Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door won't latch so opener can open it
Electricity went out so I manuely open it now I can't get it to latch so the opener will open it
    President:
  • 3,197 Answers
The two halves of the trolley should latch if you pull straight down on the rope and release. Usually you can then just run the opener and it will latch but sometimes you need to move the door manually to get the two halves to meet.
Posted on Jul 27, 2009
Oven door latch will not release so that I can open the door
Try jiggling the door by the handle. Jiggle it hard, both sideways, in/out and up/down. The little piece in there that releases the door may just be stuck, and didn't move quite far enough to let the door open. These things happen.
Nov 28, 2013 | GE Profile JTP18 Electric Single Oven
Nissan door latch
Bhi if you pull the door Handel to the open position and hold it there take a screwdriver and lift the latch to the open position if it's rusted spray with wd40 and let it sit for a while first good luck
Nov 30, 2017 | Cars & Trucks
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
Not locking have to manuely lock from inside the car
the wires in the trunk lid are broken. this model has poorly designed electrical. there is a wire bundle on the right hand side of the trunk lid open the bundle up and resplice the 4 wires. this will correct the doors and remote trunk opener.
Feb 16, 2010 | 2000 Buick Century
My drivers door locks with out reason. When I unlock with my key, I can open all of the doors except the drivers door. If I try to open the drivers door it will lock all of the doors again. The same thing...
seems to be a common problem on 03 kia's. most likely the latch mechanism is worn (they are mostly plastic and pretty cheaply made) and will need to be replaced. It happened to my kia and most mechanics directed me to the electric actuator, but all electircs were ok. drivers door latch went bad about 45k and front passenger door latch went bad about 65k.
Aug 14, 2009 | 2003 Kia Optima
Stuck door latch after cleaning
door latch stuck but the door is open and i can't close the door back
Sep 29, 2008 | GE Spectra JBP78 Electric Kitchen Range
Door won't open
Try holding the Off/Cancel button.
Apr 12, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
62 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
