Question about Thermador Microwave Ovens
Thermador MBES/01 microwave won't shut properly. Need to slam it shut in order for it to work.
2 Suggested Answers
SOURCE: mbes/01 runns 25 secnd shots off??
magnetron short defect. change magnetron
Posted on Jun 04, 2012
Thermador 01
make this test and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Oct 25, 2013 | Thermador MBES Microwave Oven
Is there a replacement microwave for the Thermador MBBS/01
The MBBS sereis was replaced by the MBES series.
Specs are here.
Nov 27, 2012 | Thermador MBBS Microwave Oven
REPLACEMENT MICROWAVE FOR THERMADOR MBES
That is good to know, some brand names will soak you just for their company logo.
Apr 22, 2012 | Thermador MBES Microwave Oven
Turns of before heating up food,inside lights are also dimming.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,./';
Jul 22, 2011 | Thermador MBES Microwave Oven
Thermador microwave doesn't turn on...you can set timer, push start but nothing happens
HI.When you turn ON your microwave,can you hear if motor is rotating?If you cant hear an ything from the motor..If you can check the terminal button of your oven.You can actually remove both sides of the oven and try to locate the terminal connection if it is engaged properly.Check also the motor.the motor might not be rotating or defective..Thank you for choosing FIXYA>>
Jul 20, 2011 | Thermador MBES Microwave Oven
Micro pops and lites flash. i have a thermador combo oven warming drawer and micrwave.
heatman101
May 01, 2011 | Thermador MBES Microwave Oven
MY displat shows a Child Lock problem. I find nothing in the manual about chikld lock. How do I unlock?
Manuals for some Thermador Microwaves are available here: http://www.thermador.com/trade/specifications-guides . Scroll down to Microwaves and select your model. Then press the link for Product Manuals and then choose the manual.
On the
MBES and MBESLFTD, the child lock feature is unlocked by pressing Settings 5 2 (touch each pad/number once).
If you have a different Thermador microwave, I'll check my stack of manuals for the specifics. (On a few other brands, the child lock can be toggled by pressing and holding the Start key. One of my other microwaves has a small padlock on the key to indicate the correct key. With that toggle, press and hold the key for 3-4 seconds or longer.)
I hope this helps.
Feb 19, 2011 | Thermador Microwave Ovens
Microwave Ovens Logo
50 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Chuck
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
