Question about Refrigerators
FRIDGE IS NOT SUFFICIENTLY COOLING - Refrigerators
aborcass
  • 2651 Answers
SOURCE: freezer/fridge fan not turning
if the unit is stuck in a defrost mode you eould have no cooling things in freexer would be defrosting quickly
Posted on Mar 13, 2008
22yooper
  • 828 Answers
SOURCE: the thermostat is not cooling
Is the compressor running continuously? Check the condenser and clean. If the condenser is plugged with dust you will have this problem. The thermostat only controls the compressor operation. If the compressor is hot and the freezer has no frost You need to call a service tech. If the condenser is found to be plugged with dust, shut the unit off, clean it and allow it to cool down before restarting it.
Posted on May 05, 2008
SOURCE: GE Side by Side Fridge Problem
could be defrost problem. check frost pattern on evaporator.
Posted on Jul 22, 2008
SOURCE: I own a three year
ice maker will not work,i push the handle to get ice it makes a noise like the motor is running .the water works just fine .please any ideas
Posted on Aug 02, 2008
  • 19 Answers
SOURCE: Inside Not Cooling and Outside is Hot
possibly could ned a new comprossor for the fridge.
Posted on Apr 22, 2009
Fridge and freezer portion of side-by-side GE Profile TPX21PR not cooling sufficiently. Technician came out and saw that only about 1/3rd of coils on freezer portion had frost and determined that we...
run the diagnostics on the unit from the enclosed tech spec sheet to see if possibly you have a bad thermistor/sensor in the unit,or possibly a bad defrost thermostat or defrost heater or the mainboard in the back is defective
Aug 18, 2011 | Refrigerators
Whirlpool Gold GD5SHAXLQ02- Serial number SP3131657 just stopped cooling. Neither the fridge and freezer seems to be cooling. This unitl is about 7 years old.
Hi!!
Check
temp. control knobs,
Small fan in freezer
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure the air duct going to the fridge is clear. Once this is done, restart unit.
If evaporator is not covered w/ice, then you may have a freon leak, Call a Service Center to get a repair estimate.
Don't forget to rate this post!! Good Luck
Aug 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator is not sufficiently cold. Changing
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 14, 2010 | Sub-Zero Bottom Freezer Refrigerator
I have ice build up on the back wall of my refrig. The fridge is not cooling sufficiently. This model has no freezer. The grill and area under fridge is dust free. What can I do?
The refrigerator may need more coolant. The system should be checked for any leaks before adding the appropriate freon replacement. (I do not know if this is user servicable or if it has to be done in the shop.) Check your warranty for the item to see if this is covered.
Sep 05, 2009 | Sub-Zero Refrigerators
Fridge lights flashing on and off, and inadequate cooling
could be a few things. sounds like the compressor is going. put a thermometer in it and play with the temperature settings.might have a short somewhere.
May 24, 2009 | Victory URD-27-SBS Stainless Steel
Apr 22, 2009 | Haier Refrigerators
Freezer ok(Whirpool -6 yrs old), but the fridge is not cooling sufficiently, only around 50 degrees. A lot of frost build up in the freezer. Have to thaw it every couple of days.
defrost system not working. take back panel off inside freezer.
check continuity thro the defrost element and stats mounted on the pipework
if all ok then points to a fault with timer or module
Sep 09, 2008 | Refrigerators
May 18, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
The thermostat is not cooling the fridge sufficiently despite the dial being turned to maximum 7.
May 05, 2008 | Refrigerators
Freezer/fridge fan not turning
Mar 13, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
