Question about Dryers
Mitsubishi tv wd73735 - replaced the dpl chip but 2 tan pads , about 1/4 inch , attached to gray plactic clips need to be placed somewhere
They may be heat sensors. where do they go and how do i attach them thanks
  • 2336 Answers
SOURCE: Mitsubishi TV parts: IC
Check HERE for the DM power board.
Posted on Mar 04, 2008
Danmart
  • 291 Answers
SOURCE: Panasonic DVD-LS855 wont play to LCD TV
Did you turn on the input of the tv to receive 'external' input.? Did you plug the DVD into the right input?
Posted on Nov 07, 2008
blueextc3221
  • 15935 Answers
SOURCE: need to know placement of heated oxygen sensor
The O2 sensors are located in the exhaust piping.
One (bank 1) is on the engine side of the Catalytic convertor.
Second (bank 2) is on the other side (exhaust end).
There are manufacturers that make universal fits that will go in either location. Be sure to specify the rear sensor when you go to the parts store.
It will look like this....
It threads right into the exhaust pipe.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 05, 2009
  • 42 Answers
SOURCE: Place where the coaxial cable attaches to the TV is broken.
You most likely need to reconnect the conenction, sodering it would most likely work. IF you don't have the skillset or know some one who does, replace the TV or use another connection on it (if it has one)
Posted on Aug 25, 2009
  • 14 Answers
SOURCE: the piece that goes over my ear is broken
go into your local pound shop and you can buy them
Posted on Sep 07, 2009
Replaced DLP chip now yellow Lamp Light on the front of my Mitsubishi TV is flashing.
Look for the reset button behind the cover door in the center of the TV. It may only be a tiny hole that a paper clip will fit in. Turn off the TV, straighten a paper clip and insert it until you feel the reset button. Bush slightly and hold it in and then power up the TV. That should stop the lamp light indicator from flashing. Make sure the lamp is fully seated and the cover is firmly in place.
Aug 08, 2017 | Mitsubishi Televison & Video
I replaced a dlp chip in a mitsubishi tv. i now have a band 4" high with vertical bars in it, running across the screen. what is wrong?
Hello. I have replaced many DLP chips, as I work for a repair shop. I have seen similar symptoms when the chip isn't seated properly in the mount. There is a gray screw that should be loosened to remove the chip, and tightened when the new one is installed. Most importantly, you must make sure that the chip is seated flat in the socket before tightening the gray screw. Since you have done it once, you should have no problem correcting the issue! ??
Aug 06, 2016 | Mitsubishi WD Televison & Video
How do u hook up a set of 4"x 6" HD Scosche speakers in a 1993 GMC Suburban
i`ve got the the same truck,,pry up the corners of the dash grilles,carefully so not to crack them,usually the clips tend to break off,so grab some epoxy from hardware store first(gonna need it).Remove 4 7mm bolts and pull spkr out,,cut wires and strip,,,left side will have gray and tan,gray is positive,,right side will have light green and dark green,light green is positive(GM wiring is lights in the front,darks in the rear).Using connecters attach new spkr pigtails connect spkrs and re-install into dash. Using epoxy replace clips on grilles waiting for epoxy to set,,carefully replace grilles and your done. GOOD LUCK
Jan 24, 2013 | Car Audio & Video
52 mitsubishi has small white dots of light that dont go away on most of the screen
Mitsubishi is replacing these DMD IC chips nationwide under an unannounced kind of recall for model #'s WD60C9, WD73733, WD57734, WDY657, WD73734, WD65735, WD60735, WD65C9, WD73840, WD65833, WD65733, WD73735, WD73833, WD57733, WD65734 and others. Call them @ 800-332-2119 and give them your model, serial # and date of purchase, tell them you have the white spots, they will set up a workorder with a local Mitsubishi servicer to come to your home and replace the DMD chip. Mitsubishi will supply the part (part # 276P595010) for free, but you must pay $200 in labor. BUT...if you ask for Shantell Hebert when you call Mitsubishi, and really push the issue, she will also pay half of the $200 labor fee, so you go from $400 to repair to only $100. Once that chip is replaced, the unit works great again!!
Jul 19, 2012 | Mitsubishi WD-57733 57" HDTV
The board is a bit different than the standard 360 with different cooling fans. Also a small clip fell off from somewhere?? The thin 1-1.5" long by 1/3" inch clip appears to be a ground clip between the MB...
If the clip you are referring to is of thin metal then it's a guide that keeps your DVD drive in place, it's also not needed.
The E74 error, like the Red ring problems, can be stubborn to fix. It very much depends on the exact method you used to fix your console. If you'd like to discuss this further contact me at jordan@jordanselectronics.com
Dec 29, 2009 | Microsoft Xbox 360 Console
Double picture, defraction in colors, specially the reds and the blues, almost 3d like.
WS-65613 uses two of the STK394-250 CONVERGENCE IC CHIPS.
If convergence is skewed and or will not adjust--both chips and any of the protection resistors around them that are bad need to be replaced and the set adjusted.
