Question about KitchenAid Refrigerators
How to clean drip pan on kitchenaid side-by-side refrigerator (model WF-L400V)
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
docjohn174
  • 943 Answers
SOURCE: refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Posted on Sep 11, 2008
barkencoa
  • 3463 Answers
SOURCE: how to empty drip pan
At the back of the food compartment where the water collects ,there is a drainage hole, this is blocked up,poke a long thin piece of wire or similar and poke it down the hole, this should clear the blockage,
If the water does not drain away then you need to go the rear of the frig and clear the rubber or plastic hose that you will see on the top of the motor compressor. this should solve the problem.
Plz rate this solution.
Thanks. and merry xmas.
Posted on Dec 20, 2008
  • 117 Answers
SOURCE: condensation dripping from top of refrigerator
The problem is the defrost drain trough is plugged with ice. You will have to turn off the refrigerator, remove the freezer back panel and use a baby aspirator to help you apply and remove hot water to melt the ice. Then insert the aspirator in the drain hole to blow out any thing that may have gotten lodged inside. You will hear the water draining now to the pain underneath the refrigerator. Hope that helps you, good luck!!
http://tclaundryrepair.com/
Posted on Feb 25, 2009
SOURCE: Kitchenaid Refrigerator dripping water
i have a kitchenaid top / bottom refrigerator water drips in top part only not freezer. what is my problem?
Posted on Jan 18, 2010
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
Drip pan full
Check if the drip pan is fixed to the motor or if it's using the evaporator element make sure it is warm enough to evaporate the water.
Jul 26, 2013 | KitchenAid KSRP25FNSS Side by Side...
Drip pan
The drip pan is located behind the toe panel (grille) at the bottom. The pan should be located in the left side. If you have auto defrost, the pan may or may not have water in it. It is likely to have accumulated grunge which can be removed by a good wash and rinse, being careful to avoid breaking the pan during cleaning. Reinstallation is the reverse of removal.
Sep 12, 2012 | Maytag MZD2766GES Side by Side...
I have a kitchenaid refrigerator kbfs20et that leaked
Yes it can and it also can confuse refrigerators with electronics. Think it is great you caught on the first time around. I have pictures of that happening to a Samsung and there was Ice in places I had never seen before. Yes if the refrigerator is near defrost and you leave the door open it will continue to try to cool and the compressor will run until the temperature is finally satisfied and the amount of water will be huge and overflow the condensate pan. Sea Breeze
Mar 15, 2010 | KitchenAid Architect® II KBFS20ETSS...
Drip is full of water and not evaporating
if the condesor fan motor was ever changed you could have a wrong rotation motor on it. Hot Air should blow across drain pan not **** cool air across pan
Mar 05, 2010 | KitchenAid (KSRD22FKST) Side by Side...
The drip pan that sits under the freezer side of our Kitchenaid Superba side by side refrigerator is full of nasty looking black water that I wanted to clean out but I can't figure out how to get it out of...
well to take that out ? which isn't normal part of it the drip pan catches water from the fridge / freezer and is caught in the pan while the evaporator generates heat to dry the pan out!! so if you really must remove it then you have to remove the wire in front of it to get it out other wise you just unplug it and reach in there with a brush to clean it
Jan 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba leaks from filter housing
i would definately change the filter
they are usually only good for 6 mos
or 400 gals
without knowing if its dripping from the housing
i would start with changing the filter and see if that takes care of it
AP3182816
i just checked and thesea re on sale
30.00 is pretty cheap
appliancepartspros.com
i used to sell these off my truck as a maytag guy
for 48
let me knoe
Oct 17, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Mice poo in the drip pan.how do I remove and clean?
Normally the pans are simply lifted a little to clear a lip formed by the frame and then pulled forward. If it hasn't been out before (or for a while) it may be necessary to slide a metal ruler or similar under the frame and pan to free it from the floor. They have relatively large surface area and it would take much gunk under it to make it seem immovable.
Jan 08, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Dec 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
How to clean the Drip Pan?
the Evaporator Tray should slide out after remove the bottom grille two clips hold it in...if you can't get it out use a wet shop vaccum with a rubber hose taped on the end ot it...let me know if you can get it.
Aug 26, 2007 | KitchenAid KSFS25FK Side by Side...
Refrigerators Logo
218 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
