Programing my remote can't program VCR-DVD . It's an Emerson,I have enter both codes and it won't work
techman
  • 3130 Answers
SOURCE: Dish network
With the dish remote and do a code search as described in the remote manual and see if you can find it that way. If you go through the entire code search and none of them turn off the VCR/DVD combo, then there is nothing you can do, as those codes in the remote are all stored in the remote and they cannot be programed in. If you do not have a remote manual to set up the remote, to do a code search, simply go to the dishnetwork web site and search for it.
Posted on Sep 27, 2006
bubba10560
SOURCE: programing rca remote for dvd/vcr combo
all you have to do is press and hold code search when the light shows up let go of code search then press VCR and it will blink onces and let go of VCR and press OFF/ON about 50 times and then press enter onces and there you go
Posted on Mar 07, 2008
SOURCE: TV code for Emerson EWC 1301 TV/VCR Combo
how do use revmote to program tv vhs thank you11
Posted on Jun 21, 2008
SOURCE: Lost code book for large Brookstone remote
http://www.brookstone.com/bs_assets/files/pdf/product/manual/538744.pdf
Posted on May 02, 2009
SOURCE: Need code for Emerson TV,DVD,VCR Combo
called comcast
Posted on May 28, 2009
I bought an RCA RCR804BFDR UNIVERSAL REMOTE, I WAS ABLE TO PROGRAM THE TV, MY EMERSON VCR/DVD EWD2004 COMBO, I GOT THE VCR WORKING FINE,BUT THE DVD PLAYER WILL ONLY TURN OFF & ON. W/REMOTE. HELP PLZ!
Try to program the remoter for Emerson DVD too. code for DVD would be there in the manual you got. It will work.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2016 | RCA Televison & Video
Program a original Magnavox remote to a Emerson DVD/VCR
If it is a programmable remote, select DVD to send code to the player
Jan 22, 2013 | Televison & Video
I Need A Remote Code For An Emerson EWC19T5 and One For All URC 4021 remote
Hello
Setup codes for Emerson Tv with One For All URC-4021 remote control are:
0154, 0236, 0463, 0180, 0178,
0171, 0623
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable
box, and an RCA VCR.To control devices other than the default brands,perform
the following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
Sep 26, 2011 | One For All URC-3021 Remote Control
Looking for a code to use on my Dish Network (Universal) remote in order to operate my Emerson Model EWD2202 Combo VCR/DVD player
Hi my nameis Mike Houston of DISH Network and I was going over your post and see whereyou want the codes to program the DISH remote to the Emerson DVD/VCR. We do nothave the three digit codes to enter however we do have what we call a PowerScan and it will allow programming the remote to the Emerson player, I willsend a link to help with these steps. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Oct 31, 2010 | Emerson EWD2202 DVD Player/VCR
RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Oct 12, 2008 | RCA 257003 Remote Control
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
Mar 25, 2008 | RCA Universal Remote 3 Device Remote...
Coding to VCR and DVD
IF not then you should be able to program in Emerson 0591, 0675 for the DVD player
Emerson 0037, 0184, 0000, 0121, 0043, 0209 for the VCR
THe problem arises however, that the vcr and the dvd function buttons are the same, so you can only program one or the other. You need A different remote. I would suggest the 15-2142 made by radioshack. It is the Family 4 in 1 remote, and it has all the functions you need. THis remote is also backlit on some buttons to make it a little easier to see in the dark.
Mar 12, 2008 | Radio Shack (15-2147) Remote Control
Innovage Universal Remote
I have a unversal remote and i can not get it to work for the dvd/vdr I have from magnavox....can someone please help me
Oct 26, 2007 | Televison & Video
Dish network
Sep 27, 2006 | Emerson EWD2004
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
