Question about Castle Toys
My little times classic Castle is missing a slide. The company doesn't sell this part .Have a solution for me?
How to fix crack in the slide
You might be able to use Fibre glass and fibre glass resin to cover the crack.
May 02, 2016 | Castle Little Tikes Climb and Slide Castle...
I need teplacement door for Little Tikes classic castle
try the littletikes.com website under replacement parent or try ebay
Sep 07, 2015 | Little Tikes Toys
HOW DO YOU GET STUBBORN PIECES APART
Maybe spray a little WD-40 or silicone spray in the cracks first. Then MAYBE very gently tap with a rubber mallot or tapping a board over the stubborn piece. The board spreads the blow around-less likely to create a dent.
Nov 21, 2013 | Little Tikes Climb and Slide Castle
Flash_integration.min.js i get this message everytime i load empireand allies game on zynga
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; GTB7.2; EasyBits GO v1.0)
Timestamp: Sun, 18 Dec 2011 09:17:33 UTC
Message: Object doesn't support this property or method
Line: 1
Char: 209
Code: 0
URI: http://assets.castle.zgncdn.com/19555/js/flash_integration.min.js
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Sep 30, 2011 | Microsoft Internet Explorer 8
The needle on my tone arm won't catch the grooves in the record and instead slides across the record
this old catridges have a small plastic where the neddle rest, but if its missing it couses to slide across the record, you will need to replace the whole assembly becouse they dont sell this little pieze by itself
Dec 25, 2009 | Audio Players & Recorders
A cracked plastic slide on my daughter's swing set
You can buy a new plastic slide from a company that sells swing sets, but the slide is probably going to cost more than a whole new swing set. The slides can be pricy when purchased separately. You might want to consider upgrading and going with a new, sturdier swing set. As far as I know, there is no way to repair the cracked slide since it is molded plastic.
Nov 04, 2009 | Little Tikes Cubhouse Swingset
Little tikes cozy coupe
Try replacing the screw. If you cant, get a long thin bolt and nut to replace it.
Jun 15, 2009 | Little Tikes Swing Along Castle
Your 4 screws may hold the swing piece to the slide piece. You actually secure it to the slide side wall with one of the red screw caps but you can also secure it with 4 screws that screw into the plastic.  You can also find the manual and assembly instructions at littletikes.com
Mar 04, 2009 | Little Tikes Swing Along Castle
Swing along castle broken parts need to order My
Go to littletikes.com. They have a seciton to choose outdoor products and you can drill down to the swing and slide castle. All the replacement parts are available there.
Feb 19, 2009 | Little Tikes Swing Along Castle
Toys Logo
27 people viewed this question
Top Castle Toys Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
D. E. Hev
Are you a Castle Toy Expert? Answer questions, earn points and help others
