Question about Samsung Dishwashers
I have a Samsung dishwasher DW80J994 series with an error code5C that sometimes appears.. Cleared drain hose and drain, but the dishwasher won't reset. What Can I do to reset it?
  • Samsung Master
  • 384 Answers
Repair and or check: Check for water leak under the dishwasher. Check the hoses, drain pump and tub. Replace any leaking components.
Parts Needed: Hoses or Drain pump
I am going to show you a video on how to check for these issues as well. This may not be your particular model but it will give you an idea of what you are going to need to do
https://www.youtube.com/watch?v=CIcQdApm6l0
Samsung Dishwasher LE leakage code FIX
We Are Here to Help !!!
Posted on Aug 09, 2017
SOURCE: Whirlpool dishwasher will not start
There is a small replacable part on the control panel circuit board which is like a fuse. It actually is a temperature fuse and it blows when the environment gets too hot for the circuit board. Unplug the dishwasher and take the door apart so you can see the circuit board. If you trace the power wires one of them leads to a little white module with 2 electrical tabs. Unplug the 2 wires and unsnap the module. You can check it with an ohm meter. IF its good the meter will register almost a short. f it's bad it will be open. The parts place I went to didn't even need a model number and he says he goes through a lot of them.
Posted on Nov 09, 2008
SOURCE: E5 error - need to know where drain hoses are
tried to take off the drain hose, but could not get it off the back, only by the disposal. I turned if off and on about 6 times and ran the delime cycle with lots of limeaway. It got the E5 error on the delime cycle, but it worked the next time I tried to run it.
The manual does say to turn it off and on as it drains out the water. Takes a while as it has to heat up the water each time.
Posted on May 20, 2009
  • 22 Answers
SOURCE: Jenn Air dishwasher leaking
the emptying valve is underneath in the middle normally and it is what the drain hose connects to on the dishwasher. The drain hose itself is connecting with either a c clamp or hose clamp, check to make sure it is tightened all the way. Also do you have an idea of what part of the dishwasher the leak is coming from? If it is not the drain valve, then check to make sure it is not leaking from the door itself, as the door just has a rubber gasket that seals it and it might be that the gasket is bad. If it's not the door and not the drain valve, it could then be coming from the drainage pump or the motor for the dishwasher, which means the seal is broken and the motor or pump would need replaced. If you are unsure of how to do so then i would contact a repair technician to fix it for you.
Posted on Jul 19, 2009
  • 4088 Answers
SOURCE: My Maytag Qriet Series 100 Dishwasher won't drain
Check the drain hose connection at the sink drain for local blockage. If ok, you may have to tear down the lower spray arm assembly down to the deck (noting orientation and position as you remove parts). Look for clogged screens and clogged openings in the deck. You can use a vacuum hooked to 'blow' to make sure these openings are clear. Wash the screens in hot water, detergent, and white vinegar to remove water and food deposits. Make sure upper and lower spray arms have open spray holes and no split seams. Hope this gets you running again!
Posted on Feb 11, 2010
  • 62 Answers
SOURCE: Dishwasher won't drain
pop out the plug where the hose hooks to garbage disposal
Posted on May 01, 2012
5e code displayed someone came and looked at it - everything was fine - ran through a cycle and showing the code again
This is what I found for you:
5E WATER DRAIN ERROR 5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Check your drain system and verify the unit can drain water. If you have too, remove the drain hose and drain into a bucket to verify it can drain. This could be from some obstruction within the hose or air-gap or disposal, however you unit drains. Good Luck
Apr 20, 2016 | Samsung Dishwashers
How do i fix an SE error code on my Samsung dishwasher
The SE or 5E error code means "Draining Error", which coincides with what you observed. First check the drain hose for an obstruction, especially where it goes into the garbage disposer (and check the garbage disposer port to make sure it is clear too). If that's okay, then you will have to pull the dishwasher out to check the drain pump. Chances are, some foreigh object has gotten into the drain pump, and is blocking or partially blocking the water flow. If everything is OK, then you probably have a bad ECS sensor, and will have to replace it. If most of this is beyond what you want to do, at least check the hose at the garbage disposal end before you call a repairman.
Feb 10, 2015 | Samsung DMT800RHS Dishwasher
Dishwasher goes to se display during cycle
That's actually a 5E error code. The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose are okay.
Dec 26, 2014 | Samsung Dishwashers
I have a Samsung Dishwasher DMT800RHS, dishes have brown film, tried Lemon Magic, fixed 9e code, still dirty dishes. Used liquid detergent, still dirty dishes. Sometimes white film.
Sounds like its not draining properly between cycles. Its time for an appliance engineer I'm guessing. Can you access the drain pump hose area to see if its clogged.
Nov 06, 2014 | Samsung 800 Series DMT800RHW 24"...
5e or se code on samsung dishwasher
The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose check out okay.
Sep 07, 2014 | Samsung Dishwashers
Samsung error E5
I don't know about a E5 error; are you sure it's not a 5E error? That means a drain error or "water not draining" error. Check the drain pump and drain hose for an obstruction. If that's okay, and the dishwasher drains water, then you probably have a bad ECS sensor.
Mar 30, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
Water won't go down drain.
It appears that you have a drain pipe problem. Check that the hose is not restricted ( kinks etc) Get a good drain cleaner that you can use in you machine and clear the gunk out of the hose. Contact simpson dealer for a compatible product to do the job as some drain cleaners react with the steel and hoses.
May 06, 2013 | Dishwashers
Intake/Drain light is flashing and dishwasher won't do anyhting. I gve cleaned the filetr and still nothing
Hi
Intake/Drain light flashing means an issue while draining. You would need to check for air gap on the dishwasher, it may be clogged. It prevents dishwasher from draining, sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections & remove motor (single screw holds motor, it is on the outside back of the machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate it, then motor will be required. If the error still appears then cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Switch the appliance off and then back on again. Hope this helps... Please post back if you need more information.
Daniel
Jun 08, 2011 | Miele 24 in. G638 Plus Free-standing...
I have 5E showing on my dishwasher. What is does this error mean?
ost common error codes that are caused by installation errors are:
  • 5E. If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose. A good indication that the drain hose is kinked is excessive water in the bottom of your dishwasher after a cycle has been completed. If your dishwasher is displaying error code 5E, your dishwasher will have to be removed to inspect the drain hose for kinks. If your dishwasher was professionally installed, contact the installer to remove the dishwasher and inspect the drain hose. If you installed the dishwasher your self, the dishwasher will have to be removed for drain hose inspection.
  • Info provided by Articlead.com
Dec 09, 2010 | Samsung DMR57LF Builtin Dishwasher
Dishwashers Logo
112 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
