you dont find it take it in because if you dont you will burn up the stater
Sep 19, 2014 | Cub Cadet Garden
Cub cadet wiring diagram
My Cub Cadet has an override feature so the PTO will continue to run even in reverse. If yours is like mine after you turn on the PTO turn the key back toward off about a quarter of a turn and push the button above and slightly right of the key. A light in the button should turn on to show the override is active.
Aug 10, 2014 | Cub Cadet Garden
Keeps blowing fuse
There are several things that can cause the fuse to blow. PTO stands for Power Take Off and most likely this will not be the problem unless it blows the fuse when it is turned on. What you are saying is the fuse is blowing by just turning on the switch will be a short which can be anything from a pinched wire, shorted diode, short in the stator. bad voltage regulator.etc
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cant get the switch to acctavate the mower deck on a cub cadet lawnmower
Check the fuse, tan/blue wire coming off ig switch or tan coming off PTO sw.
If it keeps blowing, check wire going to PTO unit for shorts or defective connection to PTO.
Apr 16, 2014 | Cub Cadet Garden
I have a 1541 cub cadet, when I switch on the pto nothing happens
check for power going to the clutch i have seen the wires break going into the clutch under the engine
Jun 25, 2012 | Cub Cadet Garden
I have a 1999 cub 2135 with a kohler engine. the mower deck wont kick in . i ran a hot wire to the pto & it worked .do i have to replace the switch or the module. i also checked the seat switch &...
IF connecting that one hot wire to the pto made it engage then you either have a broken/cut/bad connection/wire to the pto or the switch is bad.
What you did by using the hotwire to the pto is bypass all the wiring and the switch for the pto.
You can determine if it's the switch real quick if it only has two connections/wires to the switch. Pull the switch, remove the wires and touch them together, after you have the mower in the condition under which the pto would engage. If the pto engages it's the switch for sure.
Take all the proper safety precautions. Don't let the wires touch anything else.
Sep 29, 2017 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Cub cadet 2160 PTO problem
Jun 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
