Question about Water Heaters
Have a 892 e john deere excultvator is stalling when useing hydrcial
Do you think it is relief valve
I have a John Wood powervented gas water heater, model 322152-001(13-05). The temp pressure relief valve is leaking. How do I operate/reset the valve manually?
There is a leaver YOU CAN PULL up but this may not stop the valve passing it may wash any dirt of the seating ,It may be best to change the valve .
Dec 19, 2016 | Water Water Heaters
Water dripping from blowpipe
It is normal for water to drip out sometimes from the pressure relief valve outlet pipe. If it drips continuously then open and shut the pressure relief valve several times so the pressure relief valve shuts off properly.
If this does not fix the dripping problem then the pressure relief valve is faulty and needs to be replaced.
Apr 02, 2013 | Water Heaters
I have a 21v407 Rheem water heater that is leaking from the top relief valve. The leak i believe, is from under the valve. what is this problem. and how do u drain this thing?
Shut off the water supply valve over the heater. Shut off the electric or gas to the heater.
If you have any house or basement water valves below the level of the heater, open them and open a valve that is higher to vent it.
If necessary, open the drain at the bottom of the heater and using hose or buckets, lower the level below the relief/thermostatic valve. Be careful, the water is hot and softens even heavy hoses.
Once the water level is down, unthread the downtube (if there is one) from the discharge of the relief valve, unthread the relief valve from the heater and either dope/tape the threads or replace the relief valve.
Write back with any questions.
Sep 09, 2011 | Rheem Water Heaters
Have model C36 replaced t-stat relief valve and pressure reducing valve. Blowes off a temp over 170.
I think it is doing what it was designed to do. I think the water should not get to 170 degrees.
Is this a residential water heater?
Gary
Feb 04, 2011 | Hatco Corporation Water Heaters
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    My alpha cd32 boiler is 5 yrs old but now it keeps registering high pressure on the gauge when the heating is running. It is on the green when cold but goes up to 3/3.5 when running the heating. There is a...
    I would replace the relief valve or remove it to see if it is plugging up.
    Buy some cleaner and run it through if you have not done it in a while.
    Do the other anyway.
    Feb 01, 2011 | Watts 3/4 Pressure Relief Valve
    My relief valve slowly drips when my boiler runs, fills up a 5 gallon bucket in a day, when it runs alot. this is new ,
    Is the pressure in the boiler higher than the set pressure of the relief valve? If it is, there is a problem that the relief valve is trying to correct.
    If not, did you try making the valve open?
    Be careful, but step back, lift the lever and briefly let the relief valve discharge into a bucket of some sort, maybe you could put some old rags in it to keep from spraying out at you. If there is sediment in the valve this may flush it out.
    Dec 06, 2010 | Watts 3/4 Pressure Relief Valve
    MY GE PRESSURE RELIEF VALVE HAS JUST STARTED LEAKING. WHAT SHOULD I DO ? GE SMART WATER HEATER GELN0705CO3984
    You can buy a replacement relief valve at any hardware or home improvement store. It's real name is a T&P valve or temperature and pressure relief valve. It always has a 3/4" inlet and outlet. It is a very easy procedure to replace. You will need a bucket, teflon pipe thread tape, and a 3/4" x 6" black iron or galvanized pipe nipple. To start the valve replacement, turn off the shuttoff valve on the cold water line. Then open the handle on the relief valve and drain water into the bucket, that is, unless you have a pvc pipe coming off of it into a drain floor, then just drain it without the bucket. Be careful, the water is hot! When the water level gets below the relief valve, it will stop draining. Then remove the pvc pipe, if applicable, and thread in the 6" pipe nipple to use as a leverage tool to remove the valve from the water tank. Turn it counter clockwise to remove. Then put teflon tape on the new valve, going from left to right with the valve threads facing downward. Wrap about 3-4 layers all around the threads. Then twist the new valve into the water tank clockwise and using the pipe nipple tighten by hand until very snug and outlet is facing downward, as before. Remove the pipe nipple and install pvc pipe, if applicable. Leave valve handle open and turn on the cold water until the valve starts spitting, then close the relief valve and let it fill up the tank. If you did it correctly, you are now finished! Good luck!
    Douglas
    Jun 14, 2010 | Water Heaters
    It quit working and I removed panel and reset it.now it seems to make the water hoter and it is making constant noise and leeking a little from the pressure relief valve
    The pressure relief valve is bad if it is leaking due to too hot of temp or it has gone bad. If it is hotter turn down the temp on thermostat and see if it quits dripping..
    If it's making a noise it may be heating the water the way above the limit for the relief valve.
    If it is the relief valve they have them at most hardware stores and can be replaced. When installing use teflon tape on threads if this is the problem.
    May 21, 2010 | Water Heaters
    Relief blowing out hot water every hour or so. Controller? Set at about 125.
    try replacing the pressure relief valve to do so turn off water to heater and turn off power or gas which ever you have drain water from heater. then using pipe wrench remove old relief valve. when installing new valve use teflon tape on threads to prevent leaks then thread by hand back into water heater and use pipe wrench to snug dont over tighten turn water back on after full and no leaks turn power back on or relite piolit
    Nov 24, 2009 | Water Heaters
    Water Heaters Logo
    74 people viewed this question
    Top Water Heaters Experts
    Paul Carew
    Gil Shultz
    Are you a Water Heater Expert? Answer questions, earn points and help others
