Question about Vacuums
The wand won't snap down into place - Vacuums
Remove handle from hose electrolux
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
May 17, 2014 | Electrolux Vacuums
Install wand handle catch
You line up the spring, place the two top prongs behind the lip on the wand and gently snap it home onto the two locating pins. You can also now get a workshop manual for the DC07, it is item number 0955687411 on Amazon.
Apr 02, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson telescopic wand won't go back in (model dc14
take the wand off from the bottom and untwist it
May 25, 2013 | Vacuums
I have a Dyson Animal vacuum. My wife removed the handle to use some of the attachments for cleaning. When placing the handle back to the vacuum, she attached the top part of the handle back to the...
Sorry to hear you're having difficulties with your DC07 Animal. From what you've described, it sounds as if the wand has been replaced on the cleaner without the hose being retracted. To remove the wand from the machine, hold the cleaner securely in place by placing one foot on the cleaner head, then pull the wand up forcefully whilst holding the purple quick-draw hose release (located above the on/off switch) down. Make sure you are not leaning over the top of the wand as you do this.
Once you've freed the wand from the cleaner, make sure you retract the wand before replacing it on the cleaner again. Hold down the hose release button on the hose cuff as you retract the wand inside the hose.
You might find it useful to refer to the user guide supplied with the cleaner - in case you don't have this to hand, you can download a copy here:
If you have any further queries about using or maintaining your Dyson cleaner, please call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide the assistance you need. Alternatively, you can resolve many issues without picking up the phone by visiting and clicking 'Support'.
Kind regards,
Dyson Online Customer Support
Aug 28, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
When the dyson is in the upright position it goes off and I cannot use the wand . . . I have cleaned the filter and nothing is stuck in the hose but the wand has no suction power. HELP! I love my DYSON! ...
Here is something to try. Follow the hose down to where it snaps into the main base. My hose has come loose a couple times. There should be to clips that you can pinch to remove the hose. Make sure it is fully snapped in.
When you remove the hose, is there suction coming through that rectangular hole?
Jun 28, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My wand on my canister began to spark and snap and smoke. The element was melting. and now I am stuck with only a working canister. the elememt or electrical hook up is burned up...and I guess I am gonna...
How's the hose?
If it's only one wand, yes, you'll need to buy a new one. It depends on where it burnt out. If it was at a connection to the hose, the other wand, or the power nozzle, you need to check the connections thoroughly for discoloration, breaks/cracks, and potentially shorts in the hose, wand, and power nozzle.
The entire vacuum should be taken to the nearest Aerus Electrolux dealer for troubleshooting for what caused the sparking in the first place.
Jan 09, 2011 | Electrolux Lux 5500 Canister Vacuum
How do you put the telescopic wand down? Just got a new dyson 17 and I cant use it cause I cant get the dang wand down..
make sure your handle is snapped in all the way on to the machine, that will release the clip on the hose to allow for the wand to slide in.
Jan 06, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I can't figure out how to hook up hose attachment to dyson 07
You have a reversible wand on the DC07. You have to separate the wand from the hose first, then turn it around and reconnect it. Once that is done you will be able to use the attachments on the end of the wand. You can also connect your attachments to the hose.
To separate the wand:
1) Take the wand off the back of the machine
2) Place one hand on the Handle and one hand on the gray flexible hose.
3) Push the flexible hose down. You will see a long metal rod appearing. Push until the hose clicks into place at the bottom of the metal rod.
4) You'll see a half-moon shape button with a picture of a lock on the solid gray plastic part at the top of the hose - push it, this will separate the wand from the hose.
5) Turn the wand around
6) Push the purple wand cap with the holes in it back, it exposes a short dark gray pipe, about an inch in length
7) Connect the hose to the short pipe
8) Attach your tools to the top of the metal rod and have fun
Jul 08, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Clogged hose...
Low suction, poor pickup, or no suction may be due to a clog in the vacuum cleaner. If you notice a change in the sound of the motor or a reduction in the spinning action in the Dirt Container, check for clogs. Unplug cleaner from electrical outlet. Empty Dirt Container. Check Upper Tank and Louvers for build up or clogs. Check to make sure Louvers are installed correctly. To unlock the Louvers, grasp the rim and turn toward the left. Pull straight down to remove. If the Louvers are missing or not locked into place, check and clear the tube in the center of the Dirt Container. Remove the Twist ‘n Snap Hose from the vacuum by turning to the left. Check the Suction Inlet, Hose and Hose Wand for clogs. Remove any clogs from the hose using a long, narrow object. Check the Foot Hose for clogs. If needed, remove the screw attaching the Hose Wand Base to the vacuum. Straighten the Foot Hose and unclog with a long, narrow object. If the clog persists, then check the Rotating Floor Brush the Air Passageway for obstructions.
Please do rate this solution as FixYa and revert for further assistance.
May 10, 2009 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
