Question about Honeywell Heating & Cooling
I have a small Honeywell tabletop fan that I completely dissected unwired motor to clean completely. When I reassembled the fan the air blows backwards, any suggestions
  • 1,610 Answers
Lol. Turn the fan around!!
Posted on Aug 09, 2017
  • Honeywell Master
  • 9,113 Answers
Switch the power leads
the dr
  • 447 Answers
SOURCE: inside fan motor - evaporator
Yes if you dont hear the evap fan wprking remove rear panel in freezer let me know what you see. Is coil iced over? Is fan running? Is the motor warm? Attempt to spin the blade gently to see if the motor is bound. You can oil these.
Posted on Dec 02, 2007
SOURCE: AC fan not blowing/ Honeywell T87F thermastat
if you have a voltmeter that checks capacitance, check the capacitor ( silver looking battery) that is mounted on the side of the blower housing in the furnace. You need to take the wires off!! A bad Cap will slow down the fan and if its blown/dead the fan will not run.
If youre more than 1 MFD off the rating stamped on the capacitor, Replace it.
Posted on Jul 08, 2008
  • 23 Answers
SOURCE: PC Fan Issues
1 fan in and 1 fan out, usually out through the front.
Posted on Jan 24, 2009
  • 23 Answers
SOURCE: one honeywell to another
you need to program the thermostat for the reversing valve "O" it will tell you how to do this in the manual. you will need to chang from "O" to "B" or "B" to "O" depending on how its set.
Posted on Jun 25, 2009
james3751
  • 614 Answers
SOURCE: how to replace window air conditioner fan motor
Most of the time I go in from the top of unit with pkiers to remove clip. Once the clip is loose. Hold the shaft with channel locks and the fan should spin. Russ
Posted on Aug 24, 2009
GE AEH10AMG1 was working fine a week ago. Plugged it into the same socket yesterday, and the breaker in the plug popped, and it keeps popping when we try to plug in the unit.
You have a direct short in the A/C unit probably at the compressor or your condenser fan motor. You can disconnect one component at a time to identify where it is shorting. turn power off unwire condenser fan motor secure wires so they dont touch anything plug unit in if it still pops breaker your compressor is probably bad.
May 19, 2011 | GE Heating & Cooling
First time starting a/c this season, display is lit but no air is blowing. Fan outside is on. Batteries changed, still no air. System is only @ 2 years old. Stat model - TH3110D1008. Thanks.
Set the thermostat FAN setting to FAN ON to verify the fan working.
If it works in the FAN ON position the fan motor is OK and you have a bad fan relay.
If it does not work you should check the fan motor capacitor.
At 2 years old the unit is still under warranty for parts.
Apr 26, 2011 | Honeywell Heating & Cooling
Fan does not blow. Believe we need a new fan motor.
Have you considered checking to see if the fan motor might just need cleaning and lubricating?
Most small fans and heaters, have small fan motors, in which the bearings have dried out over the years. If you have made an electrical check on the motor leads-- and you have electric going into the windings, likely the motor feels warm? (If not-- possibly a bad splice where the supply wire attaches to the tiny armature wires?-- check , and check continuity)
If you want to tear into the fan motor, and clean up and lubricate the bearings-- here are some tips:
First you need to get inside the heater of the fan housing-- by removing the protective covers.
Note the screws, sizes, locations, and how the protective covers will go back on when you are ready to reassembly-- Mark where the screw holes are that line up with the matching other parts.
Then remove the motor from it's bracket (Possibly have to remove the fan first?)
You will have to remove the fan, to lubricate both front and real bearings.
Next you will need to remove the 4 long screws that hold the motor frame together-- Be sure to mark the original alignment, so you can reassembly correctly.
Now, with the fan removed, gently separate the Front and rear half's of the motor. Usually the windings will stay with the portion of the motor wher the wires are still attached. Either way, you are going to have to get the bearings to slide off both Shafts of the armature-- without breaking the delicate winding wires-- the wires are hair thin on small motors!
Now clean up the caked on residue on the shaft where the bearings ride, with rubbing alcohol. Clean up the internals of the bearings as best you can- making sure the pores of the oil-lite bearings are not plugged with solids. Now begin the gentle process of getting the bearing wicking to soak up new oil. When you are sure the reservoirs are well saturated, then generously lubricate the shafts, and slip them thru the bearings again-- retracing all your steps above, The motor shaft should turn freely now. You can test the motor without the fan on-- to be sure you have the motor itself reassembled properly.
Double check all the splices, switches, and any high temperature limit switches for continuity-- and trace the wiring all the way back out thru the power supply cord.
What did you find, and what do you need to do next?
Let us know--
Mack B
Jan 23, 2011 | Lakewood 798240 Utility Heater
Washer Front Panel states: 70 Series Heavy Duty Plus Dryer Label inside door says: Model / Stock No 87980100 79801 Ser No M94039293. Dryer Issue: Drum Turns, Clothes get hot, Lint screen clean, 1.5 ft Exh...
Possible blower fan failure, Or Blower fan blades are choked with lint, so no blow.
Your gonna need to open it up. If fan blades are choked, simply clean and vacuum them. Reassemble and test run.
If fan blades are clear, (minor lint-ing will not stop it working) then it indicates fan motor is bad.
Possibly a capacitor (motor starter) rather than motor. Usually a small cylindrical object with wires attached, located in close proximity with related motor. Check for swelling, leaking. if looks OK it's likely fine.
Capacitor is cheap to replace first. Must use SAME VALUES as original.
Nov 17, 2010 | Kenmore Dryers
Hi, Honeywell (HZ-341BL) Ceramic Heater stopped working. Can i get help
when most ceramic room heaters stop working, the blower is clogged with lint and dust from floor use . get an air compressor, or a can of air. take unit outside using a small head philips driver remove screws while laying on an old sheet .disassemble cover carefully and blow dust away from you and clean blade without bending with a toothbrush in vinegar water not gettting any liquid on the electrical parts. reassemble. thanks karl
Dec 14, 2009 | Honeywell (HZ-341BL) Ceramic Heater
My AC quit blowing cold air all of a sudden while I was out of town - my wife turned off the compressor and turned the fan to on, thinking it may be froze up - 2 hours later still no cold air - service...
Depending on how it's wired, she might have turned it off and on again and popped a breaker. It could be wired with a breaker for the fan motor and a breaker for the compressor.
Oct 07, 2009 | Honeywell Heating & Cooling
Unexpected shutdown
how long since you cleaned , ck fan for cabinet and carefully remove processor fan clean fan and take a small soft brush to sinc fins while you vac or blow a can of pressurized air until you sure clean reassemble try again could be heat you will know more when you see how much dirt is inside
Dec 22, 2008 | Gateway Computers & Internet
Honeywell manual thermostat t87F, how to take off dial
ring around clear number section pulls off then there are three small flat head screws undo those aand the outer face with the dial comes off. if you are just trying to clean out the clear dial from bugs or small debris simply lift with small screwdriver and blow into it.
Nov 22, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
