Question about Refrigerators
FRIDGE IS NOT COOLING SUFFICIENTLY
THE FREEZER IS WORKING PROPERLY, LIGHTS ARE ON WHEN DOOR IS OPENED, CONDENSER COILS ARE CLEANED, CONTROL UNIT IS FUNCTIONAL. I AM NOT SURE WHERE THE EVAPORATOR COILS ARE, WHERE CAN I LOCATE SAME TO CLEAN IT
3 Suggested Answers
aasc
  • 1606 Answers
SOURCE: Refrigerator does not cool.
Ok , I'll help you .
Pull the refrig out from the wall , and unplug . Remove the 8 " X 10 " panel on the back of the refrig . Inside this panel , is the main control board .
Remove the blue plug with 3 larger wires going to it . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . Get a short piece of insulated wire , and remove about 1/4 inch of insulation , from both ends . Insert 1 end of the wire , into the slot of wire2 , and the other end , into wire3 .
Plug the refrig back in .
After about 2 min , look inside the freezer , behind the bottom crisper , and look for a red glow . This glow , is the defrost heater .
If no glow , this is an indication of a shorted defrost heater , or bad defrost thermostat , both of which are located behind the rear freezer panel . Unplug the refrig , and reinstall the blue connector , and the 8 x 10 panel .
The pt # for the heater is WR51X10101 , and the part number for the defrost bimetal is WR50X10068 . Both should be replaced . The heater is at the bottom of the coils , held on by 2 screws , and the thermostat , is clipped on the top right of the coils , with a blue and pink wire going to it .
If you do see a red glow , reasemble as above , and remove the rear inside freezer panel . At the top of the coils , on the left , you will see 2 white wires attached to a 1 " piece , which is clipped to the coils . This piece is the # 4 thermistor ( evaporator thermistor ) . Pt # WR55X10025 . Also replace the # 5 thermistor , ( freezer thermistor ) which is at the bottom of the panel , slid into a holder , also with 2 white wires going to it . Both thermistors , sent readings of temp , by coldness resistance , to the main control board , which then decides if it needs to defrost , or cycle off due to coldness reached .
Posted on Oct 11, 2009
heatman101
  • 43501 Answers
SOURCE: Bottom Freezer Profile fridge does
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 07, 2010
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
Refrigerator not cold enough
Check for air flow into the fridge compartment. In these refrigerators, incoming cold air is ported in at the top left-hand side of the fridge compartment...the problem has to be with the return air vent inside the beer compartment. The return air port in a Maytag side by side refrigerator is located behind the crisper drawers in the beer compartment. Condensation can freeze in a sheet over this port blocking the return air flow, creating a warm compartment.
Jun 15, 2008 | Maytag MSD2754G Side by Side Refrigerator
I have an Amana(BB120) refer with the freezer on the bottom. The unit is ten years old. The refer is working fine. The freezer, however, won't lower the temperature below 31-32 degrees regardless of the...
hello
when the freezer is full of ice accumulated in the box, that could maintain to the freezing point. i guess that is normal, however if that the case. only the temperature control or the thermostat maybe something wrong. melnavz
Apr 07, 2008 | Refrigerators
Chef Base is cool but not cold enough and way to adjust this..
  • Check the thermostat control. Even if you've not touched it, something may have knocked it and adjusted the setting. The thermostat may also need to be adjusted depending on the temperature of its surroundings and the coldness of the weather.
  • Make sure any food stored in the fridge or freezer is not blocking any air vents. This can stop air circulating properly.
  • If the fridge is too close to the wall, the condenser coils will not function properly.
  • Defrost the fridge and freezer thoroughly and clean the inside surfaces with warm water. Check any air vents to ensure they are not blocked.
  • Clean the condenser coils at the back of the fridge using a vacuum cleaner, making sure all dust and any dirt are removed. Clean any stubborn dirt away with warm soapy water, being careful not to scrape the coils. Turn your fridge off and unplug it before doing this.
  • Make sure the fridge's fans are not clogged and are able to function properly. Again, you need to turn your fridge off and uplug it before attempting this.
  • Check the door is closing properly. Make sure nothing is obstructing it or pushing it slightly open. Ensure the seals around the edge are working well.
Jun 03, 2015 | Refrigerators
Why is Fridge not cooling well?
The part number you need is going to be WR09X10050. This is for the damper assembly, but while you are at it change out part number WR55X10150. this is the part that controls the damper and more than likely if one fails the other will be soon to follow
Jun 05, 2012 | Hotpoint Refrigerators
Fridge & freezer warm , temp control panel lights up interm when door opened , compressor will not start , compressor start capacitor replaced recently where to start
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Feb 24, 2011 | Amana AFD2535DES French Door Refrigerator
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Fridge will not cool properly
You may have a dust build up on the condenser coil. You may notice the jam of the ref door being very warm. This is an indication of a dirty coil (located under your ref) that just needs to be cleaned or your fan motor in the back of the unit may have failed and stopped turning.
Apr 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
