Question about Sewing Machines
My needle is hitting the 1/4" quilting foot attachment. Any suggestions for me to repair?
    Genius:
  • 2,415 Answers
-Sounds like the foot is attach to the shaft is not line up.
Take it out and re install and try again. Or may be bend needle too.
Good luck
Mai Lor
Posted on Aug 09, 2017
Trifect7
  • 57 Answers
SOURCE: How do I attach a walking foot
Okay let's get started.
  • First let's look at the walking foot.
  • Turn the bulky body so that it's away from you.
  • On the left you see a groove that is going to be where you attach the foot to your machine.
  • On the right is a u-shaped arm which you can move up and down. It will go over the needle clamp
Now, let's remove your present foot from the machine and look at it.
  • Loosen the foot screw until it almost comes off. (if it does come off, screw it back on a bit.) The screw is on the left of the foot-bar.
  • On the right you'll see the needle bar with a needle clamp (what you tighten when you replace a needle) on the right of the needle-bar.
Okay the walking foot business.
  • slide the walking foot into position so that the foot screw is in the slot on the right and the u-shaped arm is over the needle clamp, with the needle clamp in the middle of the u-shaped opening.
  • Tighten the foot screw securely, it's going to be under more strain than normal.
  • While you're at it, check that the needle-clamp is nice and tight as well.
Okay, then! There you go... Happy sewing.
Are you happy? Than please vote
Here are a few helpful pictures.
Posted on Mar 02, 2008
SewTechWayne
  • 186 Answers
SOURCE: Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Posted on Jan 31, 2009
SOURCE: quilting
Janome now has a darning foot ie it looks like an embroidery foot with a spring designed for the 1600 models. It is metal with a ring where the needle goes down through it. I removed the plastic lens inside the ring and this seems to have resolved the problem.
I usually pull my threads to the top so I can see where they are and not getting tangled underneath.
There are several good groups on Yahoo groups which offer support for starting out on quilting
Posted on Jun 05, 2009
bargainbox
  • 1388 Answers
SOURCE: Is this machine a high or low shank?
High Shank Machines are all the Janome Embroidery models MC 8000, MC 9000, 10000, 10001, 11000, 200E, 300E, 350E....etc
If yours is not an embroidery machine, it has a LOW SHANK .....the higher shank allows for easier access for the embroidery hoop.
Posted on Nov 12, 2009
SOURCE: How to attach a quilt guide
You have to unscrew the screw for the presser foot first. The walking foot will then fit. Use the same screw to attach the walking foot. Before you insert the screw, take the white handle on the walking foot and slide it on the screw arm for the needle. Now tighten the screw.
Posted on Aug 11, 2010
What foot should i use for quilting. i have a brother vx-1435
Your best option will be a "walking" or "even feed" foot. Your Brother dealer should have them in stock.
Mar 02, 2015 | Brother Sewing Machines
Brother Innovis 1e isn't stitching properly when the feed dogs are down
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem.
Nov 25, 2013 | Brother Sewing Machines
Bernina 820, quilting with the BSR foot, my machine will sometimes skip 1 to 4 stitches after going over a seam, help
Skipped stitches
Sep 27, 2013 | Sewing Machines
Walking Foot Trouble
sounds to me like you are getting what I call "flagging" of the material... where a tiny bur or something catches the material and pulls it up. If possible increase the presser a bit on the presser foot. You might also have the wrong foot for the machine or simply a defective one.
Also when it does this... do you notice any bobbin thread on top of the seam?
Feb 25, 2013 | Baby Lock Sewing Machines
Needles keep breaking when i quilt, its like they dont fit or too long quilt expression 4.0
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Jan 09, 2013 | Sewing Machines
I have just started learning how to quilt and I was told I needed a walking foot to quilt the sandwich together. I purchased one today, but I don't even know how to attach the foot. I also need to...
The foot is attached as normal, but when you're attaching it, the fork-shaped part that sticks out of the right-hand-side has to be hooked around the round pillar sticking out horizontally from the right-hand-side of the needle bar and that holds the needle securing screw. When the foot is down, you will see that the upwards motion of the needle bar raises the upper set of feed dogs on the walking foot - the whole purpose of the walking foot is to provide, effectively, a set of feed dogs on the top of the material as well as the toothed ones below the stitch plate - this allows multilayered or thick materials to be sewn as when doing quilting.
Jun 30, 2011 | Bernina Activa 130
Mar 21, 2010 | Singer Sewing Machines
Singer Esteem sewing machine. Needle works with all presser feet except my 1/4in quilt foot. It's hitting just to the side of the hole in the foot. How can I fix this? There is nothing to move the needle...
Check the needle to be sure it is not bent.
If this is not the problem, you will need to choose another foot to use until the machine can be repaired by a professional.
Feb 28, 2010 | Brother ULT2001
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Cording foot
a quilting bar attaches to one of the feet usually in the back and is attached by a little set screw. it is used as a guide to ride a long a previous line of stitching or a design to keep lines of stitches the same distance apart.
I'm familiar with 2 different types of cording feet. one looks like a zipper foot... very narrow and a notch on the side of the foot instead in the middle. to make cording ...fold a narrow piece of fabric in half and place yarn or cord along the inside of the fold.next place folded fabric with yarn inside under presser foot. but up the foot next to the yarn bump on the top side of folded fabric and stitch as close as possible. the second kind has a groove on the underside of the foot and the yarn bump follows this groove stitching is also done close to the yarn. some concideration in needle placement is needed depending on the thickness of the yarn or cord. always hand turn the needle up down the first few stitches to make sure the needle does not hit the foot.adjust if needed.
Apr 12, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
