Question about Refrigerators
Its a Frigidare model FGHN2866PF
ITS NOT SUFFICIENTLY COOLING
We have model # hvd450se in our motel.we need to know if tere is any wattanty and what is wrong with tem when they quit cooling?
What brand is that model number? If you have the serial number as well you can probably look up on the manufacturer's website regarding the warranty.
Is it not cooling at all, or just not sufficiently? Do you ever hear the compressor running? Do the interior lights work so that you know it's getting power? Have you cleaned the condenser coils?
May 08, 2017 | Refrigerators
How do you check evaporator fan in frigidare model#LGUS2642LDO
Why? don't you hear it running inside the fridge when the door is opened and the fridge is cooling.
Oct 28, 2016 | Refrigerators
FGHS2866PF WATER FILTER BYPASS
That model does not come up. what is the question about bypass?
Aug 29, 2014 | Frigidaire FGHN2866PF Gallery 27.8 Cu. Ft....
Marvel 60AR7701 not cooling
I have an older model Marvel 6OAR7701 outdoor Frig....the compressor doesn't start. It may have gotten wet in that area. Any idea's
Apr 14, 2012 | Marvel Refrigerators
An air conditioning technician told me that my Carrier XCB183D (9 years old) needs to be replaced (not cooling sufficiently) but that model is no longer available. Is that true?
Thats very likely, they update and come up with more efficient units and discontinue the older models.
The compressor will lose effieciency over time.
Jul 28, 2011 | Carrier XHD183D Air Conditioner
Frigidare model # frs26znh freezer side works good refrigerator side dose not get cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 13, 2011 | Refrigerators
Frigidare frs26znh freezer side works good refrigiator side dose not get cold
heatman101
Jul 13, 2011 | Microwave Ovens
I have a Frigidare model FRS23R4A, side x side refrigerator. The refrigerator section is freezing up. We have continually reduced the setting to 1. What is the fix?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Refrigerators
Refrigerator is not sufficiently cold. Changing
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 14, 2010 | Sub-Zero Bottom Freezer Refrigerator
Top shelf of frigidare manual defrost freezer only freezing, other shelves are not cooling.
Is the condenser clean? If it is you may have a refrigerant leak or an inefficient compressor.
Jun 28, 2009 | Frigidaire Freezer Refrigeration White...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
