Question about Home
Replacement parts ( o rings) for Flushomatic 707 toilet.
Go to the following link:
Click on the "Support" menu near the right corner of the page.
Then click on "Parts & Instruction Sheets"
Then enter the model of your toilet in the search box.
There is also a menu selection for getting replacement parts for your toilet if you need to; just enter the part number or model number in the search box.
Good luck on your project.
Dec 02, 2013 | Home
Glacier bay toilet leaks around the flap
The flapper replacement comes with a rubber ring that slides down over the fill tube to seat. If the old flapper ring does not remove easily, you may have to cut it to remove it. The replacement flapper also comes with ears that mount over hooks at the base of the fill tube on some toilets. You cut the flapper where indicated to remove the ring before installing.the ears on the hooks. If you buy a carded replacement, all of this information will be on the card. If not, someone at the point of purchase may be able to explain. Your well water may make it necessary to replace the flapper often but my experience has been that an inexpensive replacement lasts just as long as more expensive ones
Feb 17, 2013 | Home
How do I get replacement parts for Caesar toilet
did you find parts for Caesar 1.6 toilet ?
I am looking for it also.. thanks
May 28, 2012 | RTO Caesar 1.6 gpf One-Piece Toilet with...
The water runs out of my water tank Need a red rubber ring for an american standard 4260 toilet
Is it leaking on the floor, or just into the bowl.
You can find replacement parts at any hardware or plumbing store.
Aug 26, 2011 | American Standard Home
What number wax ring do I need?
Most wax rings are standard size. You should pull your toilet off again and scrape off all the old wax. If your toilet flange is below floor level, you may have to use two wax rings, one on top of the other. You can buy rings of different thicknesses, but standard rings should work. When you've placed the rings, place the toilet back on the flange bolts and push down HARD wiggling side to side. When you've got it down as far as you can go, sit on the bowl and wiggle side to side. Repeat this process until the toilet is sitting flush with the floor. NO PENNIES!
Mar 20, 2011 | Home
I have Kohler toilet ...I believe it was a Rialto model....the numbers inside the tank are T33 K2402P3 ...
picture is of a kohler rialto
looks like you can get the parts or retro fit newer kohler flush parts
ring around for a plumber or kohler toilets seller that can supply kohler cystern parts
Apr 28, 2017 | Home
Toilet keeps running water in back tank keeps running over top of drain hole
You don't have to replace, You just need to adjust the fill valve. If you have the ball **** type just tight the top phillips screw. If you have the newer type, close the water valve under the tank and Push down a plastic ring at the bottom of the filling valve, Push down the top of the valve, lift the plastic ring to it's place and open the water valve.
Aug 01, 2010 | Toto Home
Wax ring does the black part go toward floor or towards toilet
Hi the black part goes down into the gflange away from the toilet... you want the wax part to seat up against the toilet to seal around it...
Jul 21, 2010 | Home
How do you cut lino around a toilet.
I assume you mean that you are installing a linoleum floor in a bathroom. By far, the best thing to do is remove the toilet, then install the linoleum, then replace the toilet. If you have never removed a toilet before, this might sound extreme, but it's really pretty easy --- provided that the toilet mounting hardware and the water supply pipe connections are in pretty good shape. If that is the case, you will only need to buy a new wax ring. There are plenty of good resources that you can google to give you complete instructions on toilet removal and replacement. But I will throw in one important thing --- make sure the wax ring is warm before you use it. It's very important that the wax ring is nice and soft so that it can give you a good seal. I hope you found this helpful. Good luck, and thanks for using FixYa. Al Kupchella.
May 17, 2010 | Home
Replacement ad/dc power cord
you can get a replacement ac/dc power cord for durabrand portable dvd player model # PVD-707 here;
Dec 11, 2008 | Durabrand PDV-705 Portable DVD Player
Home Logo
63 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