The chips are gray in color and 2 1/2 inches wide by 1 1/2 inches wide and will have the Sanyo logo on them with the STK-394-250 PRINTED IN WHITE ON THE FACE OF EACH.
They will be on heat sink or sinks side by side--large metal with fins.
Considering you can buy a pair of these chips on Ebay for less than 20 dollars---total parts cost should be under 30 dollars.
If you or someone you know can do this you can save the set and a lot of money---most shops get at least 300 or more for this repair---whoever you get to do it make sure BOTH chips ARE REPLACED! If only one is changed you will have the same problem again in a few months.
After this repair is done the set should not have the problem again for 5-8 years--lifespan of these parts.
If this information has helped you rate this solution as I DO THIS HERE FOR FREE.
If you need help or advice let me know.
SD TECH
Nov 10, 2009 | Mitsubishi WS-65613 65" Rear Projection...
My Mitsubishi is displaying a 3D effect on the screen. Its is worst at the top and the bottom of the screen where the red and blue colors are warping the screen. Any suggestions? thank you so much
WT42313?
This is a model first made in 2003. For convergence it uses two of the STK-394-250 chips.
Their location numbers will be marked on the board as IC8C01 and IC8C02.
Both chips need to be replaced and any protection resistors around them need to be checked also--the resistors protect the set if either chip actually shorts.
You can buy a pair of the chips on Ebay for less than 30 dollars---someone needs to have the skill to get at them and unsolder all 18 pins on each chip.
If you or someone you know can do the repair you can save a lot of money---and the set.
Most shops get at least 300 for this kind of repair---I have done hundreds of these repairs.
The chips are gray in color--about 2 1/2 inches wide by 1 1 /2 inches tall----They will have the STK394-250 PRINTED ON THE FRONT OF THEM IN WHITE LETTERS.
IF you cannot do this repair yourself, shop around your area--if they say it HAS TO GO TO THE SHOP keep looking as any good tech can fix this right in your home in about 1 hour.
I am here to help people--I do this here for free. If this information has helped you rate this solution.
If you have any questions or need help let me know.
SD TECH
Oct 29, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Convergence point problem on a Philips TV
The 55pp9352 model number uses 2 of the STK-392-120 convergence chips--if it will not adjust in some direction--both chips and any of the 6.8 ohm resistors around them that are bad need to be replaced.
The reason this happens is the chips are about 2 1/2 inches wide X 1 1/2 inches tall with a metal back--they are attached to separate metal heat sinks and a white grease is applied to each to transfer heat quickly---after several years the heat sink grease dries out and one of the chips cannot stay cool enough and fails.
Pretty common problem in ALL rear projection sets--if model is 55pp, it is 55 inch set.
You can buy the chips on Ebay for less than 12 dollars---the resistors if needed are cheap parts.
It depends if you are able to do the repair yourself or need to have someone do it for you--most shops get at least 300 for this kind of repair--considering the parts cost less than 20 dollars if you can do it yourself you can save a lot of money.
Any good tech can do this repair in your home in about 1 hour--I know as I have done hundreds of them.
If you need help or advice let me know--I am here to help people.
Regards, SD TECH
Oct 11, 2009 | Philips Magnavox 51MP392H Rear Projection...
We are trying to change projector lamb on a soy 42 inch LCD tv. we could not find the place where it should be plugged. thank you
The reason why this tv it doesn't looks as having a lamp cover is because has a front panel first to deal with. identify first this one to release it:
the front cover is easy to identify because is big and the power button at the center identify this big part. this big plastic 10 inches width and it is large as the tv all the way east to west in the bottom of the set. It is attach to the set with two screws. this two screws are find in the extreme of this front cover but in the back side. They looks as gray dimes (coins) actually you can use one dime to unscrew them. Ready!
  • when the screws are release (not all the way out just release) is not the only thing attaching it to the body
  • note: Sony Co. in this front cover thought to clip it with three 1 inch diameter clips you can locate them with great deal of imagination: The location of them is this: if you trace an imagine line: trace it starting on the power button as center but something as 30 inches left and another 30 inches right outside + another immediately down but this time vertical line down as 3 inches down,
  • "this is half of the job"
  • releasing this front cover is hard and kind of puzzle because you take the front cover from top side towards you (watch your fingers is really hard to make this operation you need a strong fingers) note: the bottom is trapped with another inner plastic obstruction. Now with this clips in your mind try to release this clips (this clips make a weird sound when are release something as you already broke the panel. don't panic)
  • Until here the panel was release and in your hands put a side.
the lamp is covered with little door 3 inches square left side of the power button called lamp cover. use again your dime to release this last screw holding the lamp cover. inside you find the lamp.
Apr 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Colors are offset
You will need to install new convergence ICs if you need more info on this please let me know. Its a fairly easy repair.
Apr 10, 2008 | Mitsubishi WS-48613 48" Rear Projection...
Dryers Logo
29 people viewed this question
Top Dryers Experts
