Question about Pool & Spa
How do you repair pool gunite on sides of pool above waterline ?
    Top Expert:
  • Pool & Spa Master
  • 8,175 Answers
Tile
Posted on Sep 13, 2017
How many gallons of water are in a pool 16 ft wide 32 ft long 4 ft deep
Approximately 15,300 gallons assuming the 4' depth is pool bottom to waterline.
Aug 13, 2014 | Pool & Spa
Will a hayward pool cleaner that is for a fibreglass pool work in a vinyl pool
Most Hayward pool cleaners, including the Navigator that you pictured above, are designed to work on fiberglass, gunite, and vinyl liner pools. If you have this pool cleaner, it should work on any of these surfaces effectively.
Apr 13, 2011 | Hayward Navigator Pool Cleaner
The wall fitting seems to have lost the "set screws" or the two pins that protrude from the fitting to hold the hose in the fitting, Are these pins replacable or will the fitting have to be replaced? I...
Thank you for posting your question here on Fixya.com.
Is the fitting insert missing or do you still have the insert but the tabs are broken off? Either way, you can get the replacement and thread it into the wall port. You may have to remove whatever is left of the damaged insert first. The part is called the Universal Wall Fitting, part number 650000. They are about $5 at a local pool store.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Aug 09, 2010 | POLARIS SOFTUBE QUICK CONNECT - P-133
I have just purchased a Kreepy Krawler for my inground gunite pool. It pulsates and has suction, but does not move at all.I have it hooked up as per the manual, and everything is closed off like when I...
Make sure that there are no obstructions in the pump, filter, and flaps of the cleaner. Debris can restrict movement of this type of automatic pool cleaner. Also check for hose leaks and to make sure that your suction is correct.
Jun 18, 2010 | Universal Kreepy Krauly In-Ground Pool...
Assembly schematics
On Jandy's website, about 3/4 of the way down in the right-hand column, you will see several links to various Ray-Vac documents. Focus on the gunite versions if your pool is cement or plaster.
John
Apr 12, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Krauly does not sit flat on bottom of pool floor, also leans to one side
check the dive/float assembly. It's the dual float with arms that is hinges off of the main body. It should be near the bottom, if it has come loose and is near the top of the unit, it will cause the problems you mentioned. You may have to replace the weight holder to fix it.
Oct 08, 2009 | NRS Kreepy Krauly Gunite Builder In Ground...
Runs in a small circle
A couple of things to check. 1. sometimes the hose at the back of the head will develop a small hole or crack where water will escape and cause the vac to run in circles.
2. if the head is getting old, you might have enough wear that the little wheels on the bottom stay mostly in one location, pushing in one directon.
May 15, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
Using a hayward vari-flo valve model SP 710x32
Do not drain a vinyl liner pool mor than half way....ever... If you have a fiberglass, or gunite pool it is important to pull the hydrostatic plug under the main drain cover. If you live down a hill, or where there is a high water table, the water pressure underground can lift the empty pool out of the ground (more common in fiberglass pools). If you have a sand or DE filter switch the valve to waste. make sure that you have the skimmer turned off, and the pump is only sucking from the pool main drain (spa drain closed also), and turn the pump on. Make sure the waste hose is far enough away so you dont add any hydrostatic pressure.
Mar 27, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
