Question about Refrigerators
How many minutes it takes for regas a fridge - Refrigerators
I have a Whirlpool fridge, DA68 110338B S/No 43CJ201323. ITS running but I think its out of gas can the unit be regassed
Hi Peter.
Please allow me to try to help you.
It might be very possible for you to regas your fridge. The easiest way to do so is by getting a fridge mechanic to do the job.
You could also try to Do It Yourself, if you area DIY fan, but beware of the risks involved. You can find more info on how to DIY regas your fridge, right here -
But also, keep in mind, is it worth the cost of regassing your fridge? More on that..
Hope that helps.
Best wishes. Regards.
Nov 06, 2017 | Whirlpool Refrigerators
GE Profile CF24W-PL
Its simple really,, Your refrigator needs re gassing,, call a professional and he will regas it.
When the gas is running low the fridge cools less and less and eventually will not cool at all when the gas is depleated. Its a natural process and any aircondition or refrigation professional should be able to come to your house and gas up the refrigator , a process that takes a few minutes.. I dont recommend you attempt to do it your self, as it will not take a whole can of gas and if by chance you use the wrong type you will spiol the compressor
Jan 09, 2008 | GE Profile PSW26P Stainless Steel Side by...
I have a kic KTF295 fridge. i just need the amount of gas to charged it in grams. I thank you
The refrigeration engineer who will check your fridge for leaks, ensure no moisture is inside, sufficient lubricant is added and finally regas and seal the system will have literature to refer to for the correct gas quantity.
Sep 13, 2017 | Refrigerators
My fridge is not cold
This normally indicates that the gas is low. If compressor runs continuously, but fridge does not cool, then you must have a regas done. Dont let it run like this cos it can damage compressor by overheating.
Aug 26, 2014 | Kenmore Refrigerators
How to regas a Samsung Refrigerator model SRS610DHSS 611Ltr side by side fridge
You have to have a refrigeration license to do so because of recovery and EPA guidelines so you would need a licensed refrigeration technician to recharge your unit. Most cooling problems are not freon related, just fyi!
Mar 05, 2014 | Refrigerators
Maytag side by side refrigerator - refrigerator and freezer both not cooling.
I had same issue , required a new compressor and regas. All cooling for fridge side is blown in from freezer
Jan 25, 2013 | Maytag Refrigerators
DIY regas my fridge
With sufficient training and equipment this is not too hard to do, HOWEVER
1. Fridges contain high pressure gasses, some of these are flammable
2. You will need, guage manifold, accurate weighing scales (+/- 1 gram), a charging still, reclaim pump, reclaim cylinder, welding gear, access connectors, vacuum pump etc, Oh yes and an f-gas certificate.
My best advice DON'T TRY, lots of people get hurt doing this
I've fixed fridges for around 40 years now
Apr 14, 2011 | Danby Compact Refrigerator DCR-101W
Re-gas Hotpoint FFA64 Fridge Freezer
only certified tech's can regas refrigerator freezers and usually find there are other problems that caused the leakage . PAY to have it tested
Jan 28, 2018 | HP Refrigerators
Tempratue problem
air from the freezer fan, means the sensor- temperature control circuit is working right, it is trying to cool
there has likely been a leak from the system and there is not enough coolant left for the compressor to compress anything.
a GOOD repair guy
will have a pressure pump/gauge and test for leaks through the fill nozzle, repair them and regas the fridge (provided it is a non-CFC r12 fridge) without removing it from the home,
a not-so-good repair guy
will not
Sep 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
