Question about Canon Office Equipment & Supplies
How do you install ink cartridge in canon printer mp602b ?
cropp
  • 377 Answers
SOURCE: canon mp150 pixma printer error e5
dear warenout
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Posted on Mar 15, 2008
  • 4 Answers
SOURCE: Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Posted on Jan 09, 2009
SOURCE: Canon Pixma IP600D - error code 6502
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Posted on Jun 10, 2009
  • 191 Answers
SOURCE: Reset Canon printer chip
you can override ink check status and manually reset it in drivers options
Posted on Sep 22, 2009
manuel-d
  • 5 Answers
SOURCE: Canon Pixma ip1900 Printer wont print
i think you need a canon resetter just download it and it will fix your problem. gud luck ellyhill
Posted on Nov 16, 2009
Canon IR5000 Error code E000014-0000, I replace already two times fixing motor but the same error code? Is this the only fixing problem? Can you help me?
Resolve Canon Printer error E05?
The Canon printer error E05 execute due to the compatibility issue related to ink cartridge installed in the printer. This Error E05 as studies by Canon Printer Support professionals also may execute if the Ink Cartridge is not accurately installed. Further the Ink Cartridge in Canon printers comes with a small opening via which it easily gets the capability to discharge the ink which needs to be utilized on a certain paper. It is needed, when the printer is not at all required for a considerable period of time, and the ink may get easily dried up by blocking the cartridge opening. The Canon printer error E05 is also known to be executed by the disarrangement issue of a cartridge in its holder, or even when the cartridge needs to be replaced. This is considered a common issue but yes, it can easily be resolved.
There are 3 methods to resolve Canon Printer error E05
Method 1: Resetting of the printer
    ·Turn on the Canon printer first
    ·Next, Canon Printer Technical Support technicians have suggested users to hold and then press the button for at-least 5 to 6 seconds to enable rebooting process of the printer
    ·It is now ready to be used by you.
    Method 2: This method deals with the reinstalling and clearing of the printer blockage
      ·Open the lid cover carefully from the rare top of the Canon printer.
      ·Next, ink cartridge installed in the printer will automatically be visible
      ·It is needed to press the two "click-locks" key which is located at the sides of the cartridge holder, and then you will see that the ink cartridge will pop-out to be taken off automatically.
      ·Now, Check the cartridge if it is having any sort of dust particles, or have dried ink in its opening that could be causing the blockage.
      ·Cleaning of the cartridges is required which is suggested to be done by tissue and then re-install the ink cartridge in its holder.
      ·If the error still occurs then, one needs to replace the ink cartridge immediately.
      Method 3: Replacing of the Ink Cartridge
        ·Buying an Ink cartridge of the Canon printer from a local electronics retailer is recommended in this method.
        ·Re-installation of the cartridge is necessary by following the Method1. Come and explore our Canon Printer Customer Support services now and get your issues related to Canon printer resolved. We are available for users all day long by promising them to deliver the utmost solution available with us according to latest market trends.for more Contact on Canon Printer Support Phone Number 1-800-213-8289 for Repair Canon Printer
Canon Printer Support Phone Number 1 8002138289 Tech Support
Mar 20, 2017 | Canon imageRUNNER 5000 Copier
What is error e5 in mp 198 printer
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly..
  • In certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
  • Nov 18, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    HOW TO REMOVE E5 EARROR
    make sure you removed the orange tape from the cartridge.
    usualy E5 is when the color cartridge is faulty but if the orange tape is on the cartridge it will show E5.
    if you removed the orange tape an it still shows E5 go with the cartridge to the store where you purcess it for excange.
    Nov 18, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    Whats the meaning of error in canon e5 error?
    "E5: The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
    The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
    Install a recommended ink cartridge.
    Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
    If one of the ink cartridges is missing, this error can occur."
    Jul 22, 2010 | Canon PIXMA MP160 All-In-One InkJet...
    How to load new ink into printer Canon Pixma 620B ? Thank you!
    Step 1.
    Open the hood of your printer; if the ink cartridge holder does not slide into view, check to make sure the printer is turned on.
  • Step 2 Remove any empty cartridges from the ink cartridge holder and dispose of them properly. Some Canon printers have a protective cartridge lid that must be opened before you can change a cartridge.
  • Step 3 Remove all protective tape and plastic film from the fresh cartridge. Canon uses a bright orange protective tape on its ink cartridges. Some Canon ink cartridges also have a bright orange protective cap over the ink nozzle that must be removed before installation.
  • Step 4 Insert the new cartridge into the ink cartridge holder. Tilt the cartridge up slightly and insert end-first into the proper slot; push down gently on the cartridge to lock it into place. Some Canon printers have an indicator light that will activate when the cartridge is firmly installed; other models have a cartridge cover that will lock into place when closed.
  • Step 5 Close the hood of the printer. The printer will indicate when it is ready for use with a message on the LCD screen or by blinking the LED indicator light.
  • Jan 22, 2010 | Canon Office Equipment & Supplies
    Ir5000 error code e000005-000. how do I clear it?
    after fitting new cleaning web *28* takes you into service mode then follow the steps below to clear COPIER>COUNTER>MISC>FIX-WEB and COPIER> COUNTER>DRBL-1>FX-WEB.
    Oct 11, 2009 | Canon imageRUNNER 5000 Copier
    CANON MP160 PROBLOM E5
    E5 - The ink cartridges are not installed, or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly.
    E28 - Ink cartridge temperature rise error.
    Replace the cartridges.
    Call to authorized service center.
    Jun 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Inkjet cartridges
    Hello hotstikss
    The following are some error messages, if you are getting any of these, then you will have to investigate by reinstalling the cartridge or installing a new one.
    E14 The Ink cartridges whose destination are wrong
    E15 Ink cartridge is not installed E16 - Ink remaining is unknown
    E27 Waste ink absorber full or platen waste ink absorber full
    E28 Ink cartridge temperature rise error -
    E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
    If this does not sove the problem please let me know.
    Thanks
    Jun 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Installing new ink cartridge, canon pixma 1600
    Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
    Apr 04, 2008 | Canon PIXMA iP1600 Printer
    old marine
    old marine
