Question about Cell Phones
Is peircing pin for Model#1600 available - Cell Phones
How to block unwanted call in Nokia 1600 mobile?
This feature is not available on this phone module.
Sep 18, 2016 | Nokia 1600 Cellular Phone
Need a replacement manual coolpix 1600; link to obtain PDF copy
Are you sure about the model number? The link below will take you to the Nikon website page that provides free manual downloads for all their products. I do not see any Coolpix cameras listed with the number 1600 as part of the I.D. Go to the link and check your camera's model number again.
Nikon Product Manuals available for download Nikon Knowledgebase
Dec 18, 2014 | Nikon COOLPIX Cameras
Where do I find the replacement plastic 5 blade fan for a B&D typhoon model bdsf 1600?
Try Sears parts direct enter you're model # and they should have it
Aug 08, 2017 | Dryers
On they list the White elasticator foot as no longer made or available.
Dec 06, 2011 | White Sewing Speedylock 1600 Mechanical...
Model msd2651kes Water supply very slow. I can't find any kinks in the lines. Detached hose from back of frig and water just dribbles out. Maybe I hooked up water supply incorrectly when I first...
If when first hooked up the water line if you used a peircing type valve that clamps onto the cold water pipe it clamps on,tighten the screws equally on both sides till its tight around the pipe.Turn that handle in to peirce the pipe in a clockwise motion till it stops,it will peirce the pipe but be in the closed position, so open it in counterclockwise direction till it stops
Aug 05, 2011 | Maytag MFF2557KES 25 cu. ft. French Door...
Refrig model msd 2574veq10 ice cubes are not solid and removal of water tray
the water coming in from the house plumbing is very low pressure thier is no way for me to tell what you have as far as the connection to the house plumbing ,you would need to find where is it and see why its restricted . I do suspect though that it has a peircing type valve that clamps onto a cold water pipe if that is the case what needs to be done it get one just like that peircing valve and install it next to the exsisting one and attach the 1/4 line to the ref. to it
if you dont feel your capable of it call a plumber and not a appliance tech since i am 100% confident its the supply to ref. and not a ref. problem
Jul 23, 2011 | Maytag Refrigerators
What does backprobing? Translate this electrical
Sticking your test light or meter probe in the back of a connector.
sounds more scientific dont it. Lee
Nov 23, 2009 | 2001 Ford Explorer Sport Trac
Dm 452 microphone
this radio is made by PEIRCE SIMPSON and is wired like a cobra.
pin 1 shiels or ground
pin 2 is audio
pin 3 is transmit
pin 4 is recieve
shield is a bare wire wraped around the audio wire.i dont know the colors of the wires in the echo mic.the transmit wire will have contiuity with the shield wire when the mic is keyed that wiregoes to pin 3 . there should be 2 wires left. check these wires one at a time with the shield wire one will have contiunity . this wire will go to pin 4 recieve.the other wire will go with the shield wire on pin 1
this is the way you find how it wires. it will take an ohm meter to find whice wire goes where.
james morgan
morgans electronics
Mar 09, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
