Question about Intermatic Electrical Supplies
I have an intermatic steam shower that was put in 1992. I have never used it but it doesn't seem to work. i can[t find the instruction book.
2 Suggested Answers
rwooley
  • 100 Answers
SOURCE: Steam shower no longer puts out steam, only heat.
It is no longer getting water to the unit. Valve closed, filter stopped up, or the float valve is dirty. This is something that must be cleaned regulaly especially if you have hard water. Robert
Posted on Jun 13, 2012
Everything is working as it should, but it doesn't steam
Minerals in the water may have solidified and clogged it. The vinegar is an acid which can help to dissolve and flush and rinse out the minerals.
Sep 01, 2017 | Black & Decker SV1000-4 SteamBuster Vacuum
I just moved in to an apartm with an apollo shower steam box.. but i can only shower and i have no idea how all the otheer things are working
wow very nice shower:) here is a link to all the available downloads at apollo. unfortunately your steam shower isnt in there. i put in a request for it my self so hopefully we'll get to the bottom of this soon.
http://www.apollospas.com/index.php/component/option,com_rokdownloads/Itemid,100088/id,4/view,folder/
Jul 27, 2011 | Home
Intermatic electric water heater timer only gives enough hot water for a 7 minute shower. How do I increase this time?
Try turning your thermostat up 20 degrees. That will make hotter water, requiring more cold to mix so you'll use less hot water for the shower. If that helps but you'd like it longer, increase the temperature in 10 degree increments until you reach a temperature that works.
May 14, 2009 | Intermatic T103 Indoor 120-Volt 40-amp...
Need electrical schematic for Ariel 701 steam show/jacuzzi tub
What I recommend to you is to contact a supplier that handles these units. They might be able to contact the vendor for the product to try and get more info for you. To be honest, I think your electrician is being a little unreasonable. I would consider finding another electrician. I realize he doesn't want to miswire something and then have to replace it but it would take a complete knuckle head to mess up the wiring on a motor. My opinion though!
Apr 08, 2009 | Dmm WMK-A06 Pearl Steam Shower Unit,...
1992 Pontiac Bonneville SE, steam in passenger compartment?
You need a heater core for starters...probally could use a full system flush also. Check condition of all hoses and replace as needed....also check radiator condition and replace if necessay. I have found that once one problem occurs in the cooling system it's a good idea to make sure everything is in good shape or you will wind up chasing leaks everywhere...good luck...
Feb 23, 2009 | 1992 Pontiac Bonneville
Mr. Steam's MS225
Steam unit should be one ( Maybe two) downspout outlets knee heighth or LOWER. Is it possible you have a body spray system also. Has the shower been used yet?? The outlets that are higher are probably for the body spray system.
Please rate this response and Good Luck, Phil
Dec 22, 2008 | Home
Need instructions
I have a similar sounding timer. It has the same dial and an AM/PM window on it and is made by Dynascan. I found this post on Fixya: http://www.fixya.com/support/t2314418-instructions_program_intermatic_ej351c and then went to the intermatic site and got these instructions: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx I used the RAPID programming instructions and they seemed to work great (at least the red light acted like it was supposed to.) Guess I'll find out tonight :)
Dec 01, 2008 | Hardware & Accessories
Where can I buy Miele coffee system instruction book?
You have to buy descaling tablets from miele.  You turn the knob to program mode and keep pushing the enter button until you get to descaling.  You put two descaling tablets into your water reservoir and replace into unit.  Put containers under the steam valve and the hot water wand. Press enter.  Turn steam valve al the way on.  Keep an eye on the containers.  The process takes about 30 to 40 minutes.  The message will appear 'Descaling finished." Turn steam selector to O and press enter.  Display will read "rinse machine, fill watertank.  Fill tank and return to machine.  Place empty containers beneath hot water dispenser and steam nozzle again and turn steam selector fully on. Allow water to run through system completely.  When process is finished, display will read "Rinsing Finished."  Turn steam selector to O and press enter  Program selector is on Program Mode and display will read Descaling, Timrt, unit is no descaled and ready to use.  Turn program selector to on.
Jul 24, 2008 | Miele Coffee System
Electrical Supplies Logo
32 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Craig Butler
Craig Butler
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
