Question about The Audio Players & Recorders
Cd player has 2 cds stuckin it.Do i have to remove the face plat
johncaman
  • 201 Answers
SOURCE: I was putting CDs in my Philips 3-CD Player and
The best solution is to open the case and manually remove/realign the jammed cd.
Posted on Mar 13, 2009
jaghaglee
SOURCE: Broderbund ClickArt cds not work'g w/Printmaster Platinum 17
Contacted Fixya's Support Team (Premium Service). Their proposed solution: be sure to install (copy) the other ClickArt CD art files into the same Art Gallery file folder as PM Plat 17. Have not tried it yet, but makes sense that it would work. Thanks for your help - Fixya later!!
Posted on Mar 20, 2009
SOURCE: We have a 2004 Cadillac
Remove stereo and unplug the 3 wire harness in the back, this should reset it. I had the same problem, cd was in motion to eject, but the gate (dam) wasn't moving down to allow the cd to come out.
Posted on May 25, 2009
SOURCE: Jammed cd player - 2002 Honda Accord
I have a 2002 honda accord with the 6 disc cd changer. I beleve the cd changer has jamed and have lost power to the CD player. When I press the CD button it wont recognise the player. Any suggestions
Posted on Nov 09, 2009
SOURCE: power is working face is not lighting up or
Did you try pluging the car (hard) blue remote wire into the "jack" on the back of the stereo arching it??
Posted on Feb 18, 2010
How do I take the stock CD player out of 2002 Buick rendezvous
Remove the face and there are two screws holding it in with anti theft heads which requires a special torque bit ,may be an earth strap at the rear.
Sep 29, 2015 | 2002 Buick Rendezvous
How can I eject stuck 3 CDs from CD player + GPS 2006 toyota camry grande?
there is small pinhole on the front of the player, you need to push thin stiff wire (paper clip straightened up will do) and this will mechanically release lock on the players doors, retract the doors fully and remove the dvd's.
Dec 29, 2014 | 2006 Toyota Camry
I got a cd stuck in a ford f150 CD player so i tried another cd to get it out but I have 2 CDs stuck know how to I get them out
you have to remove the entire radio out of the dash. theres 4 pin holes on the face of the radio. what I found worked best was a old metal coat hanger, cut 2- 8 inch lengths,fold them in a (U) shape & insert them in the holes to release the support bracket. O)nce u get it out there is a manual eject lever that will work for you.
Sep 16, 2013 | 2003 Ford F150 Regular Cab
I have 2 cd's stuck in the cd player of my car. Is there anyway to get them out without having to pay a professional to get them out for me?
Yes, if you want to save the CDs, you should remove the unit from the car, take off the face plate, and manually release the lock that holds the CDs down. Then fish them out the front one at a time. Not sure what model car you have, but it usually isn't too much work to get the CD player out. There may be a trim piece hiding the screws. You can usually just pull the trim straight off. If not, look for screws above the ash tray when it's open.
Feb 22, 2011 | Chrysler Concorde Cars & Trucks
My 2002 mercury cougar radio cd player says cd error and i have 2 cd's in there. it also will not load or eject them. what shoud i do?!?!
sometimes blank CDs that you purchase to burn your own music on are slightly larger than the CDs used by recording studios - they can get stuck and the only solution is to remove the CD player and then remove the top and carefully work the CD/s out being careful not to damage anything inside - then do not use them again in your vehicles CD player
Feb 05, 2011 | 2002 Mercury Cougar
Cd stuck in the multi cd changer
You have 2 solutions. You can either a) remove the cover from the megachanger, which consists of removing about 6-8 screws. With the cover off, locate the stuck CD and remove it. Or b) press the "Open" button and remove enough CDs so you can reach into the unit and remove the one that is stuck.The solution you choose will probably depend on how many CDs are currently in the player.
Jun 28, 2009 | Audio Players & Recorders
Mar 20, 2009 | Computers & Internet
Cd/stereo
I had the same problem with a different CD player. It turned out that there were 2 CDs in the player.It is only meant for one. I had to use a flat plastic spoon handle to gently lift the cd up and I saw there were 2 cds in it. I removed the player and took the cds off. it fixed the problem.Somebody must have put in another CD on top of the other one. I couldn't figure it out for a while. Maybe that's your problem too.
Aug 04, 2008 | 1999 Nissan Quest
Jvc in car cd player kd-g162
REMOVE THE FACE PLATE YOU SHOULD SEE A SMALL OPENING THIS IS THE RESET BUTTON PRESS IT GENTLY WITH A PEN THAT SHOULD SOLVE YOUR PROBLEM
Mar 19, 2008 | Car Audio & Video
2002 Ford Escape CD Player Problems
remove raido, remove top cover and face a t-10 4 screws in face remove 4 gold t-10 screws on tape asb. use a pocket screwdriver remove cds 1 at a time by lifting one tray at a time
Oct 24, 2007 | Car Audio & Video
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
