Question about Filter Vacuums
Replaced air filter there is a warning symbol on vacuum and it will not turn on
Why won't My Hoover savvy won't turn on
Hi Denell! Your vacuum has a thermal protector that will shut it off automatically if it becomes overheated. This is usually caused by a clog or a filter that needs to be cleaned or replaced. Follow these quick steps to check your vacuum for clogs.
1. Remove the dirt cup and the dirt cup lid.
2. Grasp pre-filter frame and pull up and out of dirt cup.
3. Separate the pre-filter and Hepa cartridge filter. The pre-filter can be cleaned with a brush and then rinsed with water. Allow 24 hours to air dry.
4. Clean the Hepa cartridge filter by tapping either of the ends until dirt stops falling from the filter. The Hepa filter should be replaced once a year.
5. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
6. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose
The vacuum will turn back on after it cools off. This can take up to an hour. If the vacuum has been off for over 24 hours we recommend taking your vacuum in to a service center for repair. Follow the link to locate the nearest authorized service center to you.
Service Center Locator
Hope this helps!
Aug 13, 2014 | Hoover U8145-900 Savvy Bagless Upright...
Why is my hoover windtunnel vacuum cleaner shutting off?
Hi there! Sounds like the thermal protector is being activated. This is usually caused by a clog or a filter that needs to be cleaned or replaced. Follow the steps below to prevent the unit from shutting off.
1. Remove the hose completely.
2. Use a broom stick to gently loosen and clear hose of clogs.
3. Remove the bottom plate and brush-roll.
4. Use a wooden spoon or something similar to break up and remove any clogs from lower hose.
5. Check the primary filter behind the side grille. If it is dirty you may rinse it under running water and allow 24 hours to air dry outside the vacuum.
6. Remove the bag door. Clean the primary filter located on the vacuum under the bag. Rinse with water and allow 24 hours to air dry outside the vacuum. The primary and secondary filters should be replaced at least once a year.
7. Check that the bag is not full. If it is, replace the bag.
The vacuum will turn back on when it cools off. This can take up to an hour. Hope this was helpful!
Jul 08, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
If the filter is clogged would it quit working
Hi there! If the filter is clogged this will cause the vacuum to lose suction and possibly shut-off. Below are instructions to checking and cleaning your filters.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Jun 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
No dirt in cup and the red thing does not turn
Hello! It sounds like your vacuum has lost suction. This is caused by either a clog or a filter that needs to be cleaned or replaced. Please try these brief trouble-shooting steps.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
Exhaust Foam Filter
Primary Filter
May 10, 2014 | Hoover Nano Cyclonic Compact Bagless...
Resetting
Hello! The vacuum will reset itself, you only need to allow it time to cool off.This can take up to an hour. Overheating is usually caused by a clog or a filter that needs to be cleaned or replaced. Below are simple instructions for checking your vacuum for clogs.
Primary Filter
Exhaust Foam Filter
Mar 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
It runs but not pick up dirt in cup
Hello! If the dirt is not entering into the dirt cup this could mean there is a clog in the vacuum or a filter that needs to be cleaned or replaced. Check that the brushes are still spinning. The vacuum has a brush-roll shut-off pedal on the right side of the cleaner if you are standing behind it. Below are simple instructions for checking your vacuum for clogs.
9. Inspect the belt for damages, if the belt is broken replace the belt with a Genuine Hoover belt part 562633001 Flat Belt Nano Upright
Primary Filter
Exhaust Foam Filter
Hope this helps!
Mar 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
Warning light on, vacuum will not turn on
Your machine is clogged ... probably in the hose.
ASSURE the air path is clear and the filters are clean before yhou proceed.
Let me know how you make out on this.
a
Sep 23, 2009 | Miele S558 Red Velvet Bagged Canister...
U5180-910 vacuum shuts off on own
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Nov 18, 2007 | Hoover U5180-900 Vacuum
My vacuum is not sucking at all.....
I took out the air flow filter at the back of the vacuum and turned it on, somehow the clog cleared. Then I put the filter back in and it works perfectly! Barb
Mar 01, 2007 | Kenmore 35912 / 35913 Progressive Upright...
Vacuums Logo
Top Filter Vacuums Experts
Shekar Avadhani
Lawrence Oravetz
Are you a Filter Vacuum Expert? Answer questions, earn points and help others
