Question about Coffee Makers & Espresso Machines
Piercing pin for Model1600 ?? - Coffee Makers & Espresso Machines
Finding a seal kit for Crossman 357 air gun old style including piercing pin
You would need to contact the manufacturer for this parts kit. This site doesn't sell parts or have anyway to find them except a google search which you of course have already done.
Feb 16, 2017 | Air Tools & Compressors
I have Keurig 2.0. I have been cleaning it. I put white Vinegar in and running it through the maker. I am now running just water, but the water is not running any better. Suggestions?
Did you clean the top of the Keurig. When the top goes down, it has like a needle point when may get clogged with coffee grounds. Get a paper click and make straight it object, I clean the paper clip the insert to point and clean out the excess coffee.
Jan 02, 2017 | Keurig Coffee Makers & Espresso Machines
How to recharge air conditioner in 2000 tacoma?
Connect the charge line to the new bottle of AC Freon but be sure the piercing pin is screwed all the way out away from the container seal. Connect the other end to the charge line(covered by a cap like on your tire air fill), this will only fit one of two fittings. They're set up that way so there's no mistakes. The other is larger. After connection is complete, start the engine and turn the AC on so the compressor will suck the Freon into the system from the can, then screw the piercing pin all the way in to open the seal, then screw it back out to release the Freon from the can. To be sure ALL the Freon is removed, have a bucket of hot water there to set the Freon bottle into, and it will empty completely with the bottle in the hot water while engine and AC running. That's a good trick I learned long ago. Once the Freon bottle is empty, disconnect from the charge line fitting first, replace the cap you didn't lose, remove the can from the fill hose and put it where you can find it again, and your good to go.
Jul 01, 2014 | Vehicle Parts & Accessories
What is conch piercing?
Conch piercing is a type of ear piercing: Inner conch piercing is done at the center of the ear cartilage. Likewise outer conch piercing is done on the outer part of ear cartilage.
Feb 20, 2013 | Health & Beauty
0xc18a0106 error on HP C6280 printer
This can be caused by a number of problems however a common cause is when the pins in the ink cartridge bays haven't properly pierced the cartridge(s) when they were originally inserted. If the cartridge is almost empty it may be worthwhile trying to remove it and manually piercing it yourself with a pin.
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Oct 20, 2010 | HP C6280 All-in-One Printer
Dolce Gusto coffee machine hot water not flowing
use a solution of Bicarbonate of soda to clean scale from delivery pipe 1 tsp in 200ml
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Coffee Makers & Espresso Machines
The water will not go through the pod to make the coffee. If you remove the pod then the water flows. If you want tea the water goes through with no problem. We tried the vinegar but that didn't work...
This sounds like the pin used to puncture the K-Cup is clogged with something...
since a K-Cup is not used when making conventional Tea, this sounds like you need to remove the k-cup holder, which, by the way is a 2 piece unit on the B70 models... and I believe is the same for yours...
the lower third of the k-cup holder snaps off... revealing a better look at the Piercing Pin.
Looking at the sharp pin inside the holder, you should notice that it IS hollow... and you need a metal... not plastic coated paper clip and get it through the piercing needle.
I think that will do it...
May 17, 2010 | Keurig Elite B40 Coffee Maker
Need wiring color code for a 2000 saturn SL2 for hooking up a trailer light four pin connector
The trailer wires are left turn, right turn, running lights(the smaller elements on both tail-lights and any side lights) and ground. Energise the corresponding lights and connect the wires accordingly. Find a good ground. A piercing test probe will find the correct wire for you if you can't track it to the bulb.
May 06, 2009 | Saturn SL2 Cars & Trucks
Show test mode
my handset model1600 shows test mode , how do i turn on phone ?
thanks
Feb 29, 2008 | Nokia 1600 Cellular Phone
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
