Question about Metabo Saws
Metabo we 14-150 plus 6" angle grinder. as soon as I plug it in the red light comes on and it will not run.I already replaced the brushes. cleaned up the commutator with scotchbrite.
4 Suggested Answers
  • 31 Answers
SOURCE: not getting enough power?
brushes or bearings worn out
Posted on May 15, 2009
brewerstool
  • 141 Answers
SOURCE: Carbon brush sizes
They are exactly the same brushes. Part number 316041640 .
Posted on Sep 15, 2009
heatman101
  • 43501 Answers
SOURCE: sparks are coming from my metabo w6-115 angle
The brushes are shot and need to be replaced...
You should be able to buy replacement parts here
heatman101
Posted on Jul 16, 2011
Sparks are coming from my metabo w6-115 angle grinder where the bushing are and it seems to be grinding a bit
There are always some sparks with power tools from the brushes.
You should remove the brushes for inspection to check wear.
Be sure to reinstall in the same direction.
Jul 16, 2011 | Metabo 06204 4 1/2" 900W Ang Grinder
How do you remove and release the quick grinder pad?
There is a button at the front of the grinder usually black or red, depress it lightly and rotate the wheel (unplug grinder please) wait until you feel it fall into spot, depress tightly and hold then turn wheel and unscrew to replace pad. Reverse to reassemble.Good Luck....
Apr 21, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
Grinder doesn't start everytime the switch is pushed on and the light at the base of the tool comes on. What could this be ,the grinder is several years old.
that is a service tool light and more than likely the brushes are worn and need to be replaced, make a wiring diagram before removing anything, you can get parts from ereplacementparts.com, you would need your brand and model number. Let me know if you need more assistance
Jan 29, 2011 | Metabo 01451 We14 150 Quick Electronic 6...
Grinder runs about 2 minutes then shuts off. I replaced the heat sensor- no change. What else could be the problem?
check the condition of the brushes, make sure not sticking in the brush tube and also look at the commutator for a really dirty surface.
Dec 21, 2010 | Metabo 01451 We14 150 Quick Electronic 6...
Carbon brush sizes
Sep 15, 2009 | Metabo WE14-150 Quick Angle Grinder
Magnetic brush size
Yes and no. From 1999 to early 2008, excluding the slightly beefier "Ergo" models, the size / part number is the same. However, on the newest models there are differences in density between some models. Wire placement is different from the older models.
Sep 13, 2009 | Metabo WE14-150 Quick Angle Grinder
Just replaced the brushes in a Metabo WE14-150Quick Angle grinder
when you replaced the brushes did you notice the tool throwing sparks? Generally when I work on these after replacing the brushes I have to clean the commutator to seat the new set. You could also have other problems, e.g. bad brush holder (did you replace as assembly or just brush) Let me know what happened to the first set and if when you plug in and try it does it come up to full speed.
Sep 12, 2009 | Metabo WE14-150 Quick Angle Grinder
Hello, my Metabo WE14-125 won't work anymore, there's a small red flickering light on my machine and I don't know what it means! At first I thought it were the carbon brushes, so I changed them, but the...
The light is an overload indicator that should come on when the tool is really hot. Internally, a sensor monitors the motor temperature and when the motor becomes too hot, tells the electronic to limit the voltage to the motor. This causes the tool to feel like it has no power. It should be run no load until it cools off, the LED goes out. The tool should have full power again.
If the light is on continuously, even when cool, and it doesn't run, get the tool to an authorizied service center; it may need a new armature. You can find your closest service center here:
http://www.metabo.us/Service-Centers-USA.5317.0.html?&no_cache=1
May 17, 2009 | Metabo W14 125 Ergo Angle Grinder 5"
Saws Logo
87 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
JOHN LAPIER
Are you a Metabo Saw Expert? Answer questions, earn points and help others
